Home » Modeling » TMF (Xtext) » Conversion from oaw to tmf xtext - Problem with MetaModelRegistration
Conversion from oaw to tmf xtext - Problem with MetaModelRegistration [message #57688] Mon, 13 July 2009 12:04 Go to next message
I try to convert an "old" oaw xtext project to tmf xtext.
In this project I work with dynamic EMF and use the generated class with
the name "MetaModelRegistration" for these purposes.
In the new generated stuff this class is not available anymore. I know I
could rewrite the java stuff based on the static EMF which is now
generated. But I would prefer to get an intermediate solution.
What can I do to handle this problem?
TIA
Martin
Re: Conversion from oaw to tmf xtext - Problem with MetaModelRegistration [message #57741 is a reply to message #57688] Mon, 13 July 2009 14:37 Go to previous messageGo to next message
The generated classes all inherit from EObject, so there shouldn't be a
problem using the reflective EObject API.
The MetaModelRegistration just made sure that the EPackage was put into
the EPackage.Registry.INSTANCE in standalone mode.
This is now done by the generated <MyLanguage>Setup class.
Sorry, if I didn't understand your question.
Sven
Martin Kuhn schrieb:
> TIA
> Martin
Re: Conversion from oaw to tmf xtext - Problem with MetaModelRegistration [message #58561 is a reply to message #57741] Tue, 14 July 2009 13:47 Go to previous message
Thanks for answering. I think this problem is solved.
Until now, we used OAW xtext intensively but without having a deep
understanding of internas.
BUT I realized that the migration is not an easy task. And without a
deeper knowledge it is a little bit tricky to solve the problems. (I get
tons of errors).
E.g. we had the following definition in our grammar:
String DataType:("string"|"integer"|"long"|...|"collection");
And changed to
Now we are not able to do a switch case with string on DataType Ref's:
e.g. the following doesn't work anymore
boolean isStringType(EntityAttribute this) :
// this.type points to a DataType
switch (this.type) {
case "string": true
case "text": true
default: false
How can I solve this problem?
Is there a documentation how to solve this kind of (common??) problems?
TIA
Martin
Previous Topic:No getter or adder for 'genmodels' (EcoreGeneratorFragment)
Next Topic:Re: Modifying Content assist, and notifying linking service
Current Time: Fri Jul 25 23:27:46 EDT 2025
Powered by FUDForum. Page generated in 0.24057 seconds
