Home » Archived » Service Component Architecture (SCA) Tools » Load an SCA composite model programmatically
Load an SCA composite model programmatically [message #5178] |
Wed, 04 February 2009 10:08  |
Originally posted by: mickael.istria.openwide.fr
Hi all,
I'm trying to load an SCA model programmatically to get data form a
..composite file by navigating in the EMF objects instead of using a ugly
XPath resolver. I'm using SCA editor and metamodel v1.0.1
However, when using the classic EMF code to load a Resource:
// Create a resource set.
ResourceSet resourceSet = new ResourceSetImpl();
// Register the default resource factory -- only needed for
// stand-alone!
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(Resource.Factory.Registry.DEFAULT_EXTENSION,
new XMIResourceFactoryImpl());
// Get the URI of the model file.
URI fileURI = URI.createFileURI(new
File(scaApp.getCompositeFile()).getAbsolutePath());
// Demand load the resource for this file.
Resource resource = resourceSet.getResource(fileURI, true);
Composite compositeModel = (Composite)resource.getContents().get(0);
on a composite file generated with the sca modeler (so conform to the
SCA metamodel), I got the following error:
org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'composite' not
found.
(file:/home/mistria/runtime-EclipseApplication/test/default. composite,
2, 78)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObje ctFromFactory(XMLHandler.java:2229)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObje ctFromFactory(XMLHandler.java:2220)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1318)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1454)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:83)
When looking at variables when the exception is raised, it seems like
the ScaFactory is found and used to unserialize model (a good point!)...
Do you have any idea of why this ScaFactory cannot resolve "composite"???
Mickael
Re: Load an SCA composite model programmatically [message #5246 is a reply to message #5178] |
Wed, 04 February 2009 11:09   |
Hi Mickael,
Use the SCA resource factory
(org.eclipse.stp.sca.util.ScaResourceFactoryImpl) instead of the XMI
resource factory.
Stephane Drapeau
Obeo
Mickael Istria a écrit :
> Hi all,
> ugly XPath resolver. I'm using SCA editor and metamodel v1.0.1
> // stand-alone!
> found.
> 2, 78)
> at
> at
> at
> at
> at
> at
> Mickael
Re: Load an SCA composite model programmatically [message #5312 is a reply to message #5246] |
Wed, 04 February 2009 11:23  |
Thanks Stephane,
it works!
Mickael
Stephane Drapeau a écrit :
> Hi Mickael,
> resource factory.
> Stephane Drapeau
> Obeo
>> Hi all,
>> // stand-alone!
>> not found.
>> 2, 78)
>> at
>> at
>> at
>> at
>> at
>> at
>> Regards,
>> Mickael
Re: Load an SCA composite model programmatically [message #574114 is a reply to message #5178] |
Hi Mickael,
resource factory.
Stephane Drapeau
Obeo
> Hi all,
> // stand-alone!
> found.
> 2, 78)
> at
> at
> at
> at
> at
> at
> Mickael
Re: Load an SCA composite model programmatically [message #574188 is a reply to message #5246] |
Thanks Stephane,
it works!
Mickael
> Hi Mickael,
> resource factory.
> Stephane Drapeau
> Obeo
>> Hi all,
>> // stand-alone!
>> not found.
>> 2, 78)
>> at
>> at
>> at
>> at
>> at
>> at
>> Regards,
>> Mickael
Current Time: Thu Oct 16 18:36:29 EDT 2025
Powered by FUDForum. Page generated in 0.04170 seconds
