Home » Modeling » M2T (model-to-text transformation) » conditional iteration
conditional iteration [message #58111] Tue, 10 March 2009 15:47 Go to next message
Hi all,
I want to make a list of elements separated from comas from a set of
elements name of a specific type with a specific value. (let’s say all "a"
elements whose type value is not "b").
I use an iteration to select all "a" elements and a Choose inside it to
select all those elements whose type value is b and I only print in the
otherwise option.
If I use the delimiter in the iteration I also get a comma for b elements,
though they are not printed.
Is there any option to put a condition in the iteration?
Btw, is there any way to know how many elements and iteration has
collected?
Thanks a lot for your answers
Re: conditional iteration [message #58161 is a reply to message #58111] Tue, 10 March 2009 16:36 Go to previous messageGo to next message
How about this:
<c:iterate select="$yourContextHere/a[not(@type = 'b')]" var="a"
delimiter=", ">
<c:get select="$a"/>
</c:iterate>
The expression in square brackets is an XPath 'predicate'. It is relative
to the step it follows, and filters selected nodes that do not meet
satisfy the expression.
Paul
Re: conditional iteration [message #58211 is a reply to message #58161] Wed, 11 March 2009 07:40 Go to previous message
Definitely yes!!
I focused too much in the Jet2 control Tags and did not realize that I
should focus on the XPath expressions.
Thanks a lot!!
Previous Topic:[Announce] M2T XPAND 0.7.0 I200903100728 is available
Next Topic:newbie: including external jars
Current Time: Fri Nov 07 18:37:38 EST 2025
Powered by FUDForum. Page generated in 0.03760 seconds
