Home » Modeling » M2T (model-to-text transformation) » Formatting text
Formatting text [message #58137] Tue, 10 March 2009 15:48 Go to next message
Hi all,
Is it possible to use java.lang.String for formatting Strings in the
printed text.
Thanks a lot,
Guadalupe
Re: Formatting text [message #58185 is a reply to message #58137] Tue, 10 March 2009 16:36 Go to previous messageGo to next message
I don't understand. Can you provide more details of what you are thinking?
Paul
Re: Formatting text [message #58236 is a reply to message #58185] Wed, 11 March 2009 07:43 Go to previous messageGo to next message
Yes,
The exactly example is I am exporting UML models designed with RSA to xml.
And when I read attribute types href I obtain
" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"
and I only want to show the text "String" in my generated code (which I
could easily obtain using java String function just asking for the
subString after #)
Thanks a lot for your help,
Guadalupe
Re: Formatting text [message #58285 is a reply to message #58236] Wed, 11 March 2009 10:59 Go to previous messageGo to next message
Originally posted by: johannes.nel.gmail.com
you can use the xpath string functions.
<c:get select="string-func(context)"/>
Guadalupe wrote:
> Yes,
> xml. And when I read attribute types href I obtain
> " pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String" and I
> only want to show the text "String" in my generated code (which I could
> easily obtain using java String function just asking for the subString
> after #)
> Guadalupe
Re: Formatting text [message #58332 is a reply to message #58285] Wed, 11 March 2009 11:27 Go to previous messageGo to next message
More specifically, JET implements all these standard XPath string
functions:
http://www.w3.org/TR/xpath#section-String-Functions
Plus, there are a number of other functions implemented, too:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.jet.doc/references/xpathFunctions/overview.html
In your case, I think substring-after($foo/@href, '#') would do.
Paul
Re: Formatting text [message #58440 is a reply to message #58332] Thu, 12 March 2009 15:13 Go to previous message
Thanks a lot!!
I will record this useful links in a safe place.
Previous Topic:Setting a Template context source in JET2
Next Topic:Adding XSD for validation breaks JET transformation (0.8.x)
Current Time: Sat Nov 08 19:23:35 EST 2025
Powered by FUDForum. Page generated in 0.03858 seconds
