Home » Archived » Test and Performance Tools Platform (TPTP) » Far out behaviour of AGR
Far out behaviour of AGR [message #58527] Wed, 15 March 2006 10:55 Go to next message
Originally posted by: tom.andersson.accenture.com
Hi. Back with some problems..
For some reason AGR fails to input data to my textfields. I wrote some
tests and everything worked fine. Then I recorded another testcase. The
result was that this new testcase didn't get listed in the 'Test cases'
-tab. It was shown in the 'Examine macro' -tab though. I saved and
reloaded the testsuite after which the testcase was shown.
After this, my previously recorded tests just broke. They don't seem to be
able to insert numeric values to textfields properly. For example the code
below does nothing:
<command type="modify" contextId="view/myapp.SearchView"
widgetId="org.eclipse.swt.widgets.Text#1">123</command>
Same thing if i wrap the value inside a CDATA -block.
Then again if i use '12.3' as the value, '.3' gets inserted to the
textfield.
'12345a123' becomes 'a123'.
I tried reverting all my testcases and project files and also tried with a
clean eclipse but it just wont work anymore. Dont know if these things are
related, seems just weird. I'm using a version from the end of January
though so I guess I should try with a newer version. Also moving to use
3.2M5 soon.. but anyway, just FYI :)
Not taking these issues into account, AGR and TPTP in general have been
very useful, hopefully you will continue to make it better.
Tom
Re: Far out behaviour of AGR [message #61097 is a reply to message #58527] Tue, 28 March 2006 09:54 Go to previous message
Hi Tom,
The numeric input was a defect that I fixed in a later build. Please try
out a newer build.
Thanks.
"Tom Andersson" <tom.andersson@accenture.com> wrote in message
news:fe8cfb2dbed0fd7c74692cbf90fe1ee4$1@www.eclipse.org...
> below does nothing:
> textfield.
> Cheers,
> Tom
Previous Topic:java.lang.NoClassDefFoundError: org/eclipse/hyades/logging/events/cbe/SituationType
Next Topic:Running Automated GUI Recorder Tests In Sequence
Current Time: Tue Nov 11 09:07:29 EST 2025
Powered by FUDForum. Page generated in 0.03784 seconds
