SuSE 8.2 intall problem [message #58318] |
Sun, 01 June 2003 19:07  |
Originally posted by: avolovoy.kc.rr.com
Hi all, I'm trying to install Eclipse 2.1 on Suse 8.2 with
Sun 1.4.1_02 JDK. I've downloaded gtk version and i've got the
following error in the log file everytime i'm trying to start
eclipse
I'm not sure what i'm doing wrong, I'm just starting with linux..
!SESSION May 31, 2003 14:04:36.00
java.version=1.4.1_02
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86 -install
file:/home/shared/eclipse/
!ENTRY org.eclipse.core.runtime 2 1 May 31, 2003 14:04:36.02
!MESSAGE Problems encountered loading the plug-in registry.
!SUBENTRY 1 org.eclipse.core.runtime 2 1 May 31, 2003 14:04:36.03
!MESSAGE Parsing error in "plugin.xml" [line -1, column -1]: "Premature end
of file.".
!STACK 0
org.xml.sax.SAXParseException: Premature end of file.
org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseExc eption(ErrorHandlerWrapper.java:232)
org.apache.xerces.util.ErrorHandlerWrapper.fatalError(ErrorH andlerWrapper.java:213)
org.apache.xerces.impl.XMLErrorReporter.reportError(XMLError Reporter.java:366)
org.apache.xerces.impl.XMLErrorReporter.reportError(XMLError Reporter.java:296)
at org.apache.xerces.impl.XMLScanner.reportFatalError(XMLScanne r.java:1244)
org.apache.xerces.impl.XMLDocumentScannerImpl$XMLDeclDispatc her.dispatch(XMLDocumentScannerImpl.java:590)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(XMLDocumentFragmentScannerImpl.java:333)
org.apache.xerces.parsers.StandardParserConfiguration.parse( StandardParserConfiguration.java:525)
org.apache.xerces.parsers.StandardParserConfiguration.parse( StandardParserConfiguration.java:581)
at org.apache.xerces.parsers.XMLParser.parse(XMLParser.java:147 )
org.apache.xerces.parsers.AbstractSAXParser.parse(AbstractSA XParser.java:1158)
org.eclipse.core.internal.plugins.PluginParser.parsePlugin(P luginParser.java:472)
org.eclipse.core.internal.plugins.RegistryLoader.processMani festFile(RegistryLoader.java:89)
org.eclipse.core.internal.plugins.RegistryLoader.processPlug inPathFile(RegistryLoader.java:136)
org.eclipse.core.internal.plugins.RegistryLoader.processPlug inPathEntry(RegistryLoader.java:127)
org.eclipse.core.internal.plugins.RegistryLoader.processMani festFiles(RegistryLoader.java:104)
org.eclipse.core.internal.plugins.RegistryLoader.parseRegist ry(RegistryLoader.java:63)
org.eclipse.core.internal.plugins.RegistryLoader.parseRegist ry(RegistryLoader.java:71)
org.eclipse.core.internal.runtime.InternalPlatform.parsePlug ins(InternalPlatform.java:779)
org.eclipse.core.internal.runtime.InternalPlatform.loadRegis try(InternalPlatform.java:723)
org.eclipse.core.internal.runtime.InternalPlatform.loaderSta rtup(InternalPlatform.java:574)
org.eclipse.core.internal.boot.InternalBootLoader.startup(In ternalBootLoader.java:1011)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:838)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Re: SuSE 8.2 intall problem [message #60108 is a reply to message #58318] |
Tue, 03 June 2003 04:08   |
Originally posted by: anders_biehl.yahoo.com
I really don't know what's wrong - but just looking at the errormsg....
maybe one of your plugin.xml files are corrupt - you could try to dl the
eclipse package again. Or just reinstall eclipse from your current zip-file.
Or hope that some shell-wizard can zip up his plugin.xml, and post them here
for you to try.
Hope i was to any help
Anders
"Alexey Volovoy" <avolovoy@kc.rr.com> wrote in message
news:bbe0uv$jhm$1@rogue.oti.com...
> eclipse
end
> of file.".
> !STACK 0
> at
> at
va:213)
> at
6)
> at
6)
> at
> at
> at
> at
> at
> at
8)
> at
:472)
> at
yLoader.java:89)
> at
tryLoader.java:136)
> at
> at
ryLoader.java:104)
> at
r.java:63)
> at
r.java:71)
> at
form.java:779)
> at
form.java:723)
> at
tform.java:574)
> at
> at
..java:25)
> at
..java:1011)
> at
a:838)
> at
> at
..java:25)
Re: SuSE 8.2 intall problem [message #61622 is a reply to message #60108] |
Tue, 03 June 2003 19:02  |
Yes, I think I'll try to download again, cause i saw people
intalling it uder suse 8.1 withot nay problems ..
Anders Biehl wrote:
> zip-file. Or hope that some shell-wizard can zip up his plugin.xml, and
> post them here for you to try.
> Anders
>> eclipse
> end
>> of file.".
>> !STACK 0
>> at
>> at
> va:213)
>> at
> 6)
>> at
> 6)
>> at
>> at
>> at
>> at
>> at
>> at
> 8)
>> at
> :472)
>> at
> yLoader.java:89)
>> at
> tryLoader.java:136)
>> at
>> at
> ryLoader.java:104)
>> at
> r.java:63)
>> at
> r.java:71)
>> at
> form.java:779)
>> at
> form.java:723)
>> at
> tform.java:574)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
> .java:25)
>> at
> .java:1011)
>> at
> a:838)
>> at
>> at
> .java:25)
FUDForum. Page generated in 0.03380 seconds
