Home » Language IDEs » Java Development Tools (JDT) » -> Plugin referrences Project
-> Plugin referrences Project [message #57545] Sat, 14 June 2003 11:41 Go to next message
Hi there,
I ran into a problem. When we moved code from plugin to a normal project,
the plugin keeps complaining that it can not find the project's classes
when running. This is a problem while developing. On the normal use
we just create a *.jar file containing the required classes and add it
to the runtime libraries.
But how can I attach a normal project to a plugin's classpath?
Martin (Kersten)
Re: -> Plugin referrences Project [message #57663 is a reply to message #57545] Sat, 14 June 2003 21:14 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
You can't. Plugins can only use code in plugins. So you'll either have to
put those jars in their own plugins or inside the one you're running.
Ed Burnette, co-author Eclipse in Action (www.manning.com/gallardo)
"Martin Kersten" <Martin.Kersten@student.uni-magdeburg.de> wrote in message
news:bcffko$3da$1@rogue.oti.com...
Re: -> Plugin referrences Project [message #57740 is a reply to message #57663] Sun, 15 June 2003 04:20 Go to previous message
Ok solved that. The project becomes an empty plugin and the tomcat aspect
remains in a sourcefree *.server project. Works well.
Martin (Kersten)
"Ed Burnette" <ed.burnette@REMOVE.THIS.sas.com> schrieb im Newsbeitrag
news:bcgh9u$l71$1@rogue.oti.com...
message
Previous Topic:Method call hierarchy feature in M1
Next Topic:Debug and Run Configurations Speed Varies
Current Time: Sun Jul 13 20:09:38 EDT 2025
Powered by FUDForum. Page generated in 0.24065 seconds
