Home » Modeling » GMF (Graphical Modeling Framework) » Pulling attribute from a referenced object
Pulling attribute from a referenced object [message #57900] Sat, 30 September 2006 19:58 Go to next message
Hello all, I have a question about how to pull the contents of an attribute
from a referenced object into a label. I've looked around the web and this
group and haven't seen anything yet. Here's the scoop:
I have the following classes modeled in EMF:
Person
lastName String
firstName String
Commander
startPeriod Date
endPeriod Date
kind String
person (single reference to Person)
Command
startDate Date
commanders (List of Commanders)
I've started modeling this in GMF, and so far have been able to model a
figure based on Command with a fixed title "Command" at the top, followed by
a compartment listing "kind" for each Commander in the Command object. This
was pretty simple to do following along with the GMF tutorial.
What I'd really like to be able to do is have the list in that compartment
display the lastName of each Person via the person reference in Commander
rather than the simple attribute "kind", but I'm not seeing how something
like that is done. Can anyone give me some guidance?
Thanks!!!
Re: Pulling attribute from a referenced object [message #58243 is a reply to message #57900] Mon, 02 October 2006 09:43 Go to previous message
Originally posted by: vcciubot.uwaterloo.ca
Assuming you already show some attribute in your diagram and you want this
attribute edit part to `point' somewhere else:
You should override resolveSemanticElement() of your attribute edit part
to return the referenced object (look to in GraphicalEditPart to see how
it's done).
This method in the attribute editPart passes the referenced
object to the parser:
public String getEditText() {
EObject element = resolveSemanticElement();
return (element == null) ? "" //$NON-NLS-1$
: getParser().getEditString(
new EObjectAdapter(element),
getParserOptions().intValue());
The parser is set by this other method:
public IParser getParser() {
if (parser == null) {
String parserHint = ((View)getModel()).getType();
if (element != null) {
ParserHintAdapter hintAdapter =
new ParserHintAdapter(element, parserHint);
parser = ParserService.getInstance().getParser(hintAdapter);
return parser;
It calls the ParserService which in turn calls your ParserProvider. So you
might have to extend the generated Provider to handle this attribute, but
it's very easy.
This other method, keeps synchs with the model:
protected void addSemanticListeners() {
if (getParser() instanceof ISemanticParser) {
EObject semanticElement = resolveSemanticElement();
parserElements =
((ISemanticParser) getParser()).getSemanticElementsBeingParsed(semanticElement) ;
for (int i = 0; i < parserElements.size(); i++)
addListenerFilter("SemanticModel" + i, this,(EObject)parserElements.get(i)); //$NON-NLS-1$
} else
super.addSemanticListeners();
> Person
> lastName String
> firstName String
> Commander
> startPeriod Date
> endPeriod Date
> kind String
> Command
> startDate Date
> Thanks!!!
Previous Topic:Validate from Code
Next Topic:permanent synchronizing GMF and EMF-Editor that use the same file as modelfile.
Current Time: Tue Jul 22 01:44:23 EDT 2025
Powered by FUDForum. Page generated in 0.24762 seconds
