Home » Eclipse Projects » Equinox » running serverside OSGI in mutlipe web container
running serverside OSGI in mutlipe web container [message #58589] Thu, 26 January 2006 20:02 Go to next message
I tried installing two serverside bridge.war files each with their own
path and context to see if more than one web container could run
serverside OSGI (on the assumptions that two different applications wanted
to use this on the same server).
The first war to be deployed (under Tomcat) OK. The second had some
exceptions thrown. I think I ended up with OSGI running in each container
but one was crippled. It was hard to tell because you only have access to
a single console. My URL's for each container could run the sp_* contro
URL's. The sample extension servlet ran OK in the WAR that deployed
successfully but got a 404 in the other.
Is this a result of the issues described in bug 121472? Is so, is there an
outlook for availability of a fix?
Thanks...Jim
Re: running serverside OSGI in mutlipe web container [message #58639 is a reply to message #58589] Thu, 26 January 2006 20:49 Go to previous message
Originally posted by: skaegi.sympatico.ca
Hi Jim,
Yep, sounds like the problem in bug 121472 (and also 105851 if you're not
running off of HEAD)
I'm working on it right now.
....maybe an early patch this weekend we'll see.
-Simon
"Jim D'Anjou" <danjou@us.ibm.com> wrote in message
news:6be2b2910a351da8d3d4a08acfded63e$1@www.eclipse.org...
> Thanks...Jim
Previous Topic:Is there a reference for all the console commands? <eom>
Next Topic:Problem using UserAdmin
Current Time: Thu Nov 06 23:03:50 EST 2025
Powered by FUDForum. Page generated in 0.03258 seconds
