Home » Language IDEs » PHP Development Tools (PDT) » Debug Error: "error while publishing files to server"
Debug Error: "error while publishing files to server" [message #57863] Fri, 12 October 2007 04:32 Go to next message
I have set up an PHP Web Project with Eclipse 3.3.1 and
PDT 1.0.1.
The server is 'http://web' with Publish Information
set to 'C:\Local\Web\'
Then I set up a PHP Web Page run configuration
File/Project: Project01/index.php
Publish To: (C:\Local\Web\)project
Autogenerated URL: http://web/project/index.php
But when I try to run this configuration I get the
following error:
But there is no console output or anything else which
will help to track this error down.
Any ideas?
Best regards, T.Gau
Re: Debug Error: "error while publishing files to server" [message #58531 is a reply to message #57863] Mon, 15 October 2007 10:47 Go to previous message
I found the error myself.
It was a file named "Thumbs.db" in my project. I think it's
from Windows buildin viewer. Eclipse tried to publish it, too.
But could not override because it seems to be a system file.
So I deleted it and now it runs.
I found the hint in the eclipse log file in
/workspace/.metadata/.log
I should have thougt about that, sorry.
Greetings, T.Gau
T. Gau schrieb:
> PDT 1.0.1.
> following error:
> Any ideas?
> Best regards, T.Gau
Previous Topic:ClassNotFoundException
Next Topic:PDT server support
Current Time: Tue Nov 18 13:49:39 EST 2025
Powered by FUDForum. Page generated in 0.06452 seconds
