Home » Eclipse Projects » Nebula » GridViewer - EditorActivationStrategy per Column
GridViewer - EditorActivationStrategy per Column [message #58224] Thu, 21 August 2008 11:11 Go to next message
Originally posted by: sf.tragwerk-software.de
I want to set different CellEditors for each Column in a Grid.
How can I specify an ActivationStrategy for each CellEditorType ?
E.g. an TextCellEditor should be triggered by any KeyStroke, but an
ComboEditor only on DoubleClick.
Sebastian
Re: GridViewer - EditorActivationStrategy per Column [message #58249 is a reply to message #58224] Thu, 21 August 2008 16:28 Go to previous messageGo to next message
I don't see any chance to make this happen with the current JFace-API.
Could you please file a bugzilla and CC'me?
Tom
Sebastian Fuchs schrieb:
> Thanks
> Sebastian
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: GridViewer - EditorActivationStrategy per Column [message #58274 is a reply to message #58249] Fri, 22 August 2008 03:57 Go to previous message
Tom,
I wrote an ColumnViewerEditorActivationStrategy which
delegates
isEditorActivationEvent(ColumnViewerEditorActivationEvent event)
to the EditorActivationStrategy of the matching column.
Unfortunately
is protected, so I had to write my own Interface which declares a method
with the same intention.
So all in all, it works. Nervertheless I opened
https://bugs.eclipse.org/bugs/show_bug.cgi?id=244918
Sebastian
Tom Schindl schrieb:
> Tom
>> Thanks
>> Sebastian
Re: GridViewer - EditorActivationStrategy per Column [message #591899 is a reply to message #58224] Thu, 21 August 2008 16:28 Go to previous message
Tom
> Thanks
> Sebastian
Re: GridViewer - EditorActivationStrategy per Column [message #591912 is a reply to message #58249] Fri, 22 August 2008 03:57 Go to previous message
Tom,
delegates
Unfortunately
Sebastian
> Tom
>> Thanks
>> Sebastian
Previous Topic:GridViewer - EditorActivationStrategy per Column
Next Topic:Header Font does not repaint properly
Current Time: Tue Nov 18 20:44:55 EST 2025
Powered by FUDForum. Page generated in 0.04014 seconds
