Home » Language IDEs » AspectJ » Behavior of PointcutElement.getSource() is very strange
Behavior of PointcutElement.getSource() is very strange [message #58643] Thu, 17 November 2005 01:19 Go to next message
Hi, all
Occasionally, I found the behavior of PointcutElement.getSource() is
very strange. It doesn't return the full source of pointcut expression,
instead, it just returns head of the expression following many blank
space. For example, the resource is:
public pointcut pt3(): execution(public String main.Experiment*.toString())
||execution(public static void main.Hello*.main(String[]))
||execution(public int main.Hello*.testfieldset())
||execution(public void test.pack.Apple*.hello())
||execution(public void test.pack.Apple*.Apple(int))
||execution(public void test.pack.ITestInterface*.methodininterface())
||execution(public void test.pack.GoodApple*.hello());
But the getSource() function will return something as follows:
Is this a bug?
James Gan
Re: Behavior of PointcutElement.getSource() is very strange [message #58712 is a reply to message #58643] Thu, 17 November 2005 09:55 Go to previous message
Hi James,
It's an unfortunate effect of the current AJDT implementation - so as to
not confuse JDT, things like pointcuts pretend to be methods etc. To
obtain the real source you have to make a special call to the containing
compilation unit first. An example of this is in ajdt.ui in
PointcutSourceHover.java line 64. If you need more details, please ask on
the ajdt-dev mailing list.
Matt.
On Thu, 17 Nov 2005 14:19:02 +0800, James Gan wrote:
> Hi, all
> Is this a bug?
> James Gan
Re: Behavior of PointcutElement.getSource() is very strange [message #590962 is a reply to message #58643] Thu, 17 November 2005 09:55 Go to previous message
Hi James,
Matt.
> Hi, all
> Is this a bug?
> James Gan
Previous Topic:How to disable auto-compile AspectJ project in Eclipse 3.1
Next Topic:AspectJ 5 M5
Current Time: Thu Nov 06 22:20:43 EST 2025
Powered by FUDForum. Page generated in 0.02946 seconds
