Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » teneo - annotations in Rational Rose model - anyone?
| teneo - annotations in Rational Rose model - anyone? [message #57951] |
Tue, 17 October 2006 16:31  |
I have not found a way to specify teneo annotations correctly in Rose in
order to make them appear in the ecore so that it can be correctly
interpreted by teneo runtime.
The problem is that if in the ecore tab I add under annotations the value
teneo.jpa @Embedded
then this is incorrectly parsed as two annotations, one for each word on
the line. I can only guess that this might have to do with the key=value
pairs that are normally expected after the annotation source. With teneo
no key=value pairs are used, only values. I guess that breaks it.
Has anybody else here achieved this?
Andre
| Re: teneo - annotations in Rational Rose model - anyone? [message #58048 is a reply to message #57951] |
Wed, 18 October 2006 12:02   |
Hi Andre,
Sorry, I don't have rational rose myself.
Ed (if you are watching this thread), do you maybe know this?
gr. Martin
Andre Pareis wrote:
> teneo.jpa @Embedded
> Andre
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: teneo - annotations in Rational Rose model - anyone? [message #58073 is a reply to message #58048] |
Wed, 18 October 2006 12:04   |
Hi Andre,
You can also specify annotations in a separate xml file, see here:
http://www.elver.org/hibernate/ejb3_format.html#xml
gr. Martin
Martin Taal wrote:
> Hi Andre,
> gr. Martin
> Andre Pareis wrote:
>> in order to make them appear in the ecore so that it can be correctly
>> teneo.jpa @Embedded
>> on the line. I can only guess that this might have to do with the
>> key=value pairs that are normally expected after the annotation
>> source. With teneo no key=value pairs are used, only values. I guess
>> that breaks it.
>> Andre
The Netherlands
| Re: teneo - annotations in Rational Rose model - anyone? [message #58200 is a reply to message #58153] |
Thu, 19 October 2006 08:49   |
Ed,
The annotation should be of the following format:
source: teneo.jpa
key: value
value (of the annotation): @Embedded
(or any other jpa annotation).
In xml schema the format is:
<xsd:element name="secondEmbedded" type="this:Embeddable">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Embedded</xsd:appinfo>
</xsd:annotation>
</xsd:element>
I do not know the rose ui, but maybe you have an idea how to enter this in Rose?
Or does this help you also Andre?
gr. Martin
Ed Merks wrote:
> Martin,
> I couldn't quite tell what kind of annotations Andre is trying to
> specify. There is an "annotation" Ecore property which I described in
> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg0 5668.html
> Martin Taal wrote:
>> Hi Andre,
>> gr. Martin
>> Andre Pareis wrote:
>>> Hi,
>>> value
>>> teneo.jpa @Embedded
>>> that breaks it.
>>> Andre
The Netherlands
| Re: teneo - annotations in Rational Rose model - anyone? [message #58225 is a reply to message #58200] |
Thu, 19 October 2006 09:00   |
Martin,
I think he'd just enter teneo.jpa value='@Embedded' in the annotation
Ecore property
Martin Taal wrote:
> Ed,
> source: teneo.jpa
> key: value
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> this in Rose?
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> Martin Taal wrote:
>>> Hi Andre,
>>> gr. Martin
>>> Andre Pareis wrote:
>>>> Hi,
>>>> Rose in order to make them appear in the ecore so that it can be
>>>> correctly interpreted by teneo runtime.
>>>> value
>>>> teneo.jpa @Embedded
>>>> word on the line. I can only guess that this might have to do with
>>>> the key=value pairs that are normally expected after the annotation
>>>> Andre
| Re: teneo - annotations in Rational Rose model - anyone? [message #58471 is a reply to message #58225] |
Fri, 20 October 2006 11:57   |
Thanks Ed and Martin for your response. The simple example partially works.
turns into:
<eClassifiers xsi:type="ecore:EClass"
name="IncomeFromContinuingOperations">
<eAnnotations source="teneo.jpa">
<details key="value" value="@Embedded"/>
</eAnnotations>
but a more complex example like this one:
teneo.jpa value='@Table(name="DOM")'
becomes:
<eClassifiers xsi:type="ecore:EClass" name="Domain"
eSuperTypes="#//pareis/trading/Identifiable">
<details key="value='@Table(name" value="DOM"/>
</eAnnotations>
<eAnnotations source=")'"/>
<eAnnotations source="http://www.eclipse.org/emf/2002/GenModel">
<details key="documentation" value="Represents a
classification or identification system
Examples: ISIN, US, RIC"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Client"
eType="#//pareis/trading/Client"
transient="true" eOpposite="#//pareis/trading/Client/domains"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="symbols"
upperBound="-1"
eType="#//pareis/trading/Symbol" containment="true"
eOpposite="#//pareis/trading/Symbol/Domain"/>
</eClassifiers>
so what happens is that it breaks key and value at the second "=" which
is the wrong one. I guess this stuff will not work from within Rose.
I will try now with the separate annotations file.
Andre
Ed Merks schrieb:
> Martin,
> Ecore property
> Martin Taal wrote:
>> Ed,
>> source: teneo.jpa
>> key: value
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:element>
>> this in Rose?
>> gr. Martin
>> Ed Merks wrote:
>>> Martin,
>>> Martin Taal wrote:
>>>> Hi Andre,
>>>> gr. Martin
>>>> Andre Pareis wrote:
>>>>> Hi,
>>>>> value
>>>>> teneo.jpa @Embedded
>>>>> Andre
| Re: teneo - annotations in Rational Rose model - anyone? [message #58478 is a reply to message #58471] |
Fri, 20 October 2006 12:14   |
--------------070007060704070404030109
Andre,
Try this approach:
teneo.jpa value='@Table(name\075"DOM")'
Characters can be escaped in the usual Java way...
> works.
> turns into:
> </eAnnotations>
> becomes:
> </eAnnotations>
Examples: ISIN, US,
> RIC"/>
> </eAnnotations>
> transient="true"
> name="symbols" upperBound="-1"
> </eClassifiers>
> which is the wrong one. I guess this stuff will not work from within
> Rose.
> Thanks
> Andre
> Ed Merks schrieb:
>> Martin,
>> Ecore property
>> Martin Taal wrote:
>>> Ed,
>>> source: teneo.jpa
>>> key: value
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:element>
>>> this in Rose?
>>> gr. Martin
>>> Ed Merks wrote:
>>>> Martin,
>>>> Martin Taal wrote:
>>>>> Hi Andre,
>>>>> gr. Martin
>>>>> Andre Pareis wrote:
>>>>>> Hi,
>>>>>> the value
>>>>>> teneo.jpa @Embedded
>>>>>> with the key=value pairs that are normally expected after the
>>>>>> annotation source. With teneo no key=value pairs are used, only
>>>>>> Andre
<html>
<head>
http-equiv="Content-Type">
</head>
Andre,<br>
<br>
Try this approach:<br>
<blockquote>teneo.jpa value='@Table(name\075"DOM")' <br>
</blockquote>
Characters can be escaped in the usual Java way...<br>
<br>
<br>
Andre Pareis wrote:
<blockquote cite="mideharm3$4o2$1@utils.eclipse.org" type="cite">Thanks
<br>
<br>
| Re: teneo - annotations in Rational Rose model - anyone? [message #58480 is a reply to message #58478] |
Fri, 20 October 2006 14:50  |
Hi Ed,
that helped! Thanks very much!
Andre
Ed Merks wrote:
> Andre,
> Try this approach:
>> works.
>> turns into:
>> </eAnnotations>
>> becomes:
>> </eAnnotations>
Examples: ISIN, US,
>> RIC"/>
>> </eAnnotations>
>> transient="true"
>> </eClassifiers>
>> Rose.
>> Thanks
>> Andre
>> Ed Merks schrieb:
>>> Martin,
>>> Ecore property
>>> Martin Taal wrote:
>>>> Ed,
>>>> source: teneo.jpa
>>>> key: value
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:element>
>>>> this in Rose?
>>>> gr. Martin
>>>> Ed Merks wrote:
>>>>> Martin,
>>>>> Martin Taal wrote:
>>>>>> Hi Andre,
>>>>>> gr. Martin
>>>>>> Andre Pareis wrote:
>>>>>>> Hi,
>>>>>>> the value
>>>>>>> teneo.jpa @Embedded
>>>>>>> Andre
| Re: teneo - annotations in Rational Rose model - anyone? [message #594283 is a reply to message #57951] |
Hi Andre,
gr. Martin
Andre Pareis wrote:
> teneo.jpa @Embedded
> Andre
The Netherlands
| Re: teneo - annotations in Rational Rose model - anyone? [message #594290 is a reply to message #58048] |
Hi Andre,
gr. Martin
Martin Taal wrote:
> Hi Andre,
> gr. Martin
> Andre Pareis wrote:
>> teneo.jpa @Embedded
>> that breaks it.
>> Andre
The Netherlands
| Re: teneo - annotations in Rational Rose model - anyone? [message #594329 is a reply to message #58048] |
Thu, 19 October 2006 08:06  |
--------------090007090301030509070603
Martin,
Martin Taal wrote:
> Hi Andre,
> gr. Martin
> Andre Pareis wrote:
>> value
>> teneo.jpa @Embedded
>> that breaks it.
>> Andre
<html>
<head>
</head>
Martin,<br>
<br>
specify.
| Re: teneo - annotations in Rational Rose model - anyone? [message #594350 is a reply to message #58153] |
Ed,
source: teneo.jpa
key: value
<xsd:annotation>
</xsd:annotation>
</xsd:element>
gr. Martin
Ed Merks wrote:
> Martin,
> Martin Taal wrote:
>> Hi Andre,
>> gr. Martin
>> Andre Pareis wrote:
>>> Hi,
>>> value
>>> teneo.jpa @Embedded
>>> that breaks it.
>>> Andre
The Netherlands
| Re: teneo - annotations in Rational Rose model - anyone? [message #594363 is a reply to message #58200] |
Martin,
Ecore property
Martin Taal wrote:
> Ed,
> source: teneo.jpa
> key: value
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> this in Rose?
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> Martin Taal wrote:
>>> Hi Andre,
>>> gr. Martin
>>> Andre Pareis wrote:
>>>> Hi,
>>>> value
>>>> teneo.jpa @Embedded
>>>> Andre
| Re: teneo - annotations in Rational Rose model - anyone? [message #594477 is a reply to message #58225] |
turns into:
</eAnnotations>
becomes:
</eAnnotations>
</eAnnotations>
upperBound="-1"
</eClassifiers>
Andre
Ed Merks schrieb:
> Martin,
> Ecore property
> Martin Taal wrote:
>> Ed,
>> source: teneo.jpa
>> key: value
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:element>
>> this in Rose?
>> gr. Martin
>> Ed Merks wrote:
>>> Martin,
>>> Martin Taal wrote:
>>>> Hi Andre,
>>>> gr. Martin
>>>> Andre Pareis wrote:
>>>>> Hi,
>>>>> value
>>>>> teneo.jpa @Embedded
>>>>> Andre
| Re: teneo - annotations in Rational Rose model - anyone? [message #594483 is a reply to message #58471] |
Andre,
Try this approach:
> works.
> turns into:
> </eAnnotations>
> becomes:
> </eAnnotations>
Examples: ISIN, US,
> RIC"/>
> </eAnnotations>
> transient="true"
> </eClassifiers>
> Rose.
> Thanks
> Andre
> Ed Merks schrieb:
>> Martin,
>> Ecore property
>> Martin Taal wrote:
>>> Ed,
>>> source: teneo.jpa
>>> key: value
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:element>
>>> this in Rose?
>>> gr. Martin
>>> Ed Merks wrote:
>>>> Martin,
>>>> Martin Taal wrote:
>>>>> Hi Andre,
>>>>> gr. Martin
>>>>> Andre Pareis wrote:
>>>>>> Hi,
>>>>>> the value
>>>>>> teneo.jpa @Embedded
>>>>>> Andre
<html>
<head>
</head>
Andre,<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
| Re: teneo - annotations in Rational Rose model - anyone? [message #594495 is a reply to message #58478] |
Hi Ed,
Andre
Ed Merks wrote:
> Andre,
> Try this approach:
>> works.
>> turns into:
>> </eAnnotations>
>> becomes:
>> </eAnnotations>
Examples: ISIN, US,
>> RIC"/>
>> </eAnnotations>
>> transient="true"
>> </eClassifiers>
>> Rose.
>> Thanks
>> Andre
>> Ed Merks schrieb:
>>> Martin,
>>> Ecore property
>>> Martin Taal wrote:
>>>> Ed,
>>>> source: teneo.jpa
>>>> key: value
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:element>
>>>> this in Rose?
>>>> gr. Martin
>>>> Ed Merks wrote:
>>>>> Martin,
>>>>> Martin Taal wrote:
>>>>>> Hi Andre,
>>>>>> gr. Martin
>>>>>> Andre Pareis wrote:
>>>>>>> Hi,
>>>>>>> the value
>>>>>>> teneo.jpa @Embedded
>>>>>>> Andre
Current Time: Wed Nov 19 04:44:44 EST 2025
Powered by FUDForum. Page generated in 0.29132 seconds
