Home » Eclipse Projects » Plugin Development Environment (PDE) » Build updatesite doesn't create web/* and index.html
| Build updatesite doesn't create web/* and index.html [message #57633] |
Wed, 22 April 2009 03:39  |
Hi to everyone,
I tried to create an updatesite with one feature. This feature includes 3
plugins.
I tried to build it with the eclipse build-in opportunity (build suite).
After some really unpredictable and funny effects and errors,
today I can build the site.
The plugins and Feature-Jars are correctly build in the updatesite-path.
The only problem I still have, is, that the "web"-path and the index.html
are not created.
Can you help me to find out why it doesn't work and how I can manage to
do?
Thanks so far
Greetings
Markus
| Re: Build updatesite doesn't create web/* and index.html [message #57760 is a reply to message #57633] |
Wed, 22 April 2009 13:12   |
Markus Oley wrote:
> Hi to everyone,
> 3 plugins.
> After some really unpredictable and funny effects and errors, today I
> can build the site. The plugins and Feature-Jars are correctly build in
> the updatesite-path. The only problem I still have, is, that the
> "web"-path and the index.html are not created.
> Can you help me to find out why it doesn't work and how I can manage to do?
> Thanks so far
I'm not sure what you're expecting it to generate, but an update site
does not have any user-visible content, only site.xml, features/,
plugins/, and possibly some p2 metadata files.
What are you expecting beyond that?
Eric
| Re: Build updatesite doesn't create web/* and index.html [message #57977 is a reply to message #57861] |
Thu, 23 April 2009 11:48   |
Markus Oley wrote:
> Hi Eric,
> I did build the updatesite once and I got a index.html-file content.xml,
> artifacts.xml and an directory web, which includes site.css and
> site.xsl....
> Does an updatesite just work even if there are only plugins-path,
> features-path and the site.xml? I just thought, that the files, which
> are generated no more, are needed.
index.html and a web/ directory would be optional; only site.xml,
plugins/ and features/ are required.
I seem to remember an option somewhere to generate web content, but I
can't find it now.
Hope this helps,
Eric
| Re: Build updatesite doesn't create web/* and index.html [message #58052 is a reply to message #57977] |
Thu, 23 April 2009 13:25  |
Eric Rizzo wrote:
> Markus Oley wrote:
>> Hi Eric,
>> content.xml, artifacts.xml and an directory web, which includes
>> site.css and site.xsl....
> can't find it now.
The option is in the wizard when you create a new Update Site Project;
I'm not sure if it marks the project in any way so that those files are
re-generated automatically; you'd haven to create such a project and see
how it's .* files differ from the one you have.
Hope this helps,
Eric
| Re: Build updatesite doesn't create web/* and index.html [message #596135 is a reply to message #57633] |
Markus Oley wrote:
> Hi to everyone,
> 3 plugins.
> Thanks so far
Eric
| Re: Build updatesite doesn't create web/* and index.html [message #596184 is a reply to message #57760] |
Thu, 23 April 2009 04:51  |
Hi Eric,
site.xsl....
I just thought, that the files, which are generated no more, are needed.
Greetings
Markus
| Re: Build updatesite doesn't create web/* and index.html [message #596247 is a reply to message #57861] |
Markus Oley wrote:
> Hi Eric,
> site.xsl....
can't find it now.
Hope this helps,
Eric
| Re: Build updatesite doesn't create web/* and index.html [message #596284 is a reply to message #57977] |
Eric Rizzo wrote:
> Markus Oley wrote:
>> Hi Eric,
> can't find it now.
Hope this helps,
Eric
Current Time: Fri Nov 21 15:37:32 EST 2025
Powered by FUDForum. Page generated in 0.04241 seconds
