Home » Modeling » M2T (model-to-text transformation) » Special characters in the input model (jet with exemplars)
Special characters in the input model (jet with exemplars) [message #57523] Mon, 23 February 2009 15:35
Hi all,
I am using Jet with exemplars to generate code from uml model. I have a
template and I obtain information from Java classes.
I have found that there are some problems with some input attributes.
For instance, I can not define elements in the input model starting with
Upper case. How can then match input models with upper cases? Is there any
way to declare the inputs elements with Upper case?
Besides, I cannot define attributes with special characters like "_", but
I have input models with them, how can I declare them?
Finally, is there any problem with the attribute name 'href'? Is it a
reserved token? Is there anyway to specify names with the same name as
reserved tokens?
Any clue about any of the three questions is really welcomed.
Thanks a lot!!
Previous Topic:[Announce] M2T XPAND 0.7.0 I200902191437 is available
Next Topic:[JET2] c:addElement and EList / Array
Current Time: Sun Nov 02 01:44:43 EDT 2025
Powered by FUDForum. Page generated in 0.02893 seconds
