Home » Eclipse Projects » Technology Project and PMC » Is Omondo UML Plugin running compatible with Eclipse 3
Is Omondo UML Plugin running compatible with Eclipse 3 [message #58074] Fri, 19 September 2003 08:32 Go to next message
Originally posted by: jan.dieckmann.psi-bt.de
I am using Eclipse 2.1 and have the Omondo UML plugin installed.Does anybody
use this plugin under Eclipse 3? Are there any problems with Omondo under
Eclipse 3?
best regards
Jan Dieckmann
Re: Is Omondo UML Plugin running compatible with Eclipse 3 [message #58432 is a reply to message #58074] Wed, 01 October 2003 04:08 Go to previous message
Originally posted by: mnaglik.NOSPAM.gazeta.pl
I've tried to use it with M3 with no results.
Now I switch to 2.1 while creating uml models.
M.
U
Re: Is Omondo UML Plugin running compatible with Eclipse 3 [message #595473 is a reply to message #58074] Wed, 01 October 2003 04:08 Go to previous message
M.
U
Previous Topic:any tools for slicing and control flow analysis?
Next Topic:Plugin unit testing
Current Time: Sat Nov 22 12:04:56 EST 2025
Powered by FUDForum. Page generated in 0.02606 seconds
