Home » Archived » M2M (model-to-model transformation) » Problems with model new elements ...
Problems with model new elements ... [message #57939] Tue, 14 August 2007 21:49
Originally posted by: macf1983.gmail.com
Hi guys
I'm with a problem with how define a rule for this m2m transformation.
Here's the situation's core:
1) There's a model A with 2 classes: A1 and A2
2) There's a model B, that is almost the same of model A , except by one
more class B that have 2 attributes: an A1 object and an A2 object
How do I define a transformation rule from A to B that gives [having as
entrance a model's A instance] as result a model's B instance that keeps
the same instances of classes A1 and A2 contained in model's A instance,
but as attributes of a class B object created during the transformation ?
[By the way, is there a best way[rule] to create this object B during the
transformation ?]
I hope everyone have understood what I try to explain about this problem I
have.
Sorry if I've committed any grammatical error ...
Previous Topic:superimposition in UML2
Next Topic:[ATL]Problem with transformation of a model that contains XMI href attribute
Current Time: Fri Nov 07 16:32:21 EST 2025
Powered by FUDForum. Page generated in 0.03390 seconds
