| cannot distinguish between alternative(s) [message #58133] |
Tue, 14 July 2009 03:28  |
Hi Newsgroup,
in my dsl I will have to work with db tables. To identify a column inside
a table I use the following statements:
Table:
(schema=ID '.')? tableName=ID;
Element:
table=Table '.' columnName=ID ;
Optionally you may have to add a schema name, therefore schema is optional
in the Table statement.
When I execute the MWE worklfow I get the following warning:
warning(202):
../org.xtext.example.mydsl/src-gen/org/xtext/example/parser/ antlr/internal/InternalMyDsl.g:373:2:
the decision cannot distinguish between alternative(s) 2,1 for at least
one input sequence
which is not 100% clear to me. I see the concern from the compiler but I
do not know how to fix it. Is there any pattern fur such a problem ? A
quick fix would be to use another separator (e.g. # ) in the Table
definition. But I'd prefer to use the same separator.
Any help would be very much appreciated.
Marcel
| Re: cannot distinguish between alternative(s) [message #58856 is a reply to message #58133] |
Wed, 15 July 2009 04:55  |
Hi Marcel,
You should be able to enable ANTLR backtracking. The recent thread with
subject "[Xtext] ANTLR options"
( http://www.eclipse.org/newsportal/article.php?id=1296&gr oup=eclipse.modeling.tmf)
discussed how this is done.
Hope that helps,
--knut
Marcel Merkel wrote:
> Hi Newsgroup,
> inside a table I use the following statements:
> Table:
> Element:
> optional in the Table statement.
> warning(202):
> ./org.xtext.example.mydsl/src-gen/org/xtext/example/parser/a ntlr/internal/InternalMyDsl.g:373:2:
> one input sequence
> Marcel
FUDForum. Page generated in 0.03076 seconds
