Home » Eclipse Projects » Plugin Development Environment (PDE) » Unregistered plugins - neverending story
Unregistered plugins - neverending story [message #58001] Thu, 23 April 2009 11:51 Go to next message
Originally posted by: tmothymarc.freenet.de
Wow,
i'm getting crazy with this plugin registration mechanism of eclipse
3.4. I've read about p2, and placed my plugins into /dropins directory,
but they won't be registered. Afterwards, i create a new eclipse
instance by copying the whole program to another hard disk. I placed my
plugins into dropins, and suddenly... it works.
Both distribution are now eqauly configured and structured, but in my
first distribution, the plugins are not registered.... what a pitty.
It is like shooting dices, if the plugins will be registered in the
dropins directory. Does anyone have a good idea??? I'm becomming
deperate with every new try :(
Thx
Timothy
Re: Unregistered plugins - neverending story [message #58077 is a reply to message #58001] Thu, 23 April 2009 13:28 Go to previous messageGo to next message
Timothy Marc wrote:
> Wow,
The plugins/features you drop into the dropins/ directory each have a
set of pre-requisites (plugin or feature IDs and specific version
ranges). If any of those are not satisfied, the plugin won't load.
You can use the OSGi console to help debug why a particular plugin isn't
loading; I don't know the details of using it but Google for "OSGi
console" should get you enough info to work with.
By the way, this is why using an update site is usually a better option
than just "dropping in." The update manager will do its best to
automatically download required prerequisites when installing a feature.
Hope this helps,
Eric
Re: Unregistered plugins - neverending story [message #58248 is a reply to message #58001] Fri, 24 April 2009 05:28 Go to previous message
It used to be the case that Eclipse would cache information about
installed plugins. So, just dropping something into a directory and
restarting Eclipse wouldn't necessarily install the plugin. Instead, you
would have to start eclipse with the -clean command line parameter.
I'm not sure whether this is still true with p2 and the dropins folder,
but you might want to try it just in case.
Steffen
Timothy Marc wrote:
> Wow,
> directory, but they won't be registered. Afterwards, i create a new
> eclipse instance by copying the whole program to another hard disk. I
> placed my plugins into dropins, and suddenly... it works.
> Thx
> Timothy
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
Phone +44 (01524) 510354
WWW http://www.steffen-zschaler.de/
Consider submitting to MDPLE, the 1st International Workshop on
Model-Driven Product Line Engineering
http://www.feasiple.de/workshop_en.html
Re: Unregistered plugins - neverending story [message #596295 is a reply to message #58001] Thu, 23 April 2009 13:28 Go to previous message
Timothy Marc wrote:
> Wow,
Hope this helps,
Eric
Re: Unregistered plugins - neverending story [message #596348 is a reply to message #58001] Fri, 24 April 2009 05:28 Go to previous message
Steffen
Timothy Marc wrote:
> Wow,
> Thx
> Timothy
Previous Topic:Auto-Start option in Run-Configuration doesn't start bundles
Next Topic:headless update site build like in site editor
Current Time: Wed Oct 29 14:58:35 EDT 2025
Powered by FUDForum. Page generated in 0.03141 seconds
