Home » Language IDEs » AspectJ » How to disable auto-compile AspectJ project in Eclipse 3.1
How to disable auto-compile AspectJ project in Eclipse 3.1 [message #58619] Wed, 16 November 2005 22:45 Go to next message
I have a java project and an AspectJ project in my Eclipse3.1 workspace.
The AspectJ project relies on the Java project. I enabled "build
automatically" for the workspace.
I noticed that when I save changes to .java file in the Java project, the
AspectJ project recompile is automatically triggered. Due to the AspectJ
compiler performance, it takes relatively long to save changes .java
files. It's near a nightmare if I need to extensively change multiple
files.
I'd rather disable the auto-recompile of the AspectJ project when I am
changing code in the java project, and do a clean-build of the AspectJ
project later. Is there a configuration that allows me to achieve this
without change the project dependency setting?
Harry
Re: How to disable auto-compile AspectJ project in Eclipse 3.1 [message #58687 is a reply to message #58619] Thu, 17 November 2005 09:47 Go to previous message
Hi Harry,
No, I don't believe this is possible currently. You would have to turn off
build automatically for all projects, and then manually trigger a build
when required.
Matt.
On Thu, 17 Nov 2005 03:45:55 +0000, Harry Sheng wrote:
> files.
> Harry
Re: How to disable auto-compile AspectJ project in Eclipse 3.1 [message #590951 is a reply to message #58619] Thu, 17 November 2005 09:47 Go to previous message
Hi Harry,
when required.
Matt.
> files.
> Harry
Previous Topic:Behavior of PointcutElement.getSource() is very strange
Next Topic:Behavior of PointcutElement.getSource() is very strange
Current Time: Sun Jul 27 01:41:12 EDT 2025
Powered by FUDForum. Page generated in 0.06393 seconds
