Home » Archived » XML Schema Definition (XSD) » Changing an element from type= to ref=
Changing an element from type= to ref= [message #57873] |
Fri, 18 February 2005 14:49  |
Hi folks,
Sorry if this is a FAQ, but my newsgroup search didn't turn up much.
Basically the situation I have is that my XSD model is loaded on a file
with a perfectly normal complexType containing several elements in a
sequence. Some of the elements use type="..." specifiers, and some are
element refs.
While interacting with our editor, our user will at various times want to
change the type on these elements, and may choose a complexType or an
element, so we need to support all four possibilities:
1) used to use type="..." now uses ref=".."
2) ref -> type
3) ref -> ref
4) type -> type
Cases 3 and 4 work fine, but cases 1 and 2 we're hitting problems. We had
assumed that, for instance for case #2, we could do something like:
element.setTypeDefinition(newType);
element.setName(newName);
and then we realised that we should probably make it:
element.setResolvedElementDeclaration(element);
just to be sure. But when this serializes, we end up with an element that
contains a name, type AND ref attributes, which is obviously bad XSD. A
similar problem strikes when we try to go the other way - nulling name and
typeDefinition, and setting the resolved element.
Is there something obvious we're missing here? We don't want to get to
the point where we first have to create a new element, remove the old one
from its particle, insert the new one, and then copy over annotations,
etc. if there's a cleaner way to make it all magically work. :)
Johnathan
Re: Changing an element from type= to ref= [message #57898 is a reply to message #57873] |
Fri, 18 February 2005 15:31  |
--------------060604060502080507020605
Johnathan,
The 2) case isn't expected and isn't handled correctly so you should
open a bugzilla. You can access the DOM directly and remove the "ref"
attribute manually as a workaround, i.e,
element.getElement().removeAttribute("ref")
I think 1) case should work iff you null the type and name first and set
the reference after, but I haven't tried that.
Johnathan Nightingale wrote:
> Hi folks,
> file with a perfectly normal complexType containing several elements
> in a sequence. Some of the elements use type="..." specifiers, and
> some are element refs.
> to change the type on these elements, and may choose a complexType or
> an element, so we need to support all four possibilities:
> 2) ref -> type
> 3) ref -> ref
> 4) type -> type
> had assumed that, for instance for case #2, we could do something like:
> that contains a name, type AND ref attributes, which is obviously bad
> XSD. A similar problem strikes when we try to go the other way -
> nulling name and typeDefinition, and setting the resolved element.
> to the point where we first have to create a new element, remove the
> old one from its particle, insert the new one, and then copy over
> annotations, etc. if there's a cleaner way to make it all magically
> work. :)
> Johnathan
<html>
<head>
http-equiv="Content-Type">
</head>
Johnathan,<br>
<br>
open a bugzilla.
Re: Changing an element from type= to ref= [message #594106 is a reply to message #57873] |
Johnathan,
> Hi folks,
> 2) ref -> type
> 3) ref -> ref
> 4) type -> type
> work. :)
> Johnathan
<html>
<head>
</head>
Johnathan,<br>
<br>
open a bugzilla.
Current Time: Tue Jul 15 14:53:39 EDT 2025
Powered by FUDForum. Page generated in 0.07508 seconds
