InactiveProcessException when starting TPTP JUnit Plugin [message #58298] |
Wed, 15 March 2006 02:20  |
I have followed the guide for creating a TPTP JUnit Plugin test that is
located
at:
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. hyades.test.doc.user/concepts/cintro.htm
Finnaly I click on the testsuite file and select Run As -> Run..., and then
select the test suite and the deployment. When I click on the Run button a
progress monitor is shown wiht the task "Preparing and deploying". But the
task never ends - the following exception is thrown:
org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:417)
org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:2058)
org.eclipse.hyades.execution.harness.TestExecutionHarness.ac cess$2(TestExecutionHarness.java:1856)
org.eclipse.hyades.execution.harness.TestExecutionHarness$2. run(TestExecutionHarness.java:692)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
The session data of the exception is:
eclipse.buildId=I20051215-1506
java.version=1.5.0_05
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=bg_BG
Command-line arguments: -data /home/kiril/work/workspace -os linux -ws gtk
-arch x86
I use eclipse3.2M5 and I have downloaded
http://www.eclipse.org/tptp/home/downloads/drops/TPTP-4.2.0- 200603140100.html
I use a remote Agent Controler.
FUDForum. Page generated in 0.09593 seconds
