Home » Archived » Visual Editor (VE) » Eclipse VE just crashed
Eclipse VE just crashed [message #58517] Wed, 01 September 2004 20:13 Go to next message
Originally posted by: dmiller.mcleancargo.com
Has anyone else had problems with ve crapping on the code ... lets say your
editing a title for a jpanel, and you accept the changes. Then elipse makes
the changes to the source where it DELETES some random code and dump the
code that should have been generated for the jpanel you just changed, into
a totaly random area?
ive had this propblem with many different builds of ve.
i always start with a clean install using the builds of gef emf and eclipse
that are linked on the download page for any given version of ve.
its very frustrating to have to repair a big hunk of grid bag constraints
that just got pooped in by the ve. lets say this message is my source that
im working on with ve. this is what i mean by "pooped in"
/******************* Pooped code
tall using the builds of gef emf and eclipse that are linked on the
downloa
dump the code that should have been generated for the jpanel you just
changed, into a totaly
i always start with a install using the builds of gef emf and eclipse that
asdc re linked on the download page for any given version of ve.
frustrating to have to repair a big hunk of grid constraints that just
got pooped in by the ve. lets say this message is my source that im wor
random area? "pooped in"bag its veryc lean
/****** end pooped code
Re: Eclipse VE just crashed [message #58540 is a reply to message #58517] Thu, 02 September 2004 01:52 Go to previous messageGo to next message
Originally posted by: elvis_dowson.hotmail.com
I've had this random behaviour with the Java Editor, for a non-visual
java classes. It keeps happening when I try to copy/paste text. It messes up
the entire java source file. Sometimes, clicking on the undo option can
recover from the mess, but its happened quite frequently.
I haven't worked extensively with VE, but I have observed a similar
behaviour using the java editor.
Elvis Dowson
Here is my installation configuration :
- Eclipse 3.0 full install with EMF 2.0.0 and GEF 3.0.0 SDKs release builds
- VE 1.0M2
- Omondo EclipseUML plug-in
(eclipseUML_300_studioEdition-installer_1.0.0.20040719)
- FeeMem 1.0.0 plug-in ( Freemem not acively enabled in a view. )
- Sysdeo Tomcat PluginV3 ( Tomcat disabled )
"Derek" <dmiller@mcleancargo.com> wrote in message
news:ch5o73$dlt$1@eclipse.org...
your
makes
eclipse
your
makes
> downloa
just
eclipse that
that just
wor
Re: Eclipse VE just crashed [message #58563 is a reply to message #58517] Thu, 02 September 2004 06:07 Go to previous messageGo to next message
Hi Derek,
Do you have a repeatable scenario that exhibts this behavior ? Could
you please give as much information as possible about what steps to use
to re-create this so we can try to re-create it and create a fix ?
Also - please enter a bugzilla severe defect against this with as much
information as possible to allow us to see the problem - that way you
can track the defect's progress more easily than on the newsgroup.
Joe Winchester
Re: Eclipse VE just crashed [message #58613 is a reply to message #58563] Thu, 02 September 2004 12:03 Go to previous message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Also please append the .log file. There may be some info in there for us.
Thanks, Rich Kulp
Re: Eclipse VE just crashed [message #598108 is a reply to message #58517] Thu, 02 September 2004 01:52 Go to previous message
Elvis Dowson
- VE 1.0M2
your
makes
eclipse
your
makes
> downloa
just
eclipse that
that just
wor
Re: Eclipse VE just crashed [message #598114 is a reply to message #58517] Thu, 02 September 2004 06:07 Go to previous message
Hi Derek,
Joe Winchester
Re: Eclipse VE just crashed [message #598130 is a reply to message #58563] Thu, 02 September 2004 12:03 Go to previous message
Thanks, Rich Kulp
Previous Topic:Problem Installing VE plugin
Next Topic:How do I use the VE-examples-1.0M2.zip provided by VE
Current Time: Tue Nov 18 20:05:47 EST 2025
Powered by FUDForum. Page generated in 0.05246 seconds
