Home » Eclipse Projects » Nebula » GridTableViewer - JFace Databinding - Dates
GridTableViewer - JFace Databinding - Dates [message #57463] Mon, 11 August 2008 05:16 Go to next message
Hello there.
Is there a way to change the display format of a Date or Calendar object
in the GridTableViewer. Right now it seems that a date.toString() is done.
How can this value be displayed in a locale specific format?
Thanks in advance.
Peter
Re: GridTableViewer - JFace Databinding - Dates [message #57488 is a reply to message #57463] Mon, 11 August 2008 05:33 Go to previous messageGo to next message
You need to set your own ColumnLabelProvider#getText(Object) or
ITableLabelProvider#getText(int,Object) and check the instance for Date
and use SimpleDateFormat. The default LabelProvider always simply calls
the given objects toString method.
Tom
Peter Pfeifer schrieb:
> Hello there.
> Thanks in advance.
> Peter
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: GridTableViewer - JFace Databinding - Dates [message #57513 is a reply to message #57488] Mon, 11 August 2008 05:41 Go to previous messageGo to next message
Sorry i didn't read the header correctly you are using an
ObservableLabelProvider right? Which automatically does a toString().
I've written custom ones who are using MessageFormat. You can fetch them
http://publicsvn.bestsolution.at/repos/java/at.bestsolution. dataforms/trunk/src/at/bestsolution/dataforms/util/viewers/
With this you can write something like this:
new GenericObservableMapCellLabelProvider(obsMap,"{0,short,date} ");
If you are using EMF I've written even better ones who also support
..-notation when you want to access nested attribute (but it depends on
org.apache.lang and the use of EObject):
http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.common/src/at/bestsolutio n/soccer/ui/common/viewers/ObservableColumnLabelProvider.jav a
new ObservableColumnLabelProvider(map,"${0} (${1.name})
See
http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.associationadmin/src/at/b estsolution/soccer/ui/associationadmin/AssociationAdministra tionViewPart.java
Method: createTreeViewer how to use it you could easily customize it to
use JavaBean lookup.
Tom
> Tom
>> Hello there.
>> object in the GridTableViewer. Right now it seems that a
>> Thanks in advance.
>> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #57537 is a reply to message #57513] Mon, 11 August 2008 06:08 Go to previous messageGo to next message
Hi Tom.
Thanks that helped me a lot!
Are there any new changes on the grid/gridviewer itself? You posted a
very cool screenshot a few weeks ago. Are these changes on the
grid/gridviewer?
Peter
> from:
> See
> Tom
>> Date and use SimpleDateFormat. The default LabelProvider always simply
>> calls the given objects toString method.
>> Tom
>>> Hello there.
>>> Thanks in advance.
>>> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #57562 is a reply to message #57537] Mon, 11 August 2008 06:12 Go to previous messageGo to next message
Hi Peter,
No not yet. I'm currently maintaining a fork locally until I've finished
my work completely (I was only holiday the last 4 weeks) and then merge
it back to nebula. There are still some minor issues with the
Header-Controls.
I'll post a message when the sources are available.
Tom
> Hi Tom.
> grid/gridviewer?
> Peter
>> them from:
>> See
>> to use JavaBean lookup.
>> Tom
>>> simply calls the given objects toString method.
>>> Tom
>>>> Hello there.
>>>> Thanks in advance.
>>>> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #57612 is a reply to message #57562] Mon, 11 August 2008 06:24 Go to previous messageGo to next message
Hi.
That's good news. I eagerly waiting for it.
Thanks for all your work!
Peter
> Hi Peter,
> Header-Controls.
> Tom
>> Hi Tom.
>> grid/gridviewer?
>> Peter
>>> them from:
>>> on org.apache.lang and the use of EObject):
>>> See
>>> Tom
>>>> Tom
>>>>> Hello there.
>>>>> Thanks in advance.
>>>>> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #57637 is a reply to message #57612] Mon, 11 August 2008 13:28 Go to previous messageGo to next message
Hope you don't mind a little thread hijack (Peter said it was ok ;) ),
Tom, do you know the status on the GridViewer in SWT.VIRTUAL? I see the
source has a bunch of TODO's listed for it. I'm not sure what's involved,
but as the grid seems to work really well in normal SWT.VIRTUAL without a
viewer, it seems it's almost there (?). I would really love a virtual
viewer!
Any ideas?
Emil
"Peter Pfeifer" <peter.pfeifer@mic-cust.com> wrote in message
news:g7p403$gh2$1@build.eclipse.org...
> Hi.
> Peter
>> Hi Peter,
>> Header-Controls.
>> Tom
>>> Hi Tom.
>>> grid/gridviewer?
>>> Peter
>>>> them from:
>>>> See
>>>> Tom
>>>>> Tom
>>>>>> Hello there.
>>>>>> Thanks in advance.
>>>>>> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #57680 is a reply to message #57637] Mon, 11 August 2008 15:24 Go to previous message
Hi Emil,
Frankly I don't know when I finished my current work (with the
header/footer stuff) I can take a look into it. I'd also like to
introduce a feature to pool images and dispose them for rows not visible
this should make it possible for the Grid to deal with thousands of
different images.
Tom
> viewer!
> Any ideas?
> Emil
>> Hi.
>> Peter
>>> Hi Peter,
>>> Header-Controls.
>>> Tom
>>>> Hi Tom.
>>>> grid/gridviewer?
>>>> Peter
>>>>> them from:
>>>>> See
>>>>> Tom
>>>>>> Tom
>>>>>>> Hello there.
>>>>>>> Thanks in advance.
>>>>>>> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #591630 is a reply to message #57463] Mon, 11 August 2008 05:33 Go to previous message
Tom
> Hello there.
> Thanks in advance.
> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #591639 is a reply to message #57488] Mon, 11 August 2008 05:41 Go to previous message
See
Tom
> Tom
>> Hello there.
>> Thanks in advance.
>> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #591647 is a reply to message #57513] Mon, 11 August 2008 06:08 Go to previous message
Hi Tom.
grid/gridviewer?
Peter
> from:
> See
> Tom
>> Tom
>>> Hello there.
>>> Thanks in advance.
>>> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #591650 is a reply to message #57537] Mon, 11 August 2008 06:12 Go to previous message
Hi Peter,
Header-Controls.
Tom
> Hi Tom.
> grid/gridviewer?
> Peter
>> them from:
>> See
>> Tom
>>> Tom
>>>> Hello there.
>>>> Thanks in advance.
>>>> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #591660 is a reply to message #57562] Mon, 11 August 2008 06:24 Go to previous message
Hi.
Peter
> Hi Peter,
> Header-Controls.
> Tom
>> Hi Tom.
>> grid/gridviewer?
>> Peter
>>> them from:
>>> See
>>> Tom
>>>> Tom
>>>>> Hello there.
>>>>> Thanks in advance.
>>>>> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #591669 is a reply to message #57612] Mon, 11 August 2008 13:28 Go to previous message
viewer!
Any ideas?
Emil
> Hi.
> Peter
>> Hi Peter,
>> Header-Controls.
>> Tom
>>> Hi Tom.
>>> grid/gridviewer?
>>> Peter
>>>> them from:
>>>> See
>>>> Tom
>>>>> Tom
>>>>>> Hello there.
>>>>>> Thanks in advance.
>>>>>> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #591676 is a reply to message #57637] Mon, 11 August 2008 15:24 Go to previous message
Hi Emil,
different images.
Tom
> viewer!
> Any ideas?
> Emil
>> Hi.
>> Peter
>>> Hi Peter,
>>> Header-Controls.
>>> Tom
>>>> Hi Tom.
>>>> grid/gridviewer?
>>>> Peter
>>>>> them from:
>>>>> See
>>>>> Tom
>>>>>> Tom
>>>>>>> Hello there.
>>>>>>> Thanks in advance.
>>>>>>> Peter
Previous Topic:GridTableViewer - JFace Databinding - Dates
Next Topic:GridTableViewer - layout problem
Current Time: Wed Nov 05 18:18:13 EST 2025
Powered by FUDForum. Page generated in 0.05669 seconds
