Home » Eclipse Projects » Plugin Development Environment (PDE) » Creating an update site
| Creating an update site [message #57686] |
Wed, 22 April 2009 09:35  |
Originally posted by: tmothymarc.freenet.de
Hey all,
i've created an update site for my little prototyp feature. It consists
only of two plugins. After building it, the project structure was
adopted to /features, /plugins, ...
But how to go on? There is no export function like "Export update site".
I tried to select the site (from another distribution) directly in the
workspace, but than, i had no plugins to select for the installation,
just the category was shown. Hence, the "finish" button of the upate
manager wasn't enabled.
What am i doing wrong?
Thx Timothy
| Re: Creating an update site [message #57736 is a reply to message #57686] |
Wed, 22 April 2009 13:10   |
Timothy Marc wrote:
> Hey all,
When you configured the site, did you include any Features? Update sites
have to work with Features, not plugins directly.
Looking at the site.xml source, you should be able to see if the
feature(s) is referenced. Post the site.xml if you can't figure it out.
Actually, if you can host the entire generated site somewhere that we
can all see, that would help figure out where you went wrong.
Finally, make sure that you are not running into the issue with the
3.4.x Software Updates user interface that the checkbuttons at the
bottom of the Available Software tab are not hiding things from you.
Hope this helps,
Eric
| Re: Creating an update site [message #57837 is a reply to message #57736] |
Thu, 23 April 2009 04:03   |
Hey Eric,
okay, i will upload it. Is it enough to copy the project structure onto
a server? This is the information i didn't found in the web.
Thx
Timothy
Eric Rizzo schrieb:
> Timothy Marc wrote:
>> Hey all,
>> consists only of two plugins. After building it, the project structure
>> was adopted to /features, /plugins, ...
>> site". I tried to select the site (from another distribution)
>> directly in the workspace, but than, i had no plugins to select for
>> the installation, just the category was shown. Hence, the "finish"
>> button of the upate manager wasn't enabled.
> Hope this helps,
> Eric
| Re: Creating an update site [message #57930 is a reply to message #57837] |
Thu, 23 April 2009 11:39   |
Timothy Marc wrote:
> Hey Eric,
I'm not sure I understand the question, but the minimum requirements for
a valid update are are site.xml, features/, and plugins/.
> Eric Rizzo schrieb:
>> Timothy Marc wrote:
>>> Hey all,
>>> structure was adopted to /features, /plugins, ...
>> sites have to work with Features, not plugins directly.
>> Hope this helps,
>> Eric
| Re: Creating an update site [message #57954 is a reply to message #57930] |
Thu, 23 April 2009 11:46   |
Yes, but for plugins, products ond feature there are explicit export
functions, but not for an update site. Ist it enough to copy the project
structure onto a server or may i have to zip it or something else?
Timothy
Eric Rizzo schrieb:
> Timothy Marc wrote:
>> Hey Eric,
>> onto a server? This is the information i didn't found in the web.
>> Eric Rizzo schrieb:
>>> Timothy Marc wrote:
>>>> Hey all,
>>> Hope this helps,
>>> Eric
| Re: Creating an update site [message #58027 is a reply to message #57954] |
Thu, 23 April 2009 13:23   |
First you have to build the update site. Open site.xml in the default
editor (Site Manifest editor) and use the Build All button.
That will generate the plugins/ and features/ directory and also modify
the site.xml. You can then upload those files to your server.
You can read more in the Eclipse Help. Open Help Contents and navigate
to Plug-in Development Guide > Tools > Editors > Site Manifest Editor.
Hope this helps,
Eric
> Eric Rizzo schrieb:
>> Timothy Marc wrote:
>>> Hey Eric,
>> for a valid update are are site.xml, features/, and plugins/.
>>> Eric Rizzo schrieb:
>>>> Timothy Marc wrote:
>>>>> Hey all,
>>>> we can all see, that would help figure out where you went wrong.
>>>> Hope this helps,
>>>> Eric
| Re: Creating an update site [message #58102 is a reply to message #57686] |
Thu, 23 April 2009 17:53  |
Hi Tim,
I believe you solved it already but a small description on how to create
a update site can be found here:
http://www.vogella.de/articles/EclipseP2Update/article.html
Best regards, Lars
Timothy Marc wrote:
> Hey all,
> Thx Timothy
| Re: Creating an update site [message #596123 is a reply to message #57686] |
Timothy Marc wrote:
> Hey all,
Hope this helps,
Eric
| Re: Creating an update site [message #596177 is a reply to message #57736] |
Hey Eric,
Thx
Timothy
Eric Rizzo schrieb:
> Timothy Marc wrote:
>> Hey all,
> Hope this helps,
> Eric
| Re: Creating an update site [message #596222 is a reply to message #57837] |
Timothy Marc wrote:
> Hey Eric,
> Eric Rizzo schrieb:
>> Timothy Marc wrote:
>>> Hey all,
>> Hope this helps,
>> Eric
| Re: Creating an update site [message #596233 is a reply to message #57930] |
Timothy
Eric Rizzo schrieb:
> Timothy Marc wrote:
>> Hey Eric,
>> Eric Rizzo schrieb:
>>> Timothy Marc wrote:
>>>> Hey all,
>>> Hope this helps,
>>> Eric
| Re: Creating an update site [message #596276 is a reply to message #57954] |
Hope this helps,
Eric
> Eric Rizzo schrieb:
>> Timothy Marc wrote:
>>> Hey Eric,
>>> Eric Rizzo schrieb:
>>>> Timothy Marc wrote:
>>>>> Hey all,
>>>> Hope this helps,
>>>> Eric
| Re: Creating an update site [message #596302 is a reply to message #57686] |
Hi Tim,
Best regards, Lars
Timothy Marc wrote:
> Hey all,
> Thx Timothy
Current Time: Sun Nov 09 00:49:45 EST 2025
Powered by FUDForum. Page generated in 0.05263 seconds
