Home » Eclipse Projects » Mylyn » Mylyn 3.0.2 and org.eclipse.mylyn.web.core?
Mylyn 3.0.2 and org.eclipse.mylyn.web.core? [message #58431] Fri, 26 September 2008 08:37 Go to next message
The place where I work uses RT for for bug tracking, and doing a search
turns up:
http://sourceforge.net/projects/mylyn-rt/
The problem I have is that it depends on org.eclipse.mylyn.web.core, which
does not seem to be available for 3.0.2. Was this dropped or how do I
install it? If it was dropped are there any instructions on how to migrate
a connector to work with 3.0.2?
Andre
Re: Mylyn 3.0.2 and org.eclipse.mylyn.web.core? [message #58510 is a reply to message #58431] Fri, 26 September 2008 16:28 Go to previous message
You can probably use the connector with Mylyn 2.3.2 which is available from
the download page:
http://www.eclipse.org/mylyn/
If you are interested in porting the source code of the connector to the
latest Mylyn version take a look at this porting guide:
http://wiki.eclipse.org/Mylyn/Porting_Guide/3.0
Steffen
Andre John Mas wrote:
> turns up:
> Andre
Re: Mylyn 3.0.2 and org.eclipse.mylyn.web.core? [message #593532 is a reply to message #58431] Fri, 26 September 2008 16:28 Go to previous message
the download page:
Steffen
> turns up:
> Andre
Previous Topic:Upgrading Eclipse 3.3 to Mylyn 2.3?
Next Topic:Losing context with Mylyn 2.3.2
Current Time: Fri Nov 07 10:29:42 EST 2025
Powered by FUDForum. Page generated in 0.25247 seconds
