Home » Archived » XML Schema Definition (XSD) » Multiple inheritance in EMF -> XSD
Multiple inheritance in EMF -> XSD [message #58474] Thu, 10 March 2005 10:32 Go to next message
Originally posted by: h.u.com
I have a task of converting an EMF Ecore model into XSD. I've looked into
using the EcoreXMLSchemaBuilder and I see that when it encounters multiple
inheritance in the ecore model, it takes the first superclass and creates an
extension. I have included the code that I found in the processClass method
of this utility.
if (superClasses.size() > 0)
xsdComplexTypeDefinition.setDerivationMethod(XSDDerivationMe thod.EXTENSION_LITERAL);
EClass superClass = (EClass)superClasses.get(0);
if (superClass.getEPackage() == ePackage)
xsdComplexTypeDefinition.setBaseTypeDefinition(xsdSchema.res olveTypeDefinition(getName(superClass)));
else
xsdComplexTypeDefinition.setBaseTypeDefinition(typeInOtherSc hema(superClass));
I understand that there is no formal structure for multiple inheritance in
XSD. Would it be possible to use named model groups for each of the multiple
superclasses, and let the subclass refer to both named groups? Are there any
elegant widely accepted ways to model this type of structure in XSD?
Hayden Marchant
Re: Multiple inheritance in EMF -> XSD [message #58479 is a reply to message #58474] Thu, 10 March 2005 12:31 Go to previous messageGo to next message
Hayden,
The problem of expressing multiple inheritance in XML Schema is
basically unsolvable. One could generate and use model groups (and
attribute groups) to reduce duplication of features, but xsi:type
substitutability will still be broken. You'd need to be especially
careful about diamond inheritance, i.e, that it doesn't result in
duplication...
>of this utility.
> else
>Thanks,
>Hayden Marchant
Re: Multiple inheritance in EMF -> XSD [message #58483 is a reply to message #58479] Fri, 11 March 2005 06:32 Go to previous message
that what I thought - I was just hoping for a bit of a miracle. OK, I
suppose I'll have set the expectations low for Multiple-inheritance in XSD
then :(
Hayden
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:d0q09f$62o$1@www.eclipse.org...
> Hayden,
> The problem of expressing multiple inheritance in XML Schema is basically
> unsolvable. One could generate and use model groups (and attribute
> groups) to reduce duplication of features, but xsi:type substitutability
> will still be broken. You'd need to be especially careful about diamond
> inheritance, i.e, that it doesn't result in duplication...
>>an extension. I have included the code that I found in the processClass
>>method of this utility.
>> else
>> in XSD. Would it be possible to use named model groups for each of the
>> multiple superclasses, and let the subclass refer to both named groups?
>> Are there any elegant widely accepted ways to model this type of
>> structure in XSD?
>>Thanks,
>>Hayden Marchant
Re: Multiple inheritance in EMF -> XSD [message #594436 is a reply to message #58474] Thu, 10 March 2005 12:31 Go to previous message
Hayden,
duplication...
>of this utility.
> else
>Thanks,
>Hayden Marchant
Re: Multiple inheritance in EMF -> XSD [message #594462 is a reply to message #58479] Fri, 11 March 2005 06:32 Go to previous message
then :(
Hayden
> Hayden,
>> else
>> structure in XSD?
>>Thanks,
>>Hayden Marchant
Previous Topic:Preferences: XML Catalog - problem with relative schemaLocation's
Next Topic:Preferences: XML Catalog - problem with relative schemaLocation's
Current Time: Wed Nov 05 10:12:24 EST 2025
Powered by FUDForum. Page generated in 0.04327 seconds
