Home » Archived » BIRT » XML as DataSource for BIRT Reports
XML as DataSource for BIRT Reports [message #58163] Thu, 14 July 2005 04:04
Originally posted by: shajee.gmail.com
I wanted to know if it's possible to provide some XML data in form of a
xml file or as xml stream which would serve as datasource to a Birt report.
I have this final xml generated which get's it data from some different
datasource(SQL Server). What i want to do is send this xml to BIRT engine
where i can format the xml data to generate a presentable report.
Also is it possible to translate/generate xml/html from a birt report.
Shajee
Previous Topic:StockEntry not found
Next Topic:Linking chart by parameter causes error when a NULL param value is reached
Current Time: Wed Oct 29 19:35:12 EDT 2025
Powered by FUDForum. Page generated in 0.02999 seconds
