Home » Language IDEs » C / C++ IDE (CDT) » Code Completion on W2K
Code Completion on W2K [message #58320] Thu, 16 January 2003 09:00 Go to next message
Originally posted by: dd.oal.com
I'm currently working on a C++ project; here is my development environment:
Eclipse 2.1 (build 200212181304)
CDT 1.0.1-F1
OS: Windows 2000
The sources are accessed through Clearcase Dynamic Views by a NFS mount.
The sources a pretty large.
My problem is that I can't use code completion.
I tried Exuberant ctags and cygwin ctags: same problem:
(*) Ctrl+Space doesn't work (but Edit > Code Assist does!!?? - Key
binding seems to be alright)
(*) Eclipse runs very slowly
(*) After 2 minutes editing, it runs "out of memory"
I searched such problems in the archives and some posts talked about "Parser
Include Path" and "Parsing level".
But I can't find thoses properties.
Any help would be wellcome!
Thanx
David
Re: Code Completion on W2K [message #58655 is a reply to message #58320] Fri, 17 January 2003 02:36 Go to previous messageGo to next message
Originally posted by: g.wagenknecht.intershop.de
"David" <dd@oal.com> schrieb im Newsbeitrag
news:b06cus$411$1@rogue.oti.com...
This is a known bug in Eclipse.
You should start Eclipse passing VM arguments to allow the VM to use more
memory.
Cu, Gunnar
Re: Code Completion on W2K [message #58679 is a reply to message #58655] Fri, 17 January 2003 04:24 Go to previous messageGo to next message
I used -Xms arg and it seems to be much better....but....
is it possible to the content assist tool to be context sensitive?
For example, on "this->", could it show me only members of the related class
of "this"?
Actualy, when I use content assist, it shows me ALL the matching method
members of ALL the classes it knows about.
My sources are so large that in much cases, it is not helpfull (too many
proposals).
Any idea?
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> a
Re: Code Completion on W2K [message #61066 is a reply to message #58679] Mon, 03 February 2003 19:56 Go to previous message
Originally posted by: alain.no.spam
David wrote:
> of "this"?
> proposals).
> Any idea?
None.
You will have to wait for a more complete C/C++ parser in the CDT
To be able to do
joe->... code_completion
we need to parse the line to figure out what is joe?
and then where is joe define? which can be in some headers
outside of eclipse workspace sigh ... (C++ is such an ugly lang 8)
For now, what you see is only the list of symbols discovered
from ctags.
For the "run out mem" it maybe due to the fact that you
have large projects and the indexer is using a large amount
to hold the symbol tables(in mem).
Disable indexing from the project property, that may also help.
> "Gunnar Wagenknecht" <g.wagenknecht@intershop.de> a écrit dans le message
> news: b08apl$d06$1@rogue.oti.com...
> > memory.
> > Cu, Gunnar
Previous Topic:Disabling thread info on each step
Next Topic:C++ parser stability & completeness
Current Time: Mon Jul 21 22:17:59 EDT 2025
Powered by FUDForum. Page generated in 0.03863 seconds
