| Home » Modeling » TMF (Xtext) » Left recursion: from binary to n-ary operations
 Goto Forum:|
| Left recursion: from binary to n-ary operations [message #57815] | Mon, 13 July 2009 14:46  |  |
| Eclipse User  |  |  |  |  | Originally posted by: c.krause.cwi.nl
 Hi all,
 this is a grammar for arithmetical expressions, as suggested in a post
 some weeks ago (thank you Sven, by the way):
 PlusOperation returns Expression:
 MultiplyOperation ({BinaryOp.left=current} operator=('+'|'-')
 right=MultiplyOperation)*;
 MultiplyOperation returns Expression:
 PrimaryExpression ({BinaryOp.left=current} operator=('*'|'/')
 right=PrimaryExpression)*;
 PrimaryExpression returns Expression:
 NumberLiteral |
 '(' PlusOperation ')';
 NumberLiteral :
 value=INT;
 If I uderstand it correctly, this avoids the left recursion and nicely
 handles the priority of the operations. What I would like to do now is
 to go from binary operations to n-ary. My plan would be to:
 * make separate rules for +,-,*,/, and then
 * to use something like {NaryOp.members += current}
 Does that sound like a good plan or did I misunderstood something? Any
 suggestions are of course more than welcome.
 Christian Krause,
 CWI Amsterdam
| Re: Left recursion: from binary to n-ary operations [message #57912 is a reply to message #57815] | Mon, 13 July 2009 15:19   |  |
| Eclipse User  |  |  |  |  | What exactly do you mean by n-ary? A fixed size of operands greater than two (e.g. "foo ? bar : baz") or an
 arbitrary concatenation of operations ending up as one model element
 with any number of operands (like '1 + 2 + 3 + 4 + ...')?
 Sven
 Christian Krause schrieb:
 > Hi all,
 >   NumberLiteral |
 > NumberLiteral :
 >   value=INT;
 > Cheers,
 > Christian Krause,
 > CWI Amsterdam
| Re: Left recursion: from binary to n-ary operations [message #57936 is a reply to message #57912] | Mon, 13 July 2009 15:48   |  |
 I see that was a bit fuzzy. I mean an arbitrary length >= 2 (so at least
 one occurrence of the (same) operand).
 Christian
 > Cheers,
 > Sven
 >> Hi all,
 >>   NumberLiteral |
 >> NumberLiteral :
 >>   value=INT;
 >> Cheers,
 >> Christian Krause,
 >> CWI Amsterdam
| Re: Left recursion: from binary to n-ary operations [message #57984 is a reply to message #57936] | Mon, 13 July 2009 16:03   |  |
| Eclipse User  |  |  |  |  | This could be written like this:
 NaryOp returns Expression :
 Operand ({NaryOp.operands+=current} '+' operands+=Operand ('+'
 operands+=Operand)*)?;
 Sven
 > Cheers,
 > Christian
 >> an arbitrary concatenation of operations ending up as one model
 >> element with any number of operands (like '1 + 2 + 3 + 4 + ...')?
 >> Cheers,
 >> Sven
 >>> Hi all,
 >>> post some weeks ago (thank you Sven, by the way):
 >>>   NumberLiteral |
 >>> NumberLiteral :
 >>>   value=INT;
 >>> nicely handles the priority of the operations. What I would like to
 >>> do now is to go from binary operations to n-ary. My plan would be to:
 >>> Any suggestions are of course more than welcome.
 >>> Cheers,
 >>> Christian Krause,
 >>> CWI Amsterdam
| Re: Left recursion: from binary to n-ary operations [message #58033 is a reply to message #57984] | Mon, 13 July 2009 16:12   |  |
 Dear Sven,
 thank you for this quick and detailed help. I really appreciate it. I
 think I know more or less how to go from here.
 Christian
 PS: I guess you don't happen to know whether Itemis is planning to open
 an office in Berlin..
 > Sven
 >> least one occurrence of the (same) operand).
 >> Cheers,
 >> Christian
 >>> Cheers,
 >>> Sven
 >>>> Hi all,
 >>>>   NumberLiteral |
 >>>> NumberLiteral :
 >>>>   value=INT;
 >>>> Cheers,
 >>>> Christian Krause,
 >>>> CWI Amsterdam
| Re: Left recursion: from binary to n-ary operations [message #58058 is a reply to message #58033] | Mon, 13 July 2009 17:23   |  |
 Since it might be useful for others as well, this is the grammar I'm
 using now:
 Addition returns Expression:
 Subtraction ( {Addition.operands += current} ('+' operands +=
 Subtraction)+)?;
 Subtraction returns Expression:
 Multiplication ( {Subtraction.operands += current} ('-' operands +=
 Multiplication)+)?;
 Multiplication returns Expression:
 Division ( {Multiplication.operands += current} ('*' operands +=
 Division)+)?;
 Division returns Expression:
 Operation ( {Division.operands += current} ('/' operands += Operation)+)?;
 Literal | '(' Addition ')';
 Literal:
 Constant | Variable;
 Variable returns Variable:
 name=ID;
 Constant returns Constant:
 value=INT;
 The only wrong thing now is that 'operands' should be an attribute of a
 common superclass 'Operation', but this shouldn't be too difficult.
 Anyway, thanks again for the help.
 Christian
 Christian Krause wrote:
 > Dear Sven,
 > Cheers,
 > Christian
 >> Sven
 >>> Cheers,
 >>> Christian
 >>>> or an arbitrary concatenation of operations ending up as one model
 >>>> Cheers,
 >>>> Sven
 >>>>> Hi all,
 >>>>>   NumberLiteral |
 >>>>> NumberLiteral :
 >>>>>   value=INT;
 >>>>> Cheers,
 >>>>> Christian Krause,
 >>>>> CWI Amsterdam
| Re: Left recursion: from binary to n-ary operations [message #58158 is a reply to message #58058] | Tue, 14 July 2009 04:39   |  |
| Eclipse User  |  |  |  |  | Hi Christian,
 I think the mathmatical operators below are binary.
 IMHO it is best practice to have them as such, because it makes it
 simpler to work on them later on.
 Why do you want them to be n-ary?
 Sven
 > using now:
 > Subtraction)+)?;
 > Multiplication)+)?;
 > Division)+)?;
 > Operation)+)?;
 > Literal:
 >     name=ID;
 >     value=INT;
 > Cheers,
 > Christian
 >> Dear Sven,
 >> Cheers,
 >> Christian
 >> open an office in Berlin..
 >>> Sven
 >>>> Cheers,
 >>>> Christian
 >>>>> Cheers,
 >>>>> Sven
 >>>>>> Hi all,
 >>>>>>   NumberLiteral |
 >>>>>> NumberLiteral :
 >>>>>>   value=INT;
 >>>>>> to do now is to go from binary operations to n-ary. My plan would
 >>>>>> be to:
 >>>>>> Cheers,
 >>>>>> Christian Krause,
 >>>>>> CWI Amsterdam
| Re: Left recursion: from binary to n-ary operations [message #58281 is a reply to message #58158] | Tue, 14 July 2009 05:57  |  |
 Hi Sven,
 I understand your concern. I think in the end I will have only addition
 and multiplication n-ary and the other two binary. I want to use the
 associativity of _+_ and _*_ to simplify the model. If someone enters
 (a+(b+c)) I can do a very simple model transformation and write it as
 (a+b+c).
 Christian
 > Hi Christian,
 > Cheers,
 > Sven
 >> using now:
 >> Subtraction)+)?;
 >> += Multiplication)+)?;
 >> Division)+)?;
 >> Operation)+)?;
 >> Literal:
 >>     name=ID;
 >>     value=INT;
 >> a common superclass 'Operation', but this shouldn't be too difficult.
 >> Cheers,
 >> Christian
 >>> Dear Sven,
 >>> Cheers,
 >>> Christian
 >>>>> Cheers,
 >>>>> Christian
 >>>>>> Cheers,
 >>>>>> Sven
 >>>>>>> Hi all,
 >>>>>>>   NumberLiteral |
 >>>>>>> NumberLiteral :
 >>>>>>>   value=INT;
 >>>>>>> be to:
 >>>>>>> something? Any suggestions are of course more than welcome.
 >>>>>>> Cheers,
 >>>>>>> Christian Krause,
 >>>>>>> CWI Amsterdam
 Current Time: Fri Oct 31 08:31:55 EDT 2025
 Powered by FUDForum . Page generated in 0.04444 seconds |
