Home » Newcomers » Newcomers » Problem with problems view
Problem with problems view [message #57810] Tue, 26 April 2005 14:19 Go to next message
Originally posted by: jwalters.computer.org
I am using eclipse 3.0.1 to do Java development. Sometime yesterday all
of a sudden when I double click on a line in the problems view it shows me
only the smallest bit of what caused the error. For example if the problem
is an import it shows me only the import. In the past I was able to double
click on a problem and see the entire file. What setting/preference
controls this behaviour. This doesn't seem to be folding because the
carets aren't visible on the left hand.
Cheers
Re: Problem with problems view [message #57838 is a reply to message #57810] Tue, 26 April 2005 14:35 Go to previous messageGo to next message
More information, it's not just the problems view I get the same behavior
navigating from search and package explorer. If I double-click on a
member function for example all I see in the editor window is that member
function, not the entire file positioned to that function.
Thanks for your help.
Re: Problem with problems view [message #57907 is a reply to message #57838] Tue, 26 April 2005 17:27 Go to previous message
You have turned on Show Source of Selected Item Only. You can toggle this
by clicking on the Show Source icon in the tool bar. It looks like a page
of text with part of the text pulled out.
Previous Topic:working with content in IWorkbenchWindowActionDelegate
Next Topic:java Printstream printf()
Current Time: Wed Oct 29 06:59:03 EDT 2025
Powered by FUDForum. Page generated in 0.08513 seconds
