| Launching JET2 from code [message #57721] |
Wed, 25 February 2009 11:04  |
What's the best entry point for launching JET2 transforms programatically?
I have an EMF model in memory which I loaded from a repository. However I
will want to output a text ( java source ) file into the "current project".
If I create my own version of WorkspaceContextExtender.public static void
loadResourceAsSource(JET2Context context, IResource resource, String
resourceLoaderId, String resourceType)
which simply sets the JET2Context.setSource up directly to the "Resource"
I have in memory and then set up the other variable appropriately, would
this be a good approach, or do you know of any problems I might expect?
The "Resource" will already have successfully loaded the EMF Model and
therefore all the EObjects will have their metadata set for the purposes
of the XPath's reflection, so that shouldn't be a problem....
| Re: Launching JET2 from code [message #57770 is a reply to message #57721] |
Thu, 26 February 2009 08:07   |
I seem to able to do this quite happily, as long as I take care of the
context variables;
import java.io.IOException;
import jet2testproject.Activator;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.jet.CoreJETException;
import org.eclipse.jet.JET2Context;
import org.eclipse.jet.JET2Platform;
import org.eclipse.jet.taglib.JET2TagException;
import org.eclipse.jet.taglib.workspace.WorkspaceContextExtender;
import org.eclipse.jet.transform.IJETBundleDescriptor;
public class Jet2Utils2
public static final class WorkspaceResourceSpecification
public final String projectName;
public WorkspaceResourceSpecification(String projectName)
this.projectName = projectName;
String transformId;
Resource emfResource;
final IProgressMonitor monitor;
JET2Context context;
WorkspaceResourceSpecification resourceSpecification;
public Jet2Utils2(String transformId, Resource emfResource,
WorkspaceResourceSpecification resourceSpec, IProgressMonitor monitor)
this.transformId = transformId;
this.emfResource = emfResource;
this.monitor = monitor;
this.resourceSpecification = resourceSpec;
this.context = new JET2Context(null);
public void run()
IStatus status;
try
final IJETBundleDescriptor descriptor =
JET2Platform.getJETBundleManager()
.getDescriptor(transformId);
if(descriptor != null)
String fileType = descriptor.getModelExtension();
loadResourceAsSource(context, emfResource, fileType);
status = JET2Platform.runTransform(transformId, context, monitor);
LoggingSupport.handleStatus(Activator.getDefault(), status);
else
LoggingSupport.error(Activator.getDefault(), "Transform " +
transformId + " not found");
catch (IOException e)
// didn't work.
status = new Status(IStatus.ERROR, transformId, IStatus.OK,
e.getLocalizedMessage(), e);
catch (CoreJETException e)
public void loadResourceAsSource(JET2Context context,
String resourceType) throws CoreJETException,
IOException
context.setSource(emfResource);
try
//The only context variable I use at the momment
context.setVariable(WorkspaceContextExtender.VAR_RESOURCE_PR OJECT_NAME,
resourceSpecification.projectName);
catch (JET2TagException e)
LoggingSupport.error(Activator.getDefault(), "Invalid variable name",
e); // $NON-NLS
FUDForum. Page generated in 0.03127 seconds
