Home » Modeling » M2T (model-to-text transformation) » de.itemis.xtext.antlr breaks
de.itemis.xtext.antlr breaks [message #58464] Sat, 14 March 2009 20:29 Go to next message
Latest mwe, xpand and xtext breaks with incompatibility with the
de.itemis.xtext.antlr plugin.
Would someone please post an update to the new parser?
Here's the output...
0 [main] INFO eclipse.emf.mwe.core.WorkflowRunner -
20 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - EMF Modeling
Workflow Engine 0.7.0, Build v200903110130
21 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - (c) 2005-2009
openarchitectureware.org and contributors
21 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - running workflow:
org/batoo/ui/forms/GenerateModel.mwe
602 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - [ERROR]: Class not
found: 'de.itemis.xtext.antlr.XtextAntlrGeneratorFragment'(Element: bean
fragment class='de.itemis.xtext.antlr.XtextAntlrGeneratorFragment' in
org/eclipse/xtext/generator/StandardRuntimeFragments.mwe:4; Reported by: -
UNKNOWN-)
602 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - Workflow
interrupted because of configuration errors.
Hasan Ceylan
Re: de.itemis.xtext.antlr breaks [message #58475 is a reply to message #58464] Sun, 15 March 2009 10:19 Go to previous messageGo to next message
Nevermind, got it. Fo the record for the other users, it is on oaw
sourceforge site...
Hasan Ceylan wrote:
> Hello,
> not found: 'de.itemis.xtext.antlr.XtextAntlrGeneratorFragment'(Element:
> bean fragment class='de.itemis.xtext.antlr.XtextAntlrGeneratorFragment' in
> UNKNOWN-)
> Hasan Ceylan
Re: de.itemis.xtext.antlr breaks [message #58573 is a reply to message #58475] Mon, 16 March 2009 16:47 Go to previous messageGo to next message
Hi Hasan,
I'll crosspost your solution to the TMF newsgroup.
If you have any further questions, please don't hesitate to ask us.
Sebastian
> sourceforge site...
> Hasan Ceylan wrote:
>> Hello,
>> UNKNOWN-)
>> Thanks,
>> Hasan Ceylan
Re: de.itemis.xtext.antlr breaks [message #58620 is a reply to message #58573] Tue, 17 March 2009 02:27 Go to previous messageGo to next message
Thx...
Sebastian Zarnekow wrote:
> Hi Hasan,
> Sebastian
>> sourceforge site...
>> Hasan Ceylan wrote:
>>> Hello,
>>> workflow: org/batoo/ui/forms/GenerateModel.mwe
>>> in org/eclipse/xtext/generator/StandardRuntimeFragments.mwe:4; Reported
>>> by: - UNKNOWN-)
>>> Thanks,
>>> Hasan Ceylan
Re: de.itemis.xtext.antlr breaks [message #58692 is a reply to message #58620] Tue, 17 March 2009 12:05 Go to previous messageGo to next message
I checked out the de.itemis.xtext.antlr Plugin from
http://architecturware.cvs.sourceforge.net/viewvc/architectu rware/xtext_external/de.itemis.antlr.xtext.updatesite/plugin s/
and placed it in my dropins folder. Generating artifacts reports an
attention.
4531 [main] WARN nerator.DelegatingGeneratorFragment - ---- ATTENTION
4531 [main] WARN nerator.DelegatingGeneratorFragment - You are
generating without ANTLR. If this was not desired, please install the
missing plugin 'de.itemis.xtext.antlr'.
How can I configure Xtext to use the ANTLR Parser?
ILyas
Re: de.itemis.xtext.antlr breaks [message #58716 is a reply to message #58620] Tue, 17 March 2009 12:38 Go to previous messageGo to next message
attention.
ILyas
Re: de.itemis.xtext.antlr breaks [message #59039 is a reply to message #58692] Sun, 22 March 2009 17:43 Go to previous message
Ilyas,
What I did was to check out
de.artemis.xtext.antlr
de.artemis.xtext.antlr.feature
org.antlr
into workspace and export the feature to main platform.
I think it should still be OK to have them in your workspace, but my guess
is that you are missing org.antlr . The org.antlr plugin comes from
eclipse.org has a dummy implementation in it so the plugin from the sf.net
should override it.
Hope this helps,
Hasan
Ilyas Keser wrote:
> attention.
> Thanks
> ILyas
Previous Topic:Sample Workflow for Eclipse MWE
Next Topic:UML2 to Java class without any ECore dependencies
Current Time: Mon Oct 27 22:14:26 EDT 2025
Powered by FUDForum. Page generated in 0.08023 seconds
