| Local task commit message after updating to Mylyn 3.0.2 [message #58722] |
Tue, 30 September 2008 04:41  |
Originally posted by: mauro.molinari.cardinis.com
Hello!
After updating to Mylyn 3.0.2 (from 3.0.1, using update manager), I have
a problem with the commit message automatically generated by Mylyn for
my working set.
Instead of:
task 47: Supporto a NPW per Personal Planner
now Mylyn suggests:
taskSupporto a NPW per Personal Planner
Please note that "Supporto a NPW per Personal Planner" is the name of my
local task and that the commit template is set to:
${connector.task.prefix} ${task.key}: ${task.description}
${task.url}
I don't know if the problem was introduced by 3.0.2 or 3.0.1, but I'm
sure it worked well with Mylyn 3.0.0 (and 2.x).
Is anyone having the same problem?
Mauro.
| Re: Local task commit message after updating to Mylyn 3.0.2 [message #59389 is a reply to message #59267] |
Fri, 03 October 2008 04:08  |
Steffen Pingel ha scritto:
> Yes, this will also affect Bugzilla but since the key and id are equal for
> Bugzilla it should have the same result.
Ok, thank you!
> Note that uou can define commit templates on a per project bases in the
> project properties.
But this does not help very much: I'm working on a project on which I
need to close some bugs (=> from Bugzilla repository) and develop some
functions that are not in bugzilla (=> I'm using local tasks). So, the
base is not the project. This is because we're not using just Bugzilla
to track our issues and local tasks are often handful to create change
sets for some group of changes.
Moreover, I'm not working with a single project, but with many projects
with dependencies to each other. So I think a project-specific commit
template is quite useless in my case.
>> - if ${task.key} does not work anymore for local tasks, I would expect
>> to see my commit message as:
>> task : Supporto a NPW per Personal Planner
>> because the commit template is:
>> ${task.url}
>> Instead, it seems that Mylyn cuts " : ": why?
> That could be be a bug.
I opened bug #249572.
Thank you!
Mauro.
| Re: Local task commit message after updating to Mylyn 3.0.2 [message #593798 is a reply to message #58722] |
Wed, 01 October 2008 18:42  |
Hi Mauro,
the change you are describing is caused by an intentional fix that was made
for Mylyn 3.0.2:
242310: TaskKey CommitTemplateVariable should not use the task id
https://bugs.eclipse.org/bugs/show_bug.cgi?id=242310
The task id for local tasks is not displayed anywhere in the UI and
therefore should not be used as part of the default commit template.
If you replace ${task.key} by ${task.id} in the template you should be able
to get the id back for local tasks.
Steffen
> Hello!
> my working set.
> Instead of:
> now Mylyn suggests:
> ${task.url}
> Mauro.
| Re: Local task commit message after updating to Mylyn 3.0.2 [message #593845 is a reply to message #59066] |
Thu, 02 October 2008 04:26  |
> Hi Mauro,
> for Mylyn 3.0.2:
> Steffen
Hi Steffen, thanks for your info.
However I have a few questions:
- if I change ${task.key} with ${task.id} is there any side effect for
Bugzilla tasks? Do I have to switch the template every time I switch
from the local repository to the Bugzilla repository?
${task.url}
- what is now the default commit template in 3.0.2? I think this is
quite a "breaking change" to be included in 3.0.2 from 3.0.1... isn't
it? Apart from the fact that this totally breaks the link between CVS
history entries and local tasks (if it has ever worked... see my bug
#198361)...
Mauro.
| Re: Local task commit message after updating to Mylyn 3.0.2 [message #593880 is a reply to message #59166] |
Thu, 02 October 2008 14:24  |
project properties.
> ${task.url}
> #198361)...
The default commit template is still the same as in previous versions.
I understand that the change how task ids are handled for local tasks can
appear as an unexpected change in a minor release. The task id is internal
to some repositories such as the local repository or JIRA. Some
repositories even use long random generated text for task ids which looks
very odd if exposed in the UI. Therefore it was considered a bug that the
${task.key} template returned these ids which can still be explicitly
configured by using ${task.id}.
Steffen
| Re: Local task commit message after updating to Mylyn 3.0.2 [message #593929 is a reply to message #59267] |
Ok, thank you!
> project properties.
>> ${task.url}
Thank you!
Mauro.
FUDForum. Page generated in 0.05234 seconds
