Home » Eclipse Projects » Eclipse Platform » Different Worspaces with different plugins
Different Worspaces with different plugins [message #58444] Mon, 02 June 2003 02:59 Go to next message
Hello
is it possible to start Eclipse with different workspaces which have
different sets of plugins? For example: if I need Eclipse for writing
XML-docs I don't need the Java-related plugins and vice versa.
I start Eclipse with the links-folder for the plugins.
regards
Michael
Re: Different Worspaces with different plugins [message #58457 is a reply to message #58444] Mon, 02 June 2003 03:15 Go to previous messageGo to next message
Originally posted by: stelian.iancu.gmxREMOVE.net
For different workspaces, try starting eclipse with the -data parameter. Eg.
c:\eclipse\eclipse.exe -data c:\workspace1
c:\eclipse\eclipse.exe -data c:\workspace2
etc.
Stelian Iancu
"Michael" <Michael.Trompertz@FeltenGmbH.de> wrote in message
news:bbeskc$vta$1@rogue.oti.com...
> Hello
> regards
> Michael
Re: Different Worspaces with different plugins [message #58603 is a reply to message #58457] Mon, 02 June 2003 04:19 Go to previous messageGo to next message
Thanks for your answer.
But it was not my intention do use different workspaces (I use them, one
for XML, one for Java...). I want to have a different set of plugins for
each workspace. Something like
c:\eclipse\eclipse.exe -data c:\workspace1 -plugin c:\pluginDirectory1
c:\eclipse\eclipse.exe -data c:\workspace2 -plugin c:\pluginDirectory2
Michael
> etc.
> Stelian Iancu
> > Hello
> > regards
> > Michael
Re: Different Worspaces with different plugins [message #58701 is a reply to message #58603] Mon, 02 June 2003 04:32 Go to previous messageGo to next message
Originally posted by: stelian.iancu.gmx.net
On Mon, 2 Jun 2003 08:19:37 +0000 (UTC), Michael
> each workspace. Something like c:\eclipse\eclipse.exe -data c:\workspace1
> Michael
I guess that, after you start Eclipse, you can go to the Install/Update
Perspective and disable all the features that you don't need.
Stelian Iancu
Linux Registered User 287835
Be different. Think.
Re: Different Worspaces with different plugins [message #58775 is a reply to message #58444] Mon, 02 June 2003 06:25 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
I don't think you can. But what's the point? If you organize your work so
that each workspace only uses a given set of plugins, the others won't be
loaded anyway.
Bob
> Hello
> regards
> Michael
Re: Different Worspaces with different plugins [message #58952 is a reply to message #58775] Mon, 02 June 2003 08:45 Go to previous messageGo to next message
It's not really a problem. But there are menues and other things I don't
need. And I am not sure about startup time and memory footprint. I think
it's better if only few plugins are loaded.
Michael
> loaded anyway.
> Bob
> > Hello
> > regards
> > Michael
Re: Different Worspaces with different plugins [message #59129 is a reply to message #58603] Mon, 02 June 2003 09:51 Go to previous messageGo to next message
See http://bugs.eclipse.org/bugs/show_bug.cgi?id=36101 for a patch and
some of the 3.0 plan items.
BTW, the 2.1 code still has -plugin as a leftover. You need to point
it to a dir containing the plugin.xml (IIRC...). See
PlatformConfiguration.java in org.eclipse.core.boot (again IIRC..) for
the details...
Jan
Re: Different Worspaces with different plugins [message #59153 is a reply to message #58775] Mon, 02 June 2003 09:54 Go to previous messageGo to next message
> loaded anyway.
On unix there is also a different usecase: You don't have write
access to the dir containing the eclipse installation. So you
need to handle additional plugins at startup time, which isn't
possible just now (just with a crude hack, which is a leftover
from 1.0 or the patch, which the debian packages use).
-addsite patch:
Jan
Re: Different Worspaces with different plugins [message #59173 is a reply to message #58952] Mon, 02 June 2003 10:40 Go to previous messageGo to next message
> Michael
Eclipse will only load plugins that are accessed. This means that
although the menu items show up, the plugin behind those items isn't
loaded until you select the item. By customizing the perspectives, you
can add and remove many menu items to set things up the way you like them.
I'm curious why you need separate workspaces. A single workspace can
handle multiple projects. You can create custom perspectives to organize
views the way you want them. You can also open multiple windows and use
filters to achieve a multi-workspace kind of feel.
> > loaded anyway.
> > Bob
> > > Hello
> > > regards
> > > Michael
Re: Different Worspaces with different plugins [message #59790 is a reply to message #58952] Mon, 02 June 2003 17:04 Go to previous message
Originally posted by: Kevin.clark.accessbc.com.nospam
Michael,
Everyone is correct by saying that Eclipse doesn't load those plug-ins
until you access them... But if you -really- want separate plug-ins, there
is a solution: Install two Eclipse instances on the same computer. Then
you can add whatever plug-ins you want to the individual instances.
Or you can wait until 3.0. :-)
Kevin
> Michael
> > loaded anyway.
> > Bob
> > > Hello
> > > regards
> > > Michael
Previous Topic:CVS branch
Next Topic:Blue-screen on WinXP after premature halt of runtime-eclipse
Current Time: Thu Nov 06 06:48:43 EST 2025
Powered by FUDForum. Page generated in 0.07936 seconds
