Home » Eclipse Projects » Nebula » GridTableViewer - layout problem
GridTableViewer - layout problem [message #57699] Tue, 12 August 2008 04:44 Go to next message
Originally posted by: paul.ruthven.synergy.net.au
I am trying to display a GridTableViewer in a View, together with a
Composite that contains other widgets. I am running into some formatting
problems that are driving me crazy.
The following simplified code illustrates my problem.
If I incorporate the code as is, I get a GridTableViewer that displays
scrollbars, and fills the view as I expect.
However, if I uncomment the code labelled "###UNCOMMENT" in an attempt to
display a Composite with a Label above the GridTableViewer, I run into
problems. The scrollbars disappear, and the GridTableViewer no longer
fills the entire width of the view.
Any help with this would be much appreciated.
None of the examples I've found online combine a GridTableViewer with
another Composite in a view.
Paul
package my_package;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.ITableColorProvider;
import org.eclipse.jface.viewers.ITableFontProvider;
import org.eclipse.jface.viewers.ITableLabelProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.Font;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.ui.part.ViewPart;
import org.eclipse.nebula.jface.gridviewer.GridTableViewer;
import org.eclipse.nebula.widgets.grid.GridColumn;
public class MyView extends ViewPart {
private GridTableViewer gridViewer;
public void createPartControl(Composite parent) {
//###UNCOMMENT
// parent.setLayout(new GridLayout(1, false));
// parent.setLayoutData(new GridData(GridData.FILL));
// Composite topComposite = new Composite(parent, SWT.NONE);
// topComposite.setLayout(new GridLayout(3, false));
// topComposite.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
// Label label = new Label(parent, SWT.LEFT);
// label.setText("Test Label");
Composite tableComposite = new Composite(parent, SWT.NONE);
tableComposite.setLayout(new FillLayout());
gridViewer =
new GridTableViewer(
tableComposite, SWT.V_SCROLL | SWT.H_SCROLL);
gridViewer.setLabelProvider(new ColumnLabelProvider());
gridViewer.setContentProvider(new TableContentProvider());
gridViewer.getGrid().setCellSelectionEnabled(true);
gridViewer.getGrid().setLinesVisible(true);
gridViewer.getGrid().setHeaderVisible(true);
GridColumn column1 = new GridColumn(gridViewer.getGrid(), SWT.NONE);
column1.setWidth(100);
column1.setText("Column 1");
GridColumn column2 = new GridColumn(gridViewer.getGrid(), SWT.NONE);
column2.setWidth(100);
column2.setText("Column 2");
gridViewer.setInput(this.getViewSite());
* Passing the focus request to the viewer's control.
public void setFocus() {
gridViewer.getControl().setFocus();
class ColumnLabelProvider extends LabelProvider implements
ITableLabelProvider, ITableFontProvider, ITableColorProvider {
public Image getColumnImage(Object element, int columnIndex) {
// TODO Auto-generated method stub
return null;
public String getColumnText(Object element, int columnIndex) {
if (element instanceof TableRow) {
switch (columnIndex) {
case 0:
return ((TableRow)element).getC1();
case 1:
return ((TableRow)element).getC2();
default:
return "TBD";
return "TBD";
public Font getFont(Object element, int columnIndex) {
return null;
public Color getBackground(Object element, int columnIndex) {
return null;
public Color getForeground(Object element, int columnIndex) {
return null;
class TableContentProvider implements IStructuredContentProvider {
private List<TableRow> tableRows;
public TableContentProvider() {
tableRows = new ArrayList<TableRow>();
for (int row=1; row<=100; row++) {
String c1 = "R" + row + " C1";
String c2 = "R" + row + " C2";
TableRow tableRow = new TableRow(c1, c2);
tableRows.add(tableRow);
public Object[] getElements(Object inputElement) {
System.out.println("getElements called - length = " + tableRows.size());
return tableRows.toArray();
public void dispose() {
public void inputChanged(Viewer viewer, Object oldInput, Object
newInput) {
class TableRow {
private String c1;
private String c2;
public TableRow(String c1, String c2) {
this.c1 = c1;
this.c2 = c2;
public String getC1() {
return c1;
public String getC2() {
return c2;
Re: GridTableViewer - layout problem [message #57724 is a reply to message #57699] Tue, 12 August 2008 04:50 Go to previous messageGo to next message
There was a typo in my previous example.
The following line:
Should be:
// Label label = new Label(topComposite, SWT.LEFT);
However, the problem I describe still exists. Any help gratefully
accepted.
Re: GridTableViewer - layout problem [message #57748 is a reply to message #57724] Tue, 12 August 2008 05:02 Go to previous messageGo to next message
I think you only have to set the
tableComposite.setLayoutData(new GridData(GridData.FILL_BOTH));
and everything works soomthly else the control will request as much
space as it needs to display itself with out scroll bars (this is no
different with SWT-Table I think)
Tom
> The following line:
> Should be:
> accepted.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: GridTableViewer - layout problem [message #57825 is a reply to message #57748] Tue, 12 August 2008 20:21 Go to previous messageGo to next message
Hi Tom,
I tried what you suggested (see following code), but unfortunately that
makes the Grid disappear altogether. The only thing that gets displayed
in the View now is the label "Test Label". Below that is a large blank
area.
Any more suggestions would be appreciated.
Paul
package my_package;
//###UNCOMMENT
// tableComposite.setLayout(new FillLayout());
gridViewer =
return null;
case 0:
case 1:
default:
return "TBD";
return "TBD";
return null;
return null;
return null;
newInput) {
class TableRow {
private String c1;
private String c2;
this.c1 = c1;
this.c2 = c2;
return c1;
return c2;
Re: GridTableViewer - layout problem [message #57846 is a reply to message #57825] Tue, 12 August 2008 20:52 Go to previous message
Hi Tom,
After further experimentation, I discovered that if I include both the
following lines, the Grid is displayed properly with scrollbars.
Sorry, I mis-understood your previous email. I didn't realise that you
can call setLayoutData with a GridData instance, whilst using a FillLayout.
Paul
Re: GridTableViewer - layout problem [message #591695 is a reply to message #57699] Tue, 12 August 2008 04:50 Go to previous message
The following line:
Should be:
accepted.
Re: GridTableViewer - layout problem [message #591704 is a reply to message #57724] Tue, 12 August 2008 05:02 Go to previous message
Tom
> The following line:
> Should be:
> accepted.
Re: GridTableViewer - layout problem [message #591732 is a reply to message #57748] Tue, 12 August 2008 20:21 Go to previous message
Hi Tom,
area.
Paul
package my_package;
//###UNCOMMENT
gridViewer =
return null;
case 0:
case 1:
default:
return "TBD";
return "TBD";
return null;
return null;
return null;
newInput) {
class TableRow {
private String c1;
private String c2;
this.c1 = c1;
this.c2 = c2;
return c1;
return c2;
Re: GridTableViewer - layout problem [message #591745 is a reply to message #57825] Tue, 12 August 2008 20:52 Go to previous message
Hi Tom,
Paul
Previous Topic:Grid: GridViewer selection service does not support cell selection
Next Topic:Grid: GridViewer selection service does not support cell selection
Current Time: Fri Jul 18 20:07:49 EDT 2025
Powered by FUDForum. Page generated in 0.04810 seconds
