[ATL] Running an ANT file with java [message #58327] |
Fri, 17 August 2007 12:01  |
Hello everybody,
I don't know if this newsgroup is the correct place to post my problem, but
I will try.
I have an ANT script (build.xml) that executes several ATL transformations.
I want to run that build.xml file from java, but I don't know how. I have
tried with:
Process proce = Runtime.getRuntime().exec("cmd /c
"+ant_home+"/bin/ant -buildfile
c:/eclipse3.3/runtime-New_configuration/Plugin/src/plugin/po pup/actions/build.xml ");
InputStream is = proce.getInputStream();
BufferedReader br = new BufferedReader (new InputStreamReader (is));
String aux = br.readLine();
while (aux!=null)
}catch(Exception e){
System.out.println("Error: "+e.getMessage());
The problem is that only the first sentence in the ANT file is executed, but
not all the script. Why?
Any idea?
Thank you very much in advance
Bea
FUDForum. Page generated in 0.05054 seconds
