| Usability around the current task [message #58697] |
Tue, 30 September 2008 03:23  |
Maybe my perspective layout is a bit unusual as my Tasks view is a fast
view.
I wish I'd have a key binding to open the Task editor for the current
task without
going through any intermediary UI like the Tasks view or the Tasks dialog.
Do you think it's worth a Bugzilla?
Another nice feature would be a better feedback about the current task.
For example in the main window title bar the name of the current
perspective is shown.
Do you think it's possible to show the title of the current task in the
window title bar?
Maybe this could be configurable in the preferences...
Cheers
/Eike
| Re: Usability around the current task [message #59364 is a reply to message #59340] |
Thu, 02 October 2008 16:05  |
> Steffen Pingel wrote:
>>> It's a bit strange that it occupies space in the the main tool bar even
>>> if it's *not* switched on throught the prefs.
>> That is one of the usability reasons why the trim is not part of the main
>> distribution, yet. It is related to this bug:
>> 201589: [Contributions] visibleWhen has no effect on toolbar
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=201589
> As far as I remember that issue had been worked around.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=144161
The trim is not hidden until after it has been added to the toolbar and
therefore leaves a blank space (in the top left corner by default). As a
workaround you can enable it, drag it to a different location where it
doesn't affect other toolbars and then disable it. There are ways to fix
that but it would require usage of platform internals.
Steffen
| Re: Usability around the current task [message #593771 is a reply to message #58697] |
Wed, 01 October 2008 17:42  |
> view.
> task without
Yes, certainly. I have wanted that for a while but have been using the trim
widget instead which displays a clickable link with the currently active
task (see below).
> window title bar?
If you install the UI Experiments feature from the incubator update site you
can enable a trim widget that displays the currently active task. Please
file a bug and let us know if you have other ideas such as displaying it in
the window title bar.
Steffen
| Re: Usability around the current task [message #593776 is a reply to message #58992] |
Wed, 01 October 2008 18:08  |
> task (see below).
The trim widget been in the incubator probably for nearly 2 years now.
What is actually preventing from bringing it into the standard UI?
regards,
Eugene
| Re: Usability around the current task [message #593853 is a reply to message #58992] |
Thu, 02 October 2008 04:47  |
Hi Steffen,
The trim widget is exactly what I need!! ;-)
And I couldn't find a key binding...
Thank you for the hint!
/Eike
>> view.
>> task without
> task (see below).
>> window title bar?
> Steffen
| Re: Usability around the current task [message #593862 is a reply to message #59191] |
Thu, 02 October 2008 12:04  |
> even if it's *not* switched on throught the prefs.
You can drag it around. I usually move it into the status bar at the
bottom.
regards,
Eugene
| Re: Usability around the current task [message #593911 is a reply to message #59340] |
Steffen
FUDForum. Page generated in 0.05583 seconds
