Home » Archived » M2M (model-to-model transformation) » [ATL] how to apply stereotypes???
[ATL] how to apply stereotypes??? [message #58092] Fri, 17 August 2007 06:59 Go to next message
Hi guys, can anyone give me an example transformation that takes as input
a standard UML model and returns the same model with a profile and some
stereotypes applied????
I am able to apply a profile to a model, but tried without success for 3-4
days to apply a stereotype to a UML component...
I used Dennis Wagelaar's UML2Copy.atl and the UML2profile.ecore metamodel
(as described in this forum), but the concept of stereotypes was totally
ignored by my ATL transformations!
I also tried to use the UML24ATL driver:
- first I applied the profile to the model
- but the call of "isStereotypeApplicable(stereotype)" on some component
returned always "false"...
I don't know what to do, does anyone have some answer??? I am sure someone
has already applied UML stereotypes...
Regards, Ivano
Re: [ATL] how to apply stereotypes??? [message #58670 is a reply to message #58092] Mon, 20 August 2007 04:01 Go to previous messageGo to next message
> input a standard UML model and returns the same model with a profile and
> some stereotypes applied????
> 3-4 days to apply a stereotype to a UML component...
> metamodel (as described in this forum), but the concept of stereotypes
> was totally ignored by my ATL transformations!
Are you using the same profiles as I do? If not, you need to create your
own UML2Profiles.ecore meta-model.
I'm afraid I don't have the time to help you out step by step, but if
you're interested in a working stereotype example, best follow the full
instructions listed here:
http://ssel.vub.ac.be/ssel/research:mdd:casestudies:installa tion:uml2casestudies
> someone has already applied UML stereotypes...
> Regards, Ivano
Since I haven't tried this method recently, I'll leave this to the
people who know how this works ;-).
Kind regards,
Dennis
Re: [ATL] how to apply stereotypes??? [message #59560 is a reply to message #58092] Mon, 27 August 2007 05:54 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Ivano,
You can find from
http://www.eclipse.org/gmt/modisco/useCases/PerformanceAnnot atedUmlStateCharts/
a complete use case, using ATL, in which we apply a profile to a UML
model (and so stereotypes to UML model elements).
I hope this will help you.
> Regards, Ivano
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] how to apply stereotypes??? [message #60145 is a reply to message #59560] Sat, 01 September 2007 11:09 Go to previous message
Thank you very much: everything works perfectly!
Ivano
Previous Topic:[ATL] comparaison of ATL with other transformation languages
Next Topic:[ATL] Splitting ASMModel
Current Time: Mon Jul 21 21:48:43 EDT 2025
Powered by FUDForum. Page generated in 0.04005 seconds
