Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » teneo - persisting the ecore itself (FAQ)
teneo - persisting the ecore itself (FAQ) [message #57808] Mon, 16 October 2006 18:22 Go to next message
Hi Martin (and others),
I know that this or similar have been asked before. But just out of
curiosity, is persisting of the ecore itself fully supported now?
I'm asking because I just experimentally added an association from my
domain model to the EClass and added the EcorePackage.eINSTANCE to the
EPackages to be mapped to hibernate and surprisingly it worked! At
least, ecore related tables have been created in the DB, like "EClass",
"EPackage" and others. Will those be fully working or with restrictions?
Has anybody tested this already?
I'm asking because the architecture of the application that I am going
to build kind of depends on those capabilities. If this is not an
option, I would have to help myself with EClass IDs which I had to
resolve in a derived association for instance. If teneo already had the
capabilities, I could use them directly! That would make it very much
easier...
Andre
Re: teneo - persisting the ecore itself (FAQ) [message #57832 is a reply to message #57808] Mon, 16 October 2006 18:31 Go to previous messageGo to next message
I'm really impressed. I just gave it a try and it was absolutely no
problem to persist the ecore itself plus my own packages. Martin, this
is really really a great piece of work that you've created for us here... :)
> easier...
> Regards
> Andre
Re: teneo - persisting the ecore itself (FAQ) [message #57856 is a reply to message #57832] Mon, 16 October 2006 18:54 Go to previous messageGo to next message
Andre,
Yeah, Martin has done a great job, hasn't he! ;-)
> here... :)
>> the EPackages to be mapped to hibernate and surprisingly it worked!
>> At least, ecore related tables have been created in the DB, like
>> "EClass", "EPackage" and others. Will those be fully working or with
>> restrictions? Has anybody tested this already?
>> going to build kind of depends on those capabilities. If this is not
>> an option, I would have to help myself with EClass IDs which I had to
>> the capabilities, I could use them directly! That would make it very
>> much easier...
>> Regards
>> Andre
Re: teneo - persisting the ecore itself (FAQ) [message #57878 is a reply to message #57856] Tue, 17 October 2006 05:37 Go to previous message
Thanks for the kudos :-)!
I actually tested this before and on mysql 4.1 I got an exception because hibernate tried to do a
join with 61 tables which it apparently was not able to handle. So the queries may not be that
efficient. On the other hand model data is normally very small (in database terms).
With microsoft sql server my test (storing and retrieving the library ecore model) worked fine.
When I tested it it also stored the ecore model itself in the database (as the ecore model is
represented in ecore also).
gr. Martin
Ed Merks wrote:
> Andre,
>> here... :)
>>> much easier...
>>> Regards
>>> Andre
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo - persisting the ecore itself (FAQ) [message #594166 is a reply to message #57808] Mon, 16 October 2006 18:31 Go to previous message
> easier...
> Regards
> Andre
Re: teneo - persisting the ecore itself (FAQ) [message #594178 is a reply to message #57832] Mon, 16 October 2006 18:54 Go to previous message
Andre,
> here... :)
>> much easier...
>> Regards
>> Andre
Re: teneo - persisting the ecore itself (FAQ) [message #594192 is a reply to message #57856] Tue, 17 October 2006 05:37 Go to previous message
gr. Martin
Ed Merks wrote:
> Andre,
>> here... :)
>>> much easier...
>>> Regards
>>> Andre
The Netherlands
Previous Topic:teneo - persisting the ecore itself (FAQ)
Next Topic:teneo - annotations in Rational Rose model - anyone?
Current Time: Fri Nov 21 14:55:46 EST 2025
Powered by FUDForum. Page generated in 0.03924 seconds
