| SWT with Visual Editor [message #58535] |
Wed, 27 April 2005 15:02  |
Originally posted by: esirko.sw-sol.com
Can someone confirm for me that the Visual Editor cannot be used to develop
SWT applications?
Thanks.
| Re: SWT with Visual Editor [message #59063 is a reply to message #58738] |
Thu, 28 April 2005 10:45  |
"Jeff Myers" <myersj@nospam.gmail.com> wrote in message
news:d4pfqp$lot$1@news.eclipse.org...
> Eric W. Sirko wrote:
>> Well, the palette contains plenty of AWT and Swing controls, but nada in
>> the way of SWT. How does this SWT support manifest itself?
>> Eric
> In the New Visual Class wizard, select a class in the SWT group as the
> starting point, or bring up the properties of your Java project, select
> the Java Build Path page, the Libraries tab, hit Add Library... and select
> SWT Library. The SWT palette options only show up when the SWT Library is
> added to the project. Selecting a SWT starting point in the New Visual
> Class wizard will do this for you.
> Hope this helps,
> - Jeff
Hey you're right. I had added the SWT jar file using the Add JARs button
instead of the Add Library button. Apparently that wasn't good enough.
Thanks!
FUDForum. Page generated in 0.08264 seconds
