Home » Archived » BIRT » BIRT API
BIRT API [message #58601] Thu, 14 July 2005 23:19 Go to next message
Originally posted by: zszqcym.yahoo.com.cn
hi!
I'm a chinese.I use birt and eclipse .I want to creat a report in
java code.
My question is :How can I write a new *.rptdisign file by bird's
api ?
eg.Write datasource and dataset's property into a *.rpt in java.
Thank you for your help!
Re: BIRT API [message #59219 is a reply to message #58601] Fri, 15 July 2005 21:54 Go to previous message
Greeting,
You could create a report in BIRT API by following the steps in the below.
If you'd like to find out the API docs, please go to Help-> HelpContents
->BIRT Developer Guide->Reference->API Reference -> Report Object Model
API Reference.
Cheers.
Nina Li
Actuate Corporation
createReport( ){
//A session handle to manage all open reports
SessionHandle session = DesignEngine.newSession( null );
//Add a session (A report design handle for this report)
ReportDesignHandle reportDesignHandle = session.createDesign( );
//An element factory for creating all BIRT elements
ElementFactory elementFactory = designHandle.getElementFactory( );
//create the necessary elements for the reports
createMasterPages( );
createDataSources( );
createDataSets( );
createReportBody( );
...Output the report...
reportDesignHandle.saveAs( ... + "*.rptdesign" );
createMasterPage(){
//A design element handle for managing the Master page
DesignElementHandle masterPage = elementFactory.newSimpleMasterPage(
"Master Page" );
//Add the master page into the report
reportDesignHandle.getMasterPages( ).add( masterPage );
createDataSources( ){
//A script data source handle for managing the data source
ScriptDataSourceHandle dataSourceHandle =
elementFactory.newScriptDataSource("Data source");
...Set the property of data source...
//Add the data source into the report
reportDesignHandle.getDataSources( ).add( dataSourceHandle );
createDataSets( ){
//A script data set handle for managing the data set
ScriptDataSetHandle dataSetHandle = elementFactory.newScriptDataSet("Data
set");
...Set the property of data set...
//Add the data set into the report
reportDesignHandle.getDataSets( ).add( datasetHandle );
createReportBody( ){
//Create the contents of report
createGrid( );
createTable();
createLabel();
Previous Topic:Mailing Labels with BIRT?
Next Topic:importPackage does not work
Current Time: Sun Nov 02 09:27:27 EST 2025
Powered by FUDForum. Page generated in 0.04007 seconds
