Home » Language IDEs » ServerTools (WTP) » Where is the XML editor?
Where is the XML editor? [message #57429] Thu, 23 December 2004 06:37 Go to next message
Hello everyone,
I've just installed the brand new WTP M2 on top of Eclipse 3.1 M4
running on Windows XP SP2. I also followed the instructions for XML
validation (installing Xerces 2.6.2).
Unfortunately I can't find the XML editor/validator. XML files (and
HTML/HTM/GIF/JPG) now open in the internal Web Browser, which is not
very helpful.
I searched every menu, perspective and project type. The only new XML
related entry I could find is the new "XML Catalog" preferences page. I
uninstalled WTP M1 for a similar problem, but this time the XML editor
is part of the High Priority items on the milestone plan
( http://www.eclipse.org/webtools/downloads.html#milestonebuil dnotes).
Andreas
Re: Where is the XML editor? [message #57756 is a reply to message #57429] Thu, 23 December 2004 13:28 Go to previous messageGo to next message
Andreas Schildbach wrote:
> Hello everyone,
> very helpful.
> Andreas
Andreas,
The XML editor should be available. Create a project and then create an
XML file in it, e.g. test.xml. You should see XML show up in the New
wizard. If you right-click your test.xml file, you should see a pop-up
action to Validate XML File.
-- Arthur
Re: Where is the XML editor? [message #57854 is a reply to message #57756] Thu, 23 December 2004 18:30 Go to previous messageGo to next message
I'm sorry, but this isn't happening. I tried both creating XML files in
my Java project and in simple projects. No XML in new file wizard. No
Validate XML context menu entry on XML files. Something seems to be
wrong, although Eclipse claims that J2EE Standard Tools Feature 1.0.0
and Web Standard Tools Feature 1.0.0 are installed.
Andreas
Re: Where is the XML editor? [message #57881 is a reply to message #57854] Thu, 23 December 2004 20:43 Go to previous messageGo to next message
--------------050202030408090109040504
Hi Andreas,
It's possible if you have other XML editing plug-ins installed. Having
the XMLBuddy and the SolarEclipse I got the same problem. But after
wiping them everything is all right. You'll need to download and install
the Xerces XML parser. Details you'll see in the dialog box which will
pop-up once you gonna try to validate any XML.
Moreover, XML editor not only works as declared, the validator really
helps to find bugs (see attachment).
Anyway, I've found a bug (or is it a kinda feature, guys??) in the XML
editor. After one corrected error, the error mark remains visible until
you run validation again.
Dimos
Content-Type: image/jpeg;
name="Untitled-1.jpg"
Content-Disposition: inline;
filename="Untitled-1.jpg"
/9j/4AAQSkZJRgABAgEASABIAAD/4QvvRXhpZgAATU0AKgAAAAgABwESAAMA AAABAAEAAAEa
AAUAAAABAAAAYgEbAAUAAAABAAAAagEoAAMAAAABAAIAAAExAAIAAAAbAAAA cgEyAAIAAAAU
AAAAjYdpAAQAAAABAAAApAAAANAAAABIAAAAAQAAAEgAAAABQWRvYmUgUGhv dG9zaG9wIENT
IFdpbmRvd3MAMjAwNDoxMjoyNCAwNDozNDo0OQAAAAAAA6ABAAMAAAABAAEA AKACAAQAAAAB
AAABuaADAAQAAAABAAAAkQAAAAAAAAAGAQMAAwAAAAEABgAAARoABQAAAAEA AAEeARsABQAA
AAEAAAEmASgAAwAAAAEAAgAAAgEABAAAAAEAAAEuAgIABAAAAAEAAAq5AAAA AAAAAEgAAAAB
AAAASAAAAAH/2P/gABBKRklGAAECAQBIAEgAAP/tAAxBZG9iZV9DTQAB/+4A DkFkb2JlAGSA
AAAAAf/bAIQADAgICAkIDAkJDBELCgsRFQ8MDA8VGBMTFRMTGBEMDAwMDAwR DAwMDAwMDAwM
DAwMDAwMDAwMDAwMDAwMDAwMDAENCwsNDg0QDg4QFA4ODhQUDg4ODhQRDAwM DAwREQwMDAwM
DBEMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwM/8AAEQgANQCgAwEiAAIR AQMRAf/dAAQA
Cv/EAT8AAAEFAQEBAQEBAAAAAAAAAAMAAQIEBQYHCAkKCwEAAQUBAQEBAQEA AAAAAAAAAQAC
AwQFBgcICQoLEAABBAEDAgQCBQcGCAUDDDMBAAIRAwQhEjEFQVFhEyJxgTIG FJGhsUIjJBVS
wWIzNHKC0UMHJZJT8OHxY3M1FqKygyZEk1RkRcKjdDYX0lXiZfKzhMPTdePz RieUpIW0lcTU
5PSltcXV5fVWZnaGlqa2xtbm9jdHV2d3h5ent8fX5/cRAAICAQIEBAMEBQYH BwYFNQEAAhED
ITESBEFRYXEiEwUygZEUobFCI8FS0fAzJGLhcoKSQ1MVY3M08SUGFqKygwcm NcLSRJNUoxdk
RVU2dGXi8rOEw9N14/NGlKSFtJXE1OT0pbXF1eX1VmZ2hpamtsbW5vYnN0dX Z3eHl6e3x//a
AAwDAQACEQMRAD8Ao9b6x1CvM6lXV1LqVWTXm5Taq633ek1jbHNxqa62uDG0 f8L/ANb/AMF+
lfH6pj2G11v1h6zQwsaKa3HJseHuYy11rn1tqY9uPY92H6P/AGo9L7R6tTH1 L0a3IfX6jnWm
uuuS5zn7WtaPznOcQ1jUDG6rj5hc3EzW3uYJc1jyXAfvbDtds/lqb70NBwAa d/8A0FXtSIsX
wx3NaC/3i8J+0aNSPrH1fUsa1o+0kNAYz17nOcxvrOfd6uzHb6P/AB3sQ7Oq WVa19e6tlfo7
SWfp6/0oYTita8j3Vuu9lv8AN/8AWV6Icl4cGuu2udo1pfBPb2NLtzlJ1t7f pWObpPucRoOT
7il95H7n4x/9VrTj8XhH51Ixw1n1k6s/I3a2CvI27TsbHp2em39F+ks/0l30 FTyus9WGXc3C
6j1B2IHD0XPtvLi3a2d28Vu/nN/+DYvRjfYASbSA3VxL9BA3e7X2+1IW3EAh 7iHCWkOJBHi3
95Ic0B/k78zH/vEHF/Wr+X9584b1nr/fOzv+3LUVvV+ud87N/wC3LV6HuyIn c+PGTGqY2WgS
XuAJAkkjU6NH9pH72P8AND7f/QUeyf3y8E3q3W/+5uZ/25ait6p1n/uZl/8A bli7c3PAJdYQ
GzuJdAG3R+5xPt2fnp910TLo8ZMapfeh/mh9v/oKvZP75eMb1Pq/fLyv8+xF b1Hqv/crJ/z7
F1260iQXEcSCSNDtOv8AWTNe9zQ9ri5jo2vaZaZOxu149rtz/Yh96H+aH2/+ gq9k/vl5dvUO
p98nI/z3orc7qP8A3IyP8966QG1zdzS5zTwRJH3hL9LMe6eI1S+8j/Nj7f8A 0FXsn98uA3Mz
+99/+c9Fbl5ve+7/ADnLZLnt+kSNQNTGpO1rdf3nHakfUEgyI1Mzwh95H+bH 2/8AoKvZP75c
tuTl/wCmt/znIrcjJ/0tn+c5XwXOALTuDgC0gyCDwWx9JMCSSAZIdtInXd+5 /X/kJfeB/mx9
v/oKvZP75awuyD/hHz29xVLP6hmWPzKaz+plr21ObXcHloqs+0evZb+ibVv/ AJh7P5z/AAnp
/oPtGsdw0Mj4oOcT9gy9f+093/nt6ZPMJV6eGux/sXRxmN+q77h//9Db+txy Q3BFYrNBzB64
u0qLgW/Zhlat/V/6R6ixM1+Dj34V31fNe5uS6YJN/qztNbd217+lvqdto/fZ 632ldrfXXaLK
rWNsqfIfW8S1wnhzSqOF0Lo+Bd6+JjBlv5r3Oe8tn/R+s5+xV54uKfFfb+8O H9x1OW+Ixw8s
cJgTKpgUf1WT3o8P9Ij+n7f6Cus29Kqc09QnZW19jRtDmlgfSbGuc4fv10Mf X+ey7/CLJqv6
I/DGKX5NovfXewPdW+wvcLKHNd6jtvpY/p2+s69ldeSz/gfS9bpe0dvA6hMY MyAZ50Hcbf8A
qVK5rhYh6D9mzKaHXfY8mtt97HsDwA2r12ubad9z7X4mLv8ARt/0f6T0LfTq Q6ndDpwixt2Z
6LbGW73tBdNfqUNY1rvZb73PZtZW/wDwP85i0rop8NJJJjxPJTaaaD2/R0Gk ae391JTmO6X0
7PdddufFj7BdUdh/SC21799bxZsd6h9Pa7+excfGou9lSJndGxs611lt19e+ z1XNqeGjdDW+
zc1zq272+t7P8O/1VfgDgAfDRJJTWZgVMwnYQcTUS5w9rBtLn/afZXWxlbdt /vZ+4g0dExaL
Tb6t9u5tjHNsfuBFrXVv3aN9217v6/6L/QVq+kkpz6Oh4dFlb63WN9Nj69gL Wsd6gsa+x1TG
tZ6m27Z/xdWPX/gUzugYJADXWNAc15B22S5npbd/rNf7Xuo3XV/4b/MWikkp zKvq7g1CBbe/
QhrnvBc2fzmu2/T3f4T/AIv/AEaJkdFxsiupjrbm+gxtbSxwaCGbvc+sN9Pc 7ft/7bV9JJTS
PR8R1FlDnWvZZYy0eo/1Cw1lxpbV6odsrZuU6em00tx2sssAxrn5A1b73P3b mW+3+Za1+yqq
vZsp/Qq0kkpz8boeHjUuqre926oUb3hjnbGuZY1pOz3s31/pKn/obvU9P0/T Uv2LgFlLC0uF
DrHtLg0uLrnMttc92z6Xq1VP3fyFeSSUgwcOvCxxj1vstaHF2+1255Jge539 n+3Z+l/wifN/
oGX/AOF7v/Pb0ZBzf6Bl/wDhe7/z29JT/9Ht3/Td8T+VRUn/AE3fE/lUUxcp JJJJSkkkklKS
SSSUpJJJJSkkkklKSSSSUpKQASeACT8kkiJBExIIn4hJTWry8ixjXtxpDgDp Y88idu5uLt9q
Z2c9jxW+ljHuG4Nda4Eidu6HYv7yrU2deqqbWOm0kNAEnLZPHkwIOTj9Uy3b sjpVLxLHFozG
hpfUS6i10M3epTvfs9//AHxFDojJySARiyCJBD38H/0EQbM316ep4zqjVZi4 xL/cXA+tVk7W
+6ul7XM+z+/2fnqP2n6wd+nUE9yctsnzPsQq6M5rOs5eZSzHOVjgMrZaLf5q rL9QlzWt2/z9
e1JT/9LsH25m936tXyf+1B8f/Cib1cz/ALjV/wDsQf8A3kXz2kmpfoT1cz/u NX/7EH/3kS9X
M/7jV/8AsQf/AHkXz2kkp+hPVzP+41f/ALEH/wB5EvVzP+41f/sQf/eRfPaS Sn6E9XM/7jV/
+xB/95EvVzP+41f/ALEH/wB5F89pJKfoT1cz/uNX/wCxB/8AeRL1cz/uNX/7 EH/3kXz2kkp+
hPVzP+41f/sQf/eRL1cz/uNX/wCxB/8AeRfPaSSn6E9XM/7jV/8AsQf/AHkS 9XM/7jV/+xB/
95F89pJKfoT1cz/uNX/7EH/3kS9XM/7jV/8AsQf/AHkXz2kkp+hPVzP+41f/ ALEH/wB5EvVz
P+41f/sQf/eRfPaSSn6E9XM/7jV/+xB/95EHNszPsOVOPWB6Fsn1yYHpvn2/ ZWrwFJJT/9n/
7RCqUGhvdG9zaG9wIDMuMAA4QklNBCUAAAAAABAAAAAAAAAAAAAAAAAAAAAA OEJJTQPtAAAA
AAAQAEgAAAABAAIASAAAAAEAAjhCSU0EJgAAAAAADgAAAAAAAAAAAAA/gAAA OEJJTQQNAAAA
AAAEAAAAeDhCSU0EGQAAAAAABAAAAB44QklNA/MAAAAAAAkAAAAAAAAAAAEA OEJJTQQKAAAA
AAABAAA4QklNJxAAAAAAAAoAAQAAAAAAAAACOEJJTQP1AAAAAABIAC9mZgAB AGxmZgAGAAAA
AAABAC9mZgABAKGZmgAGAAAAAAABADIAAAABAFoAAAAGAAAAAAABADUAAAAB AC0AAAAGAAAA
AAABOEJJTQP4AAAAAABwAAD/////////////////////////////A+gAAAAA ////////////
/////////////////wPoAAAAAP////////////////////////////8D6AAA AAD/////////
////////////////////A+gAADhCSU0EAAAAAAAAAgABOEJJTQQCAAAAAAAE AAAAADhCSU0E
CAAAAAAAEAAAAAEAAAJAAAACQAAAAAA4QklNBB4AAAAAAAQAAAAAOEJJTQQa AAAAAANJAAAA
BgAAAAAAAAAAAAAAkQAAAbkAAAAKAFUAbgB0AGkAdABsAGUAZAAtADEAAAAB AAAAAAAAAAAA
AAAAAAAAAAAAAAEAAAAAAAAAAAAAAbkAAACRAAAAAAAAAAAAAAAAAAAAAAEA AAAAAAAAAAAA
AAAAAAAAAAAAEAAAAAEAAAAAAABudWxsAAAAAgAAAAZib3VuZHNPYmpjAAAA AQAAAAAAAFJj
dDEAAAAEAAAAAFRvcCBsb25nAAAAAAAAAABMZWZ0bG9uZwAAAAAAAAAAQnRv bWxvbmcAAACR
AAAAAFJnaHRsb25nAAABuQAAAAZzbGljZXNWbExzAAAAAU9iamMAAAABAAAA AAAFc2xpY2UA
AAASAAAAB3NsaWNlSURsb25nAAAAAAAAAAdncm91cElEbG9uZwAAAAAAAAAG b3JpZ2luZW51
bQAAAAxFU2xpY2VPcmlnaW4AAAANYXV0b0dlbmVyYXRlZAAAAABUeXBlZW51 bQAAAApFU2xp
Y2VUeXBlAAAAAEltZyAAAAAGYm91bmRzT2JqYwAAAAEAAAAAAABSY3QxAAAA BAAAAABUb3Ag
bG9uZwAAAAAAAAAATGVmdGxvbmcAAAAAAAAAAEJ0b21sb25nAAAAkQAAAABS Z2h0bG9uZwAA
AbkAAAADdXJsVEVYVAAAAAEAAAAAAABudWxsVEVYVAAAAAEAAAAAAABNc2dl VEVYVAAAAAEA
AAAAAAZhbHRUYWdURVhUAAAAAQAAAAAADmNlbGxUZXh0SXNIVE1MYm9vbAEA AAAIY2VsbFRl
eHRURVhUAAAAAQAAAAAACWhvcnpBbGlnbmVudW0AAAAPRVNsaWNlSG9yekFs aWduAAAAB2Rl
ZmF1bHQAAAAJdmVydEFsaWduZW51bQAAAA9FU2xpY2VWZXJ0QWxpZ24AAAAH ZGVmYXVsdAAA
AAtiZ0NvbG9yVHlwZWVudW0AAAARRVNsaWNlQkdDb2xvclR5cGUAAAAATm9u ZQAAAAl0b3BP
dXRzZXRsb25nAAAAAAAAAApsZWZ0T3V0c2V0bG9uZwAAAAAAAAAMYm90dG9t T3V0c2V0bG9u
ZwAAAAAAAAALcmlnaHRPdXRzZXRsb25nAAAAAAA4QklNBCgAAAAAAAwAAAAB P/AAAAAAAAA4
QklNBBQAAAAAAAQAAAACOEJJTQQMAAAAAArVAAAAAQAAAKAAAAA1AAAB4AAA Y2AAAAq5ABgA
Af/Y/+AAEEpGSUYAAQIBAEgASAAA/+0ADEFkb2JlX0NNAAH/7gAOQWRvYmUA ZIAAAAAB/9sA
hAAMCAgICQgMCQkMEQsKCxEVDwwMDxUYExMVExMYEQwMDAwMDBEMDAwMDAwM DAwMDAwMDAwM
DAwMDAwMDAwMDAwMAQ0LCw0ODRAODhAUDg4OFBQODg4OFBEMDAwMDBERDAwM DAwMEQwMDAwM
DAwMDAwMDAwMDAwMDAwMDAwMDAwMDAz/wAARCAA1AKADASIAAhEBAxEB/90A BAAK/8QBPwAA
AQUBAQEBAQEAAAAAAAAAAwABAgQFBgcICQoLAQABBQEBAQEBAQAAAAAAAAAB AAIDBAUGBwgJ
CgsQAAEEAQMCBAIFBwYIBQMMMwEAAhEDBCESMQVBUWETInGBMgYUkaGxQiMk FVLBYjM0coLR
QwclklPw4fFjczUWorKDJkSTVGRFwqN0NhfSVeJl8rOEw9N14/NGJ5SkhbSV xNTk9KW1xdXl
9VZmdoaWprbG1ub2N0dXZ3eHl6e3x9fn9xEAAgIBAgQEAwQFBgcHBgU1AQAC EQMhMRIEQVFh
cSITBTKBkRShsUIjwVLR8DMkYuFygpJDUxVjczTxJQYWorKDByY1wtJEk1Sj F2RFVTZ0ZeLy
s4TD03Xj80aUpIW0lcTU5PSltcXV5fVWZnaGlqa2xtbm9ic3R1dnd4eXp7fH /9oADAMBAAIR
AxEAPwCj1vrHUK8zqVdXUupVZNeblNqrrfd6TWNsc3Gprra4MbR/wv8A1v8A wX6V8fqmPYbX
W/WHrNDCxoprccmx4e5jLXWufW2pj249j3Yfo/8Aaj0vtHq1MfUvRrch9fqO daa665LnOfta
1o/Oc5xDWNQMbquPmFzcTNbe5glzWPJcB+9sO12z+WpvvQ0HABp3/wDQVe1I ixfDHc1oL/eL
wn7Ro1I+sfV9SxrWj7SQ0BjPXuc5zG+s593q7Mdvo/8AHexDs6pZVrX17q2V +jtJZ+nr/Shh
OK1ryPdW672W/wA3/wBZXohyXhwa67a52jWl8E9vY0u3OUnW3t+lY5uk+5xG g5PuKX3kfufj
H/1WtOPxeEfnUjHDWfWTqz8jdrYK8jbtOxsenZ6bf0X6Sz/SXfQVPK6z1YZd zcLqPUHYgcPR
c+28uLdrZ3bxW7+c3/4Ni9GN9gBJtIDdXEv0EDd7tfb7UhbcQCHuIcJaQ4kE eLf3khzQH+Tv
zMf+8QcX9av5f3nzhvWev987O/7ctRW9X653zs3/ALctXoe7Iidz48ZMapjZ aBJe4AkCSSNT
o0f2kfvY/wA0Pt/9BR7J/fLwTerdb/7m5n/blqK3qnWf+5mX/wBuWLtzc8Al 1hAbO4l0AbdH
7nE+3Z+en3XRMujxkxql96H+aH2/+gq9k/vl4xvU+r98vK/z7EVvUeq/9ysn /PsXXbrSJBcR
xIJI0O06/wBZM173ND2uLmOja9plpk7G7Xj2u3P9iH3of5ofb/6Cr2T++Xl2 9Q6n3ycj/Pei
tzuo/wDcjI/z3rpAbXN3NLnNPBEkfeEv0sx7p4jVL7yP82Pt/wDQVeyf3y4D czP733/5z0Vu
Xm977v8AOctkue36RI1A1Mak7Wt1/ecdqR9QSDIjUzPCH3kf5sfb/wCgq9k/ vly25OX/AKa3
/OcityMn/S2f5zlfBc4AtO4OALSDIIPBbH0kwJJIBkh20idd37n9f+Ql94H+ bH2/+gq9k/vl
rC7IP+EfPb3FUs/qGZY/MprP6mWvbU5tdweWiqz7R69lv6JtW/8AmHs/nP8A Cen+g+0ax3DQ
yPig5xP2DL1/7T3f+e3pk8wlXp4a7H+xdHGY36rvuH//0Nv63HJDcEVis0HM Hri7SouBb9mG
Vq39X/pHqLEzX4OPfhXfV817m5Lpgk3+rO01t3bXv6W+p22j99nrfaV2t9dd osqtY2yp8h9b
xLXCeHNKo4XQuj4F3r4mMGW/mvc57y2f9H6zn7FXni4p8V9v7w4f3HU5b4jH DyxwmBMqmBR/
VZPejw/0iP6ft/oK6zb0qpzT1CdlbX2NG0OaWB9Jsa5zh+/XQx9f57Lv8Ism q/oj8MYpfk2i
99d7A91b7C9wsoc13qO2+lj+nb6zr2V15LP+B9L1ul7R28DqExgzIBnnQdxt /wCpUrmuFiHo
P2bMpodd9jya233sewPADavXa5tp33PtfiYu/wBG3/R/pPQt9OpDqd0OnCLG 3ZnotsZbve0F
01+pQ1jWu9lvvc9m1lb/APA/zmLSuinw0kkmPE8lNppoPb9HQaRp7f3UlOY7 pfTs911258WP
sF1R2H9ILbXv31vFmx3qH09rv57Fx8ai72VImd0bGzrXWW3X177PVc2p4aN0 Nb7NzXOrbvb6
3s/w7/VV+AOAB8NEklNZmBUzCdhBxNRLnD2sG0uf9p9ldbGVt23+9n7iDR0T FotNvq327m2M
c2x+4EWtdW/do33bXu/r/ov9BWr6SSnPo6Hh0WVvrdY302Pr2Atax3qCxr7H VMa1nqbbtn/F
1Y9f+BTO6BgkANdY0BzXkHbZLmelt3+s1/te6jddX/hv8xaKSSnMq+ruDUIF t79CGue8FzZ/
Oa7b9Pd/hP8Ai/8ARomR0XGyK6mOtub6DG1tLHBoIZu9z6w309zt+3/ttX0k lNI9HxHUWUOd
a9lljLR6j/ULDWXGltXqh2ytm5Tp6bTS3HayywDGufkDVvvc/duZb7f5lrX7 Kqq9myn9CrSS
SnPxuh4eNS6qt73bqhRveGOdsa5ljWk7PezfX+kqf+hu9T0/T9NS/YuAWUsL S4UOse0uDS4u
ucy21z3bPperVU/d/IV5JJSDBw68LHGPW+y1ocXb7XbnkmB7nf2f7dn6X/CJ 83+gZf8A4Xu/
89vRkHN/oGX/AOF7v/Pb0lP/0e3f9N3xP5VFSf8ATd8T+VRTFykkkklKSSSS UpJJJJSkkkkl
KSSSSUpJJJJSkpABJ4AJPySSIkETEgifiElNavLyLGNe3GkOAOljzyJ27m4u 32pnZz2PFb6W
Me4bg11rgSJ27odi/vKtTZ16qptY6bSQ0ASctk8eTAg5OP1TLduyOlUvEscW jMaGl9RLqLXQ
zd6lO9+z3/8AfEUOiMnJIBGLIIkEPfwf/QRBszfXp6njOqNVmLjEv9xcD61W Ttb7q6Xtcz7P
7/Z+eo/afrB36dQT3Jy2yfM+xCrozms6zl5lLMc5WOAytlot/mqsv1CXNa3b /P17UlP/0uwf
bmb3fq1fJ/7UHx/8KJvVzP8AuNX/AOxB/wDeRfPaSal+hPVzP+41f/sQf/eR L1cz/uNX/wCx
B/8AeRfPaSSn6E9XM/7jV/8AsQf/AHkS9XM/7jV/+xB/95F89pJKfoT1cz/u NX/7EH/3kS9X
95F89pJKfoT1cz/uNX/7EH/3kQc2zM+w5U49YHoWyfXJgem+fb9lavAUklP/ 2QA4QklNBCEA
AAAAAFMAAAABAQAAAA8AQQBkAG8AYgBlACAAUABoAG8AdABvAHMAaABvAHAA AAASAEEAZABv
AGIAZQAgAFAAaABvAHQAbwBzAGgAbwBwACAAQwBTAAAAAQA4QklNBAYAAAAA AAcABQAAAAEB
AP/hF/podHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvADw/eHBhY2tldCBi ZWdpbj0n77u/
JyBpZD0nVzVNME1wQ2VoaUh6cmVTek5UY3prYzlkJz8+Cjx4OnhtcG1ldGEg eG1sbnM6eD0n
YWRvYmU6bnM6bWV0YS8nIHg6eG1wdGs9J1hNUCB0b29sa2l0IDMuMC0yOCwg ZnJhbWV3b3Jr
IDEuNic+CjxyZGY6UkRGIHhtbG5zOnJkZj0naHR0cDovL3d3dy53My5vcmcv MTk5OS8wMi8y
Mi1yZGYtc3ludGF4LW5zIycgeG1sbnM6aVg9J2h0dHA6Ly9ucy5hZG9iZS5j b20vaVgvMS4w
Lyc+CgogPHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9J3V1aWQ6YzFjNzY3 MWEtNTU0Ny0x
MWQ5LTkyNWMtZTU3MWQ4ZjM1NmUwJwogIHhtbG5zOmV4aWY9J2h0dHA6Ly9u cy5hZG9iZS5j
b20vZXhpZi8xLjAvJz4KICA8ZXhpZjpDb2xvclNwYWNlPjE8L2V4aWY6Q29s b3JTcGFjZT4K
ICA8ZXhpZjpQaXhlbFhEaW1lbnNpb24+NDQxPC9leGlmOlBpeGVsWERpbWVu c2lvbj4KICA8
ZXhpZjpQaXhlbFlEaW1lbnNpb24+MTQ1PC9leGlmOlBpeGVsWURpbWVuc2lv bj4KIDwvcmRm
OkRlc2NyaXB0aW9uPgoKIDxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSd1 dWlkOmMxYzc2
NzFhLTU1NDctMTFkOS05MjVjLWU1NzFkOGYzNTZlMCcKICB4bWxuczpwZGY9 J2h0dHA6Ly9u
cy5hZG9iZS5jb20vcGRmLzEuMy8nPgogPC9yZGY6RGVzY3JpcHRpb24+Cgog PHJkZjpEZXNj
cmlwdGlvbiByZGY6YWJvdXQ9J3V1aWQ6YzFjNzY3MWEtNTU0Ny0xMWQ5LTky NWMtZTU3MWQ4
ZjM1NmUwJwogIHhtbG5zOnBob3Rvc2hvcD0naHR0cDovL25zLmFkb2JlLmNv bS9waG90b3No
b3AvMS4wLyc+CiAgPHBob3Rvc2hvcDpIaXN0b3J5PjwvcGhvdG9zaG9wOkhp c3Rvcnk+CiA8
L3JkZjpEZXNjcmlwdGlvbj4KCiA8cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91 dD0ndXVpZDpj
MWM3NjcxYS01NTQ3LTExZDktOTI1Yy1lNTcxZDhmMzU2ZTAnCiAgeG1sbnM6 dGlmZj0naHR0
cDovL25zLmFkb2JlLmNvbS90aWZmLzEuMC8nPgogIDx0aWZmOk9yaWVudGF0 aW9uPjE8L3Rp
ZmY6T3JpZW50YXRpb24+CiAgPHRpZmY6WFJlc29sdXRpb24+NzIvMTwvdGlm ZjpYUmVzb2x1
dGlvbj4KICA8dGlmZjpZUmVzb2x1dGlvbj43Mi8xPC90aWZmOllSZXNvbHV0 aW9uPgogIDx0
aWZmOlJlc29sdXRpb25Vbml0PjI8L3RpZmY6UmVzb2x1dGlvblVuaXQ+CiA8 L3JkZjpEZXNj
cmlwdGlvbj4KCiA8cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0ndXVpZDpj MWM3NjcxYS01
NTQ3LTExZDktOTI1Yy1lNTcxZDhmMzU2ZTAnCiAgeG1sbnM6eGFwPSdodHRw Oi8vbnMuYWRv
YmUuY29tL3hhcC8xLjAvJz4KICA8eGFwOkNyZWF0ZURhdGU+MjAwNC0xMi0y NFQwNDozNDo0
OSswMzowMDwveGFwOkNyZWF0ZURhdGU+CiAgPHhhcDpNb2RpZnlEYXRlPjIw MDQtMTItMjRU
MDQ6MzQ6NDkrMDM6MDA8L3hhcDpNb2RpZnlEYXRlPgogIDx4YXA6TWV0YWRh dGFEYXRlPjIw
MDQtMTItMjRUMDQ6MzQ6NDkrMDM6MDA8L3hhcDpNZXRhZGF0YURhdGU+CiAg PHhhcDpDcmVh
dG9yVG9vbD5BZG9iZSBQaG90b3Nob3AgQ1MgV2luZG93czwveGFwOkNyZWF0 b3JUb29sPgog
PC9yZGY6RGVzY3JpcHRpb24+CgogPHJkZjpEZXNjcmlwdGlvbiByZGY6YWJv dXQ9J3V1aWQ6
YzFjNzY3MWEtNTU0Ny0xMWQ5LTkyNWMtZTU3MWQ4ZjM1NmUwJwogIHhtbG5z OnhhcE1NPSdo
dHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvbW0vJz4KICA8eGFwTU06RG9j dW1lbnRJRD5h
ZG9iZTpkb2NpZDpwaG90b3Nob3A6YzFjNzY3MTktNTU0Ny0xMWQ5LTkyNWMt ZTU3MWQ4ZjM1
NmUwPC94YXBNTTpEb2N1bWVudElEPgogPC9yZGY6RGVzY3JpcHRpb24+Cgog PHJkZjpEZXNj
ZjM1NmUwJwogIHhtbG5zOmRjPSdodHRwOi8vcHVybC5vcmcvZGMvZWxlbWVu dHMvMS4xLyc+
CiAgPGRjOmZvcm1hdD5pbWFnZS9qcGVnPC9kYzpmb3JtYXQ+CiA8L3JkZjpE ZXNjcmlwdGlv
bj4KCjwvcmRmOlJERj4KPC94OnhtcG1ldGE+CiAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAK
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IAogICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgCiAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAK ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIAogICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
CiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAKICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgIAog
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg CiAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgIAo8P3hwYWNrZXQgZW5kPSd3Jz8+/+IMWElD Q19QUk9GSUxF
AAEBAAAMSExpbm8CEAAAbW50clJHQiBYWVogB84AAgAJAAYAMQAAYWNzcE1T RlQAAAAASUVD
IHNSR0IAAAAAAAAAAAAAAAAAAPbWAAEAAAAA0y1IUCAgAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAARY3BydAAAAVAAAAAzZGVzYwAA AYQAAABsd3Rw
dAAAAfAAAAAUYmtwdAAAAgQAAAAUclhZWgAAAhgAAAAUZ1hZWgAAAiwAAAAU YlhZWgAAAkAA
AAAUZG1uZAAAAlQAAABwZG1kZAAAAsQAAACIdnVlZAAAA0wAAACGdmlldwAA A9QAAAAkbHVt
aQAAA/gAAAAUbWVhcwAABAwAAAAkdGVjaAAABDAAAAAMclRSQwAABDwAAAgM Z1RSQwAABDwA
AAgMYlRSQwAABDwAAAgMdGV4dAAAAABDb3B5cmlnaHQgKGMpIDE5OTggSGV3 bGV0dC1QYWNr
YXJkIENvbXBhbnkAAGRlc2MAAAAAAAAAEnNSR0IgSUVDNjE5NjYtMi4xAAAA AAAAAAAAAAAS
c1JHQiBJRUM2MTk2Ni0yLjEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAFhZWiAAAAAAAADzUQABAAAAARbMWFlaIAAAAAAAAAAA AAAAAAAAAABY
WVogAAAAAAAAb6IAADj1AAADkFhZWiAAAAAAAABimQAAt4UAABjaWFlaIAAA AAAAACSgAAAP
hAAAts9kZXNjAAAAAAAAABZJRUMgaHR0cDovL3d3dy5pZWMuY2gAAAAAAAAA AAAAABZJRUMg
aHR0cDovL3d3dy5pZWMuY2gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAZGVzYwAAAAAAAAAuSUVDIDYxOTY2LTIuMSBEZWZhdWx0IFJH QiBjb2xvdXIg
c3BhY2UgLSBzUkdCAAAAAAAAAAAAAAAuSUVDIDYxOTY2LTIuMSBEZWZhdWx0 IFJHQiBjb2xv
dXIgc3BhY2UgLSBzUkdCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGRlc2MAAAAA AAAALFJlZmVy
ZW5jZSBWaWV3aW5nIENvbmRpdGlvbiBpbiBJRUM2MTk2Ni0yLjEAAAAAAAAA AAAAACxSZWZl
cmVuY2UgVmlld2luZyBDb25kaXRpb24gaW4gSUVDNjE5NjYtMi4xAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAB2aWV3AAAAAAATpP4AFF8uABDPFAAD7cwABBMLAANcngAA AAFYWVogAAAA
AABMCVYAUAAAAFcf521lYXMAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAKP AAAAAnNpZyAA
AAAAQ1JUIGN1cnYAAAAAAAAEAAAAAAUACgAPABQAGQAeACMAKAAtADIANwA7 AEAARQBKAE8A
VABZAF4AYwBoAG0AcgB3AHwAgQCGAIsAkACVAJoAnwCkAKkArgCyALcAvADB AMYAywDQANUA
2wDgAOUA6wDwAPYA+wEBAQcBDQETARkBHwElASsBMgE4AT4BRQFMAVIBWQFg AWcBbgF1AXwB
gwGLAZIBmgGhAakBsQG5AcEByQHRAdkB4QHpAfIB+gIDAgwCFAIdAiYCLwI4 AkECSwJUAl0C
ZwJxAnoChAKOApgCogKsArYCwQLLAtUC4ALrAvUDAAMLAxYDIQMtAzgDQwNP A1oDZgNyA34D
igOWA6IDrgO6A8cD0wPgA+wD+QQGBBMEIAQtBDsESARVBGMEcQR+BIwEmgSo BLYExATTBOEE
8AT+BQ0FHAUrBToFSQVYBWcFdwWGBZYFpgW1BcUF1QXlBfYGBgYWBicGNwZI BlkGagZ7BowG
nQavBsAG0QbjBvUHBwcZBysHPQdPB2EHdAeGB5kHrAe/B9IH5Qf4CAsIHwgy CEYIWghuCIII
lgiqCL4I0gjnCPsJEAklCToJTwlkCXkJjwmkCboJzwnlCfsKEQonCj0KVApq CoEKmAquCsUK
3ArzCwsLIgs5C1ELaQuAC5gLsAvIC+EL+QwSDCoMQwxcDHUMjgynDMAM2Qzz DQ0NJg1ADVoN
dA2ODakNww3eDfgOEw4uDkkOZA5/DpsOtg7SDu4PCQ8lD0EPXg96D5YPsw/P D+wQCRAmEEMQ
YRB+EJsQuRDXEPURExExEU8RbRGMEaoRyRHoEgcSJhJFEmQShBKjEsMS4xMD EyMTQxNjE4MT
pBPFE+UUBhQnFEkUahSLFK0UzhTwFRIVNBVWFXgVmxW9FeAWAxYmFkkWbBaP FrIW1hb6Fx0X
QRdlF4kXrhfSF/cYGxhAGGUYihivGNUY+hkgGUUZaxmRGbcZ3RoEGioaURp3 Gp4axRrsGxQb
OxtjG4obshvaHAIcKhxSHHscoxzMHPUdHh1HHXAdmR3DHeweFh5AHmoelB6+ HukfEx8+H2kf
lB+/H+ogFSBBIGwgmCDEIPAhHCFIIXUhoSHOIfsiJyJVIoIiryLdIwojOCNm I5QjwiPwJB8k
TSR8JKsk2iUJJTglaCWXJccl9yYnJlcmhya3JugnGCdJJ3onqyfcKA0oPyhx KKIo1CkGKTgp
aymdKdAqAio1KmgqmyrPKwIrNitpK50r0SwFLDksbiyiLNctDC1BLXYtqy3h LhYuTC6CLrcu
7i8kL1ovkS/HL/4wNTBsMKQw2zESMUoxgjG6MfIyKjJjMpsy1DMNM0YzfzO4 M/E0KzRlNJ40
2DUTNU01hzXCNf02NzZyNq426TckN2A3nDfXOBQ4UDiMOMg5BTlCOX85vDn5 OjY6dDqyOu87
LTtrO6o76DwnPGU8pDzjPSI9YT2hPeA+ID5gPqA+4D8hP2E/oj/iQCNAZECm QOdBKUFqQaxB
7kIwQnJCtUL3QzpDfUPARANER0SKRM5FEkVVRZpF3kYiRmdGq0bwRzVHe0fA SAVIS0iRSNdJ
HUljSalJ8Eo3Sn1KxEsMS1NLmkviTCpMcky6TQJNSk2TTdxOJU5uTrdPAE9J T5NP3VAnUHFQ
u1EGUVBRm1HmUjFSfFLHUxNTX1OqU/ZUQlSPVNtVKFV1VcJWD1ZcVqlW91dE V5JX4FgvWH1Y
y1kaWWlZuFoHWlZaplr1W0VblVvlXDVchlzWXSddeF3JXhpebF69Xw9fYV+z YAVgV2CqYPxh
T2GiYfViSWKcYvBjQ2OXY+tkQGSUZOllPWWSZedmPWaSZuhnPWeTZ+loP2iW aOxpQ2maafFq
SGqfavdrT2una/9sV2yvbQhtYG25bhJua27Ebx5veG/RcCtwhnDgcTpxlXHw cktypnMBc11z
uHQUdHB0zHUodYV14XY+dpt2+HdWd7N4EXhueMx5KnmJeed6RnqlewR7Y3vC fCF8gXzhfUF9
oX4BfmJ+wn8jf4R/5YBHgKiBCoFrgc2CMIKSgvSDV4O6hB2EgITjhUeFq4YO hnKG14c7h5+I
BIhpiM6JM4mZif6KZIrKizCLlov8jGOMyo0xjZiN/45mjs6PNo+ekAaQbpDW kT+RqJIRknqS
45NNk7aUIJSKlPSVX5XJljSWn5cKl3WX4JhMmLiZJJmQmfyaaJrVm0Kbr5wc nImc951kndKe
QJ6unx2fi5/6oGmg2KFHobaiJqKWowajdqPmpFakx6U4pammGqaLpv2nbqfg qFKoxKk3qamq
HKqPqwKrdavprFys0K1ErbiuLa6hrxavi7AAsHWw6rFgsdayS7LCszizrrQl tJy1E7WKtgG2
ebbwt2i34LhZuNG5SrnCuju6tbsuu6e8IbybvRW9j74KvoS+/796v/XAcMDs wWfB48JfwtvD
WMPUxFHEzsVLxcjGRsbDx0HHv8g9yLzJOsm5yjjKt8s2y7bMNcy1zTXNtc42 zrbPN8+40DnQ
utE80b7SP9LB00TTxtRJ1MvVTtXR1lXW2Ndc1+DYZNjo2WzZ8dp22vvbgNwF 3IrdEN2W3hze
ot8p36/gNuC94UThzOJT4tvjY+Pr5HPk/OWE5g3mlucf56noMui86Ubp0Opb 6uXrcOv77Ibt
Ee2c7ijutO9A78zwWPDl8XLx//KM8xnzp/Q09ML1UPXe9m32+/eK+Bn4qPk4 +cf6V/rn+3f8
B/yY/Sn9uv5L/tz/bf///+4ADkFkb2JlAGRAAAAAAf/bAIQABAMDAwMDBAMD BAYEAwQGBwUE
BAUHCAYGBwYGCAoICQkJCQgKCgwMDAwMCgwMDAwMDAwMDAwMDAwMDAwMDAwM DAEEBQUIBwgP
CgoPFA4ODhQUDg4ODhQRDAwMDAwREQwMDAwMDBEMDAwMDAwMDAwMDAwMDAwM DAwMDAwMDAwM
DAwM/8AAEQgAkQG5AwERAAIRAQMRAf/dAAQAOP/EAaIAAAAHAQEBAQEAAAAA AAAAAAQFAwIG
AQAHCAkKCwEAAgIDAQEBAQEAAAAAAAAAAQACAwQFBgcICQoLEAACAQMDAgQC BgcDBAIGAnMB
AgMRBAAFIRIxQVEGE2EicYEUMpGhBxWxQiPBUtHhMxZi8CRygvElQzRTkqKy Y3PCNUQnk6Oz
NhdUZHTD0uIIJoMJChgZhJRFRqS0VtNVKBry4/PE1OT0ZXWFlaW1xdXl9WZ2 hpamtsbW5vY3
R1dnd4eXp7fH1+f3OEhYaHiImKi4yNjo+Ck5SVlpeYmZqbnJ2en5KjpKWmp6 ipqqusra6voR
AAICAQIDBQUEBQYECAMDbQEAAhEDBCESMUEFURNhIgZxgZEyobHwFMHR4SNC FVJicvEzJDRD
ghaSUyWiY7LCB3PSNeJEgxdUkwgJChgZJjZFGidkdFU38qOzwygp0+PzhJSk tMTU5PRldYWV
pbXF1eX1RlZmdoaWprbG1ub2R1dnd4eXp7fH1+f3OEhYaHiImKi4yNjo+DlJ WWl5iZmpucnZ
6fkqOkpaanqKmqq6ytrq+v/aAAwDAQACEQMRAD8Amn59fn75u/KvzlaeXdAs tHfS20Oz1SWW
/sDcz+tO7RMAyzQih4g771rvm77N7Nx6nGZSJu+H013Dy82meSQnwjuv7a7w wOb/AJyj/Oe2
sY9Ru/LWlW1nNT0ZZ9BmiD1FRx53YJFDWvSmbU9hacfxH5x/4lv8PLVkgfD/ AI8kz/8AOZf5
l+g80GmeXmMcixOkmkvGasGNRS6b+XK49i6eXWX+x/4lxtRPJhFmvkf1qC/8 5n/mkf8ApT+W
/wDuHSf9lGT/AJDwd8v9j/xLg/np9w+39aZaZ/zln+dGs/W/0T5Y0S/+oW0l /ffVNInn9Czg
p6k8vCY8I0qOTtRVruchLsbTx5yIvbnH/iUjWZDyA+39ayx/5y8/NvUru30+ w0DQLq/u5Egt
bWDS5ZZpZpWCoiIsxZmZiAqgVJwnsTTgWZSr/N/4lA1uQ9B9v61S7/5y5/Nn T7ufT9Q0HQbS
/tZHgurWfS5YpopomKujo0wZWVgQykVBwDsXARYlKv8AN/4lTrcg6D7f1rR/ zmD+Zp/6VPl3
/uHP/wBV8P8AImDvl/sf+JX89PuH2/rVF/5y9/Ms/wDSp8vf9w9/+q+P8iYO +X+x/wCJX89P
uH2/rVF/5y6/Mo/9Kry9/wBw9/8Aqtg/kTB3y/2P/Er+en3D7f1qi/8AOW35 kH/pVeX/APuH
t/1Wx/kTB3y/2P8AxKPz0+4fb+tUX/nLP8xz/wBKry//ANw9v+q2P8iYe+X+ x/4lfz0+4fb+
tHz/APOTP5tWthZapd+XdIg0zUvV/R17LpUqQXP1dgkvoyNIFfgx4vxJ4ts2 QHY+nJIEjY57
x/4lkdbkAuh9v61Af85WfmIf+lXoH/cPb/qrkv5Fw98v9j/xLH89PuH2/rR+ pf8AOSf5r6Lf
S6XrXl7SNO1KDj69nd6VLbzpzUOvKOSRWFVYMKjoa5CPY+nkLjIke+P/ABKT rcgNED7f1qA/
5yk/ME/9KzQf+kA/9Vcl/IuHvl/sf+JR+en3D7f1qi/85Q/mAf8ApWaF/wBI B/6q4/yLh75f
7H/iV/PT7h9v61Rf+cnfP5/6Vuhf9IB/6q4/yLh75f7H/iV/PT7h9v61Qf8A OTXn0/8ASt0P
/pAP/VTB/I2Hvl/sf+JX89PuH2/rVB/zkt58P/St0T/pA/6+Y/yNh75f7H/i V/PT7h9v61Qf
85Jeej/0rtE/6QP+vmD+RsPfL/Y/8Sv56fcPt/WqL/zkf55P/Su0X/pB/wCv mP8AI2Hvl/sf
+JX89PuH2/rVF/5yL88H/pX6L/0g/wDXzH+RsPfL/Y/8Sv56fcPt/WqL/wA5 Eedj/wBK/Rv+
kEf814P5Hw98v9j/AMSv56fcPt/WqL/zkJ51P/Sv0b/pBH/NeP8AI+Hvl/sf +JX89PuH2/rV
F/5yB85n/jw0f/pBH/NeP8j4e+X+x/4lfz0+4fb+tUH5++cj/wAeGj/9II/5 rwfyPh75f7H/
AIlfz0+4fb+tUH58+cT/AMeOkf8ASCP+asf5Hw98v9j/AMSj89k7h9v61Rfz 283n/jx0j/pC
X/mrH+SMPfL/AGP/ABK/nsncPt/WqL+eXm4/8eOk/wDSEv8AzVg/kjD3y/2P /Er+fydw+39a
ov53ebD/AMeWk/8ASEv/ADVj/JGHvl/sf+JX8/k7h9v61Rfzr81n/jy0r/pC X/mrB/JGHvl9
n/Er+fydw+39aoPzn81H/jy0r/pCX+uP8kYu+X2f8Sv5/J3D7f1qg/OTzQf+ PPS/+kJP64/y
Ti75fZ/xK/n8ncPt/WqL+cHmc/8AHnpn/SEn9cf5Jxd8vs/4lfz+TuH2/rVB +bvmU/8AHppn
/SGn9cH8k4u+X2f8Sv5/J3D7f1qi/mz5kP8Ax6ab/wBIaf1x/knF3n7P+JX8 /k7h9v61RfzV
8xn/AI9NN/6Q48H8k4u8/Z/xK/n8ncPt/WqL+aXmE/8AHrp3/SHHj/JOLvP2 f8Sv5/J3D7f1
qi/md5gP/Hrp3/SHHj/JWLvP2f8AEr+fydw+39aoPzL14/8AHtp//SHHg/kr F3n7P+JX8/k7
h9v61QfmPrp/49tP/wCkSP8Apj/JWLvP2f8AEr+fydw+39aoPzE1w/8AHtYf 9IkX9MH8lYu8
/Z+pfz+TuH2/rVF/MDWj/wAe9h/0iRf0x/kvF3n7P1I/P5O4fb+tUHnzWT/x 72P/AEiRf0x/
kvF3n7P1L+fydw+39aovnnVz/uix/wCkSL+mP8l4u8/Z+pfz+TuH2/rVF866 sf8AdFl/0iQ/
804P5Lxd5+z9S/n8ncPt/WqDzlqp/wB0Wf8A0iQ/804/yXi7z9n6l/P5O4fb +tUXzdqZ/wB0
2f8A0iw/804P5Lxd5+z9S/n8ncPt/WqL5r1I/wC6bT/pFh/5px/kzF3n7P1L +fydw+39aovm
fUD/ALqtP+kWH/mnH+TMXefs/Uv5/J3D7f1qi+Y78/7qtf8ApFg/5owfyZi7 z9n6l/P5O4fb
+tMbG+1C+iln52FvFCyIzS2qbtIGIAEcL/yHMXUaXBhriMt/6v6nIw6jNluu Hb3oj1rv/lt0
v/pEb/smzE/wX+n/ALFyf8I/o/7JiOvecCx8yeXrSa3kv9M0z6zcXNtarCIz dxXBjCO0cbh1
EPIlRReScX5cuMziwyxylDi9Nc66liMmUTEZVvfK+j8+8xHKf//QC/8AOT8G mXX516RBrUrQ
6U/lXT/rcqBWKxiaUnZ45VI/mqlOPdPtr2HYRAwEn+d/vY+RcadeNv8Azf8A fe+P3obzjrun
a7rNwdZ1BrprWOG3sG9VzEunLEptvQYWzK0TRkOHV5ObMzeo7VObkDTYwaNd evX/ADGUhlMj
Ijf8f0nkeoa1pflLzHpXmryn6dxqWj6rZ6l6Vw0ksDT2TmaIOoitzxJX4gr1 I/aTKIDHlhIR
JqW34uMf0tOqyTEBfQ/jqX0r+a2ieTdb8w+Q/wArfJ+tW0uk/mj5km/M3Vbn zALiOIDVIglr
HEYRZt6VyouI47bmt003pR+vBzV80mmnOMZ5JjfHHwhw/wBHn/O+nb1fT5Fp yCJIiD9R4t0V
pv5d+WfKPlrWPMuh6Je+Xb/zJ+WnnePVdIv7a505kbTbqzSKT6pe3moTQs6T b1u5EdFjkRI+
TLglnnkmIyIkI5MdEVL6gf4oiI/2KRjEQSBVxl+Oqb6p+XHlyw/Nq88w6Jo1 z5q81ad598r6
dcpfXuqarcaRor6Va3Z1Fytz6399yAmvHmtlWERrGFRxlcdRI4RGR4YmEzyj HilxEcPKuXSN
S3ZHGBOwLPEO/YVz/tSfQ/yU8redvPvmCbzNp/6Xt/NHmvzfbNqOkwXs1xo3 1CWQRi9u47+K
2tJHciW2jmsLv1lZeTcZVWOyesnjxx4TXDGHOvXf82PDxS/peuLAYRKRvqZf D7f0IrQdNg8z
+fPyEI0mSTQJPKFnZS+ctMudStJVvLTS9TEmmreWVzHCjI8bNJGqrc1V0d/S 5R4JyMMebffj
PoPDy4o+rhkP+OpiOKUNtq579x2YUv5VeQf8AjU/0R/uH/5V5/if/Hf1m6/5 Sz61w/Rvq+r9
R+1/o/1b0PrP7PP1vjzK/NZPEq9/E4ODb+7r6/5/9Livh+DT4UeG6/hvi/pd 3civzX/LH8vt
LtfzbttA0CPR5vy9k8tSaRd21zezS3C62qi4juhd3E6MoMnKP0kidSq1ZhyD DS6nLI4uKV+J
xXy/g5VQCcuOI4qFcNfagde80foH/nHP8s9N9fWIv0zb+aLfhpOqfo20f/Ty lL2D6vN9aj/e
f3fOL4fUXl+8qs8eLi1WQ7bcHMcXT+Hf0sZSrFEb731Z1oX5J+VdPsrK5uLK QazoWqeTGt/N
GjrqFlp2prrF3bxXDWl9JqFwLlQJg3r2sNg8UyoyUVuC4k9bMki9pCfplRlH hBrijwjh90jN
tjgiB7jHffe/j+pkGu+TPKnmCLy/pHmGO4v7fSf+VlXej6Z6s93dX97Za0BF Dx9eK5upOHOX
01uY5pmj+Obj6mUwzThxGO1+FZ/mgx93DH/S0O5nKETQP9P73np/L3yZcL5t 1DQvI2rt5l0v
SNGuNK8ka5b31m9zPc3rWt/eW1nb3b3r26Kila3coikkkEhdfT45v5jIOESm OEmVzjR6XGJl
XBxf5rR4cdyIm6HpP2+f2sW/5yZ/8nh5p/7d/wD3TrbMns3/ABePx/3RatV/ eH8dHla5snFV
lwKrrgVWXFVdcCqy4FV0xVWXAqsuKq6YEKy4qrrgVWXAqsuKq64FVlxVXTAq suKq64FVkxVW
XAquuBCsuKq6YFVlxVXXAqsuBVZcVV1wKrLiquuBCsuKqy4FV1wKrLiqumBV ZcVT3S/+OVe/
8xFr/wAQnzRdq8o/H9Dt+zv4vh+l8r/4U1f9L/pD/C2tf9C1/pr1f8AcJPrf 1v1KfpH9D/Vf
rP6J+s/vf0X6nLl/pv1T0f8AR80d/N2z1ef/AJTL8yf+2Pp//ULe5n4P7if+ b/unDy/30P8A
O+58Y5jOS//Rlv8AzkB+Rvmb8y/PFnrulS6YdLj0Ow06a21Ce4hdpYXNxWkV vMCnxqNzvvt4
7fQ9oYsOI45gmze1d0e8+TTPFIz4h3V9vuLzi6/5xm/Ny+hSC88w2E8cZb0+ d/PVFf8AYQjT
RxQdEjWiINkUZnfyrpSKMZH4R/W23kqtvn/x1Kj/AM4ifmGlvJBBqOjgyyrN JJNe3cpJVWFB
SxX+bLIds6eHIT+Uf1uPmxTyRrYfH9imv/OIX5lD/pa6H/0kXf8A2SZZ/LuD ul8h/wAU4f5G
fePx8FRf+cRvzIH/AEtND/6SLv8A7JMf5dwd0vkP+KR+Ryd4/HwVF/5xJ/Mc f9LTRP8ApIu/
+yTH+XcHdL5D/il/I5O8fj4Kg/5xN/MYf9LPRP8Akfd/9kmD+XcHdL5D/il/ I5O8fj4Kg/5x
Q/MQf9LPRf8Akfd/9kuP8u4O6XyH/FL+Ryd4/HwVF/5xU/MMf9LPRf8Akfdf 9kuP8uYO6XyH
/FL+Qyd4/HwVF/5xX/MEf9LLRv8Akfdf9kuD+XMHdL5D/il/I5O8fj4Ki/8A OLf5gD/pZaP/
AMj7r/slx/lzB3S+Q/4pfyGTvH4+Cov/ADi/5/H/AEsdH/5H3X/ZLj/LmDul 8h/xS/kMnePx
8FRf+cYvPo/6WOkf8j7r/smwfy5g7pfIf8Uv5DJ3j8fBUH/OM3nwf9LHSP8A kdc/9k2P8t4O
6XyH/FL+Qyd4/HwVF/5xp89D/pYaT/yOuf8Asmwfy3g7pfIf8Uv5DJ3j8fBU H/ONvnkf9LDS
f+R1z/2TY/y3g7pfIf8AFL+Qyd4/HwVF/wCccfPA/wClhpX/ACOuf+yfH+W8 HdL5D/il/IZO
8fj4Ki/846edh/x/6V/yOuP+yfB/LeDul9n/ABS/kMnePx8FQf8AOPHnUf8A H/pf/I64/wCy
fH+WsPdL7P8Ail/IZO8fj4Kg/wCce/OY/wCP7S/+Rtx/2T4/y1h7pfZ/xS/k MnePx8FQf84/
+ch/x/aZ/wAjbj/snwfy1h7pfZ/xS/kMnePx8FRfyD84j/j+0z/kbcf9UMf5 aw90vs/4pH5D
J3j8fBUX8hvN4/4/dN/5Gz/9UMf5aw90vs/Wv5DJ3j8fBUX8ivNw/wCP3Tf+ Rs//AFQwfyzh
7pfZ+tfyGTvH4+Cov5G+bB/x+ad/yNn/AOqGP8s4e6X2frX8hk7x+PgqL+SP msf8fmn/API2
f/qhj/LOHul9n61/IZO8fj4Kg/JTzUP+PzT/APkZN/1Rwfyzh7pfZ+tfyGTv H4+CoPyY80D/
AI+7D/kZN/1Rx/lnD3S+z9a/kMnePx8FRfyc8zj/AI+7D/kZN/1Rwfyzh7pf Z+tfyGTvH4+C
ov5P+ZR/x9WP/Iyb/qjj/LGHul9n61/IZO8fj4Ki/lH5kH/H1Y/8jJv+qWP8 sYe6X2frX8hk
7x+PgqL+U3mMf8fVl/yMl/6pYP5Yw90vs/Wv5DJ3j8fBUH5VeYR/x82X/IyX /qlj/LGHul9n
61/IZO8fj4Kg/K7zAP8Aj5s/+Dl/6pYP5Xw90vs/Wv5DJ3j8fBUX8sdeH/Hx Z/8ABy/9Usf5
Xw90vs/Wv5DJ3j8fBUH5a66P+Pi0/wCDl/6p4/yvh7pfZ+tfyGTvH4+Cov5c a4P+Pi0/4OT/
AKp4/wAr4e6X2frX8hk7x+PgqL+XmtD/AHfa/wDByf8AVPB/K+Hul9n61/IZ O8fj4Ki/l/rI
/wB323/Byf8AVPH+V8PdL7P1o/IZO8fj4Ki+Q9XH+77b/gpP+qeD+VsXdL7P 1r/J+TvH4+Co
PI+rD/d1v/wT/wDNGP8AK2Lul9n61/k/J3j8fBUHkrVR/u63/wCCf/mjH+Vs XdL7P1r/ACfk
7x+PgqDydqY/3bB/wT/80YP5Wxd0vs/Wv8n5O8fj4Ki+UdSH+7YP+Cf/AJox /lbF3S+z9a/y
fk7x+PgqjyrqA/3bD/wT/wDNGP8AKuLul9n61/k/J3j8fBUXyzfj/dkP/BN/ zTg/lXF3S+z9
a/yfk7x+PgvXy5fD/dkX3t/zTj/KuLul9n61/k/J3j8fBUGgXg/bi+9v+acf 5Vxd0vs/Wv8A
J+TvH4+Cquh3Y/bj+9v+acH8q4u6X2frX+T8nePx8F66Pcj9uP7z/TH+VMXd L7P1r/J+TvH4
+CqulXA/aT7z/TB/KmLul9n61/k/J3j8fBUXTpx+0n3n+mP8qYu4/Z+tf5Py d4/HwQGteXtU
1a1SzttdvtGgEgllGmPDG0rqpVObywStRQzUClQeXxcuKccXPq8GauIS29zk YdNmxXRjv70i
/wCVdav/ANTx5h/6Srb/ALJMxeLS90/9i5Faj+j/ALJankkeW9O8zarJql7q t7qOntHcT6hJ
FJJxtYZ/TAMUMX+/TXlXtkjmwjHKMOK5VzroWIxZTMSlW18r6h8P5iuU/wD/ 0vVmpf70J/zD
23/UPHmOW0ITArsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirs VdirsVdirsVd
irsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVd irsVdirsVdiq
V+Zf+Uc1j/mCuf8Ak02Ec1L88syGp//T9Wal/vQn/MPbf9Q8eY5bQhMCuxV2 KuxV2KuxV2Ku
xV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2Ku xV2KuxV2KuxV
2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KpX5l/5RzWP+YK5/wCT TYRzUvzyzIan
/9T1ZqX+9Cf8w9t/1Dx5jltCQeZNf0/ytoOoeYdVYrY6dC08iqUEkhUfDFGH ZQZJGISNeQ5u
yr3yucxCJkeQcrS6bJqc0cWMXKZEY/H3bvkTzh+ZXnr8wXupZZZrHQ7WGT19 L0p7iO1SzuJV
iJvWVh6/IyRws0oWFqqqQxmVw/HantLLmvg9MR3f75+ouw/YXs7s0R8fhzZZ SHCZ/wA+EePh
xR/i+mc+p4Y77RYBb2tvaTxXVnEttdwOssFzAPSmjkQ8ldHSjKykVVlNVPTN aM+QGxI/N7rJ
2To8kDCWKBEhR9MeR+D2nyB+dXmTybqcflnz6011o0Vw9teXOoeq2q2EzyBG M0kzcniifl6i
SD1Y1LlZOMSQZ0Gi7SnxjHl53Vnb/TPjHtX7CaaWnlruzzQERPw4evHOFfXi 4eL6o8Mv5p3P
V9RRSxzRpNC6yQyKHjkQhlZWFQQRsQRnTPgCF1aLV5tPmj0K6trLVW4/V7m9 tpL23SjAtzhi
ntmaq1ApMnFqN8VOLKvI386fmJaeUJ/N2tarpz2dr5jh0N7XRtFuxdtFa+a4 tHnded7fGT1o
ElpDHb+sGlX0pOaDnKghlzfmfbQynS7zy9q1r5seS3js/LEh09r65W7jupo5 I5or17NVKWF4
3726jcfVnHDlJbiYUm2Q+W/MkHmOC8Is7nTNR0y5+pappd76JuLa4MMVyqO1 tLPC3KGeKUGK
WReMgVisiuiBXm+q/mv5itdN812dpa2R80+QNJ1XUfNnqRytbLNb28kmkCOM SqQuoxr9d+Ce
4NpFG9nMfXlSZJUi3aj+a/mK307yXBa2tkfMGo6sNO81GWOX6mIdO1u18u6m bHjLzDG8vInt
PWqPqwkaYLLxiZpbeg+Q9du/NHkbyz5m1BI47/WtJsNRuo4AywrNd20czhAz MwUMx41ZjTuc
iUsE80ef/Mem/mWNES11G18uaZ/h5JLq3h0y4srl/Muozafyu1mukuhGGRY7 drYJJFOs0tzD
c23opJIDZDvKX5vPJ5E0jXNX0zUdWjsNF02985+ZLVLCO0srifTLfUbl5YXu IJ34QTpcMLS2
mXi/pxB5VaJUhbZr5z846f5Lj0q/1a4+q6VcXN0l9P8AV2ueNvZ6VfalI3wS KycVtC3JY52a
npCH956sQASmehapfavaPc6hol7oMyyGNbPUXspJnUKpEgNjc3UfEkld3D1U /Bx4lgrC7D86
PLtzo1h5n1HS9W0Xynqlk9/p+uajbxLDMILGTUZYhBDNLdBkggnfm1usEohJ gmlWW3aY0i1D
zZ+aup6D5Y8x3v8AhXUdM8zabot/rekadqjadMl1FpwjWeUmx1CVRHbtPC06 PLFM8b/6Mszq
yqgLbNW1+5h8sXPmO80LUbe5tba4un0ALbXWpv8AVg5EUaWk80TyShf3SpMe XNVbi1QoSgh5
3sr39I/4asbnzL+jrawug+kyWbwXP6S5OkUE89zDCZEhEdzIryJ/o89vInP1 kGGlYJL+clpa
+a5p766ksfKcdlbG8tZ7RZ5rO6s08zyamrtBJyDRtowRnj+uRuYeNujLP9ZU 0i2Qad5y8x6n
+Ymk6Fe6DqPl3Sp9F1e9lt9TbTJfrNxa3elxRPG1hd3bL6S3EoYMY1b1V2fj 8ArZXoWBLzDW
vPmrwecL3y9Br3lzQbm1ube10nQPMAkjv9c9eCGZZbWcXcJijllmezRks73h NBK375v9HQ0h
Ov8AlZFl9dp+h9R/w5+kf0J/ij/Q/wBH/pD65+jfS9L619c/3s/0Xn9U4c/3 nL6t+/xpNu0T
8yLLW7nSB+h9RsdG8xf8o1rl19TNpqPK2kvY/SSC6luY/UtopJ1+s28FFThJ wmKRM0tu1vzl
rOl/mJoHlC00G51DStW069vbrUIGtF9F7a7soA/7+7hb04VuGa4CxPI3qQfV xJxnVGtlYx5L
/OGD/AnlnXvO9pqNjbX2iw3dx5ouraGO0vL220xtQvBFbwObpaJb3Mqs1pFB KsX+ju6y2/rE
hFs10Tzk+p6uuharoOo+XdVntpr2xt9Tawl+s29rJFFcPG2n3d2q+k1xCGEp jZvVX0w/GTgK
SxHX/OfnnTz+YPmCyudJHlvyFIxbSZtPuZL69htdGtNWlUXq3yRxNIbhokf6 pKI6K7JL9nDS
E6j/ADS025inaw0XVru4XVrry9YWyw28DX+pafJdrcx2r3NxDEyxRWUs5meS OFk/dJI12stt
GKTaS3H5pXz+ctJ0qy0XVpLg2Wsw6r5Ujhsnvk1K0fRp4DJcC4NoiraXzS8/ riwt6yQsxu/T
gw0i3Wn5rrP5pvreC1vb+Gey0y20ny3DHapffpoXevRajAZZZY4OUS6U/Nmu fq5+rN9WkkaV
PWaW0z/5WrHJqEOh2XlXWr3zMfrn1/Q4W0pLiy+oLYyP60s2oR27c49StZE9 Ceb4ZKPwdJEU
Utuh/N7QpLaG8l0zUbe21O2ivfK7yJan9NW9zc21pC9qI7hzF6kt9aIovvqb L9ZRpAix3Bha
W2UNr9zD5YufMd5oWo29za21xdPoAW2utTf6sHIijS0nmieSUL+6VJjy5qrc WqFCWL65+bXl
jSry2Zbz1NBj4XGoa3bwi/sGt5NI1HVuEc0EwIkSCyS5fjFO3oz23CIi6WaI 0i1eb8z7bTWa
PzL5e1by/N6a3Ucd8dPmDWKXVta3d2ZLG9uY44LM3cMt08zxcIC0qCRYpeDS bRp/Mby6bu80
+3Mlzf2mrWmhpa25ikmuJrtgrTQIJOTwQMtyLh6ViOn6h8J+qyY0tpX+aPmT zHoz+WNG8u2e
oyy+YtRlsri+0f8ARhvYEt7C5vQkA1aVYBJIYOssckfoJcCqTtb8kIKjc/nL o1jo3+Jb/Q9W
tfLFzZXOo6JrDrYvDqcNrYzamBbxR3bzxtLa28s0f1qG2FE4SmKZljZpbZ3p Oo/pbT4dRFpc
2UdxyaKC9j9C49IMQjvESWj9RQJBHIEmRWCzRxSh41CUr8u+a1127vdLu9Kv dC1vT47e5uNM
1E2rzfVbxpUgnD2NxdQlXe3mTj6vqKYjzjVWjZ2lYJ5c/NW5F3qek6nHc61r S6je2mkaZZW9
tDcT01vzBBFGk81zBAfTtNIZj6ogosJPr3M86xpKkWyHSfPGvah+YV75SuPL F7aaXBpOl6j9
ekewJtptQ+vGQXHp30jMvK2WBPRikInjnZj9XaGZhWyU01vzk+mau2haVoOo +YtVgtob2+t9
Mawi+rW91JLFbvI2oXdoreq1vMFERkZfSb1AnKPm0rF9H89an5s/Me2stGh1 H/A8Wi6brdrq
NuunJZXsWtx3jRy3YunN6sY+rotukEUMyzrN9aVrcwtjWyEF5/8AzI806Nc/ mFo2l6PcwReX
vKn6b03zCn1J4oLuS21ORZZUlui7xl7RIokFszesk3rL6DRSMQFtkM35pabZ s0eq6Lq2mTXE
azaDBeQ28c2qrJdW1kggjFwzQM097aR8L8WbobhfVVFjuDCKTadeXfNa67d3 ul3elXuha3p8
dvc3GmaibV5vqt40qQTh7G4uoSrvbzJx9X1FMR5xqrRs4pWQ4q7FXYqlfmX/ AJRzWP8AmCuf
+TTYRzUvzyzIan//1fVmpf70J/zD23/UPHmOW0PnL/nKHUp1tvKuhhU+qXE9 5qLvQ+oJrKOO
BADWnEreSFtq1Cbj4uWg7ZmRiA7y+xf8C3SwydoZMpJvHD093rPCbY7+Qn5v aZ+Xl9f+XfNW
nwXfknzHSHVpjbpLPDVTGGkAUtPBxZhJA3LiGZ4V5GSOfUdm66OAmMxcJfVt +OKP9H5f0vUP
bX2Xy9q44Z9NOUdRg3xjiMYy/i9O9YstgcGUcN0I5Dw8E8Xe0/JP8r/yU1PW vzc1iWe90LSe
F1oukPF6/wBRnkdUUKxYmeT1GVLZpOAhrzld3UXCb7+T8GklLPLcR+mP83/i v6P83r/OfKD7
Xdq+0OLF2XiEYZMtxy5b4fGiBZvb91DgEpZhDi8X6YRjGXhS8mfmT59vvzK8 333my/tILF7r
jHDa2yKOEEQ4xiSQKrTSBQA0r7n7KhI1jjTlNXqTqMhmRV/j4+99/wCwOxcf ZGihpoSlPh3M
pHnKW8uGNkY4XyhH3ninKc5egf8AnHfzBc6v5At9OvHaSXR2NnbswFBaQu9v CtakkgQmtdt/
h+H4V7nSzM8MJHqH5H9pdLDS9p58UCSIzPPnv6vJ63mS86wr/AH/ADrP+Hf0 j/00f+JvrPo/
9/F+n/Q4ep/zw9Tl/wAW8P8AdeG1Szzv+U1p5z1uXXrmaymmWPTBZ6dq+nLq mm+tpg1WMtc2
5mhMytHqr8EV4jFNDFLzkWsWIKKZD5F8nweS9Im0+KPTopLq5a7ni0TTIdG0 9XaNIgIraJpG
FVjUu0008jOWo6xelDEkpYvqX5Q/XtI1W3i1n0Ne8yadq+meaNVNtzW//TMb +nI0YmVz9Rcr
HYLNNP8AVrH1bQMxl+sRtopOtW/LPy/e3uq6xpyfo/Xte1HQNT1q/rLP9Z/w zeQXNvH6TyhE
qkJi5Rhft82WQrTG0078vvK3m3yfpGl+XNW13TtW0HRtOt9MsUtdKnsLs/VI 44o5JZn1C6Rv
gQ8lWFKseQZQvFklXa/5A/Tmt3usfpH0Prn+Gf3Po8+P+F9Ym1b7XqLX1/W9 Lp+648/3leGN
qwW1/wCcdtNs7a1s+eg6ihstOstS1LWfLlvqeqctO0+20wvYzz3Bit1MVqkk cU1veJHcNI7+
tG/pA8SKeneZ/Lt3rk+h32n3sdjf6Bez6jatPbtdQvNLpl7p6B0WWFuKtdiV qOC4j9Oqc/US
ISo+RfKP+DdIm071rZvrFy119U0y1/RulWvKNI/SsrP1Z/Qjb0/VkX1X53Ms 83w+rwUkqx6/
/KO01XyF5T8g6hqkhsPLlkdOurqCJY5rqF9CvNDcoGaRYWK3ZmWomAKcKNXl je6KVrz8u9X8
0fpD/Hmt2179b0XU/Llv+g7CTSvTtNb9D627/WbvUOcg+rReiRwWP95zSXmv ptrTNdJi1eHT
4Y9dura91VeX1i5sraSyt3qxK8IZZ7llotAazPyarfDXioS89/5U3p9t5S/w xp9xbNGmo/pA
QanaNqGlXFvBB9QsrS9smuE+sR2tlHbRxn1o2e5tIL2TlL6iubRTH7T/AJx1 tBaDT9Q1mNbC
WO6gurXSdPXT4VhvV8yK6WqNPcLCqL5hIiUiUILVfter+7PEtMtbyR53vNXf zHqPm+2XXodF
1TRNKfT9IFvaWkupSWksd4Ibi6unkkje1HNJJjDKvpqscJSVrgWr0LAlhXm7 yl5n80Qaroae
YbaDyhr1tJZanYz6cZ7+O3uYfq9wlndx3UCR8kq8Znt7po5ndiZIeEEZBVj9 r+Sum2fmltbh
h0FrVtWl103k3l+3n8xfWZ7tr9lGqSzMgUTMURhaerHbcY45VnVboG0U7yN+ Sum+SdV0y6tI
dBW00SNodOurLy/b2muTKIGtlN7qTTTGVmjctO8ENq801G5JCZLeRJtaZprH l27vfMWi+ZtM
vY7S/wBLjubCeO5t2uoZtO1CW1muUQJLA0c5azi9KYtJHGPU5wS8l4RSxi// ACjtNV8heU/I
OoapIbDy5ZHTrq6giWOa6hfQrzQ3KBmkWFit2ZlqJgCnCjV5Yb3RSt5F/LKD yhq82stbeXLW
5e2a0jXyz5eh0HkksiSOZ5GuLyWShiX01SSGPdzKkzei0KStI21/K/ykPNOs +cNW0nTtW17U
tRt9TsdQurCCS7sfqllaWkccU7h3+F7UzKylOLSbLVebNppRb8vru30qxh0v Vo4db0nXtV8y
aZeXNo1xaibWZ9QZ4p7dJ4XkVIdRljUpPEfUSOX7PKFm1SuP8t/Ntn5gXzjp vmXTo/NVz9f/
AExJcaPPNp8v1+LSrdfq9umpRSQ8I9JgrzuJ+bvK3wKURG0Ull7+Q1pfM93d 39lqN+0kN+bb
VtLW+0l9R+ta1dXLy2bXCM8DNrk31eH1hJbtDA7z3HF+Z4lpkHk78sIPKmr2 OsxS6dbyW1tq
lvPp+iaTDo+nl9Uk00h4oYpJGXgumrz9aS4kkeViJY4kigQErSjH+V93Z6J5 Z0uy1Oynm8u+
WJvKTDVdNa+sbyG6OmrLJNbLdQkq0dgyel6pH774nZY+Eja0y7ynoH+F/L9n of1j6z9W9Rua
p6MCetK8vo28PJ/RtoefpW0HN/Qt0ii5vw5EFLBJfyN0SbyzB5U+vSQaat7f z3LwIRM9jdaL
d+X7W2RpXkCNa2M1vCsxWT1ja+pKhlmkfJcSKVvLv5OaRp/6Wj1iw8uCz1bT rjRrq28s6BH5
e9a0vuInWeZbm6nbZAIxFNAq8nZ1lf0WhFrSN0D8qtP0bV9B12e7+uarpltO 2qXHptF9f1ie
S5lN/wARKVho2paofq6Axf6d/wAutvwbWmUa3oH6Z1Py3qP1j0P8PajJqfp8 Ofr+pp15YenX
kOFPrfqcqN9jjx+LkoS89v8A8nNX1XypbeRr/wAx23+GdG0660zy36GmyR38 PraTc6LDJeTN
evHcenb3UjSLFBaerMEdWiQNE0rRT0/WNO/TGkX+k/W7mw+v201r9esZPQu4 PXjKerBJQ8JE
ryRqHiwByKWFfl3+Wn+BtX1vVq6LD+mLawtfqPlzRv0DaJ+j5Lt/VeP63dep JJ9a4lqr8MaD
CTaAEsP5Q3cA14W2o6Tfw+YJK3ljr+jNqlj6I1nV9ZCmAXtuGZZNTRVdmoPq /PhylHom1pk+
k+TLvQtbsdUsNYkuoV0mx0PWTqqNeX15DpIuWtZluVkhCTtJdyvcu8U4m+Hg sDcnYWl2seWP
MR8xT+ZvKesWWm39/ZWunalHqmny6nC0Ony3M1uYRBe2LRtyvJvU5NKHHpcR Hwb1G1d5R8hW
nk67R9Pu5J7CDQdF8t2sE6qZlh0FrzhK8i8VZpFuwGAjQKY6/t8USVQXnL8v rvzNL5gNhq0e
nw+adBk8t6yk9o12whSO9FrLbMs8AjZJL+Vpg6zCZFRE9BuUjIKu/MD8tLTz /c2k97cxrDZ2
VxarZ3Fst3bTTSahpmpRG4jZ1EkAk0xUmg+EzRSuqywt8WINLSt5A8gweSf0 jMsOi29zqHop
JF5c0WHQbThbeoUZ0WW5lkkJlYFnnMYUJ6UMbes8yTas1wK7FXYqlfmX/lHN Y/5grn/k02Ec
1L88syGp/9b1ZqX+9Cf8w9t/1Dx5jltDwf8A5yS8r3WqeXtL8zWME1xLoM06 3oj4lItPu4w0
0zLTkeEkENWU0SNpHdeC849N2rgOTFYFmO76d/wO+18eh7R4MkoxhmjwcUv5 38AvlHiP85h3
/OP2o/lL5autW86ef7mR9f8AL8a3WhaU8IeKRuQUSQfFSW5DsojR/TWEf6Ry bg0lro+zJafG
Tkyn1R+kfq75fd9X9X2D23wdsauGPSaGIGLMeDNkv1R/o5NvRg4b45R45ZP7 mo8QhnmXlX/n
LC+1HzfqFt+YdjBJ+XWuVtf0ekKz/o6BwY6t8HK5jdT/AKSrglvtwooH1eTN w9smWQjKP3cu
n83/AIr+l/sf5rzfaX/A0x4tFCWhnIavD6uO+Dx5fVtvWGcT/cmPL6cspf30 OKfmrp/kbSfP
OqWP5d3suoeWklCW7EGRFnY0aG2kDM08aseMUhHJ/sj1fhnl1GpxYznMMPqH T9nePP8A6SPo
nYnaGrj2XHUdpiOKcY8Uz9Po/hnkhX7vJL+LHG9+kJHwod4/5x70O40fyrM1 wArytGs0RYMy
XPx3Ewqo48Q09EoTsP8AZHusWLwscYdwfkftjXnXa3LqDXrkTtYFdPq35M+8 867d+V/Kmp+Z
rRI5E0WNdRv45QzFtOtHWa9EQVlrObZZfq/Jlj9f0/UIj5ZYHUsR1D8wdUl0 +8urC+ttOlk1
q/sNGgGial5jvZbDRW+oXjy2WmTpKKXyScbhW9FIJLVJVWefiDSHnHlz8z9S l16717TbKO3m
83yWl1DBPNcTw2lzrFh5HsoWeOOSGOdYDqTO3JElcR+nDNbLNKWlSLZa+qeZ PLXnTzfLr2va
c/mG40Xy1DpdzZaFqFyj1vdccwpplvf3F1cyBI5nJhmXhGDK0fpwSFgl3l3z Z5084+cfJt/Z
albafpU2neZYdU06fTr1PrT6Frljp803oS3cLW8ky/FbpPHLJYc54pPrPqfA 0qC8u/mR50vP
y3uvO9k+nQaV5Q0Wxu9U0q6gvb671B10Cy1uYRX8t8Gh5rdegrTxXsisnryP Pz9NWt1tkNr5
488m1bzPejSV8tx+Z5fLC6XDBctfTwt5hbQoro3TTiOFkLK7w/V7gS+kxWaH 6xwtmlTP8xPO
+qeXNX0TQNJb6tc6rbX981/+htS8ycE06S0iMX1LS3ilHqG8Deu0npx+l6ZR mmRkACliT/mr
5/fSvNGprpllZQ+VvLFxr8v6Rs7+0urq5hn1q1tyLOdopIILkadDd8ZXMsEb G3/ftMtzbmgt
st/S35ialrs3lizvNF0nVdN06z1bUp5rG71W3f8AS11fRRW8IW9sWH1dbLi8 7/71M/qLb2nH
0iNlY/5Z/M7zz5u0DWvNOmaTZRabax6UbGzjW5v75Dq+l6VqU8skcZiM62Md 5NJ6MA9fUKJB
ELWVOVySFt6R5T1GfVvL9nf3OoW2qXMvqCa7s7SbTouccro0bWtxNPLDJEV9 KaKWT1EmR1dY
2rGsSlOsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVd irsVdirsVdir
sVdirsVdirsVdirsVdirsVdiqV+Zf+Uc1j/mCuf+TTYRzUvzyzIan//X9Wal /vQn/MPbf9Q8
eY5bQl11a219bTWV7DHc2dzG0NxbzKJIpIpAVZHVgQysDQg7EZEi2UZGJBBo h8yfmD/zj9rW
jzzan5GrqeiseZ0qaRmvoCSf3cJCH1U6BfUYSL/uyRxykXntT2PGRvGa8n2/ sH/gnZMMBj10
Tk3iBkh9QjykZx/jP8W28t3ljeVvNaTm2m0aW3mV/Tk9eW3URsDQ8wsrMOJ+ 1RWb/JOYEexd
QTvXze1y/wDBN7IjAmJnIgbR4a4j3X0t6X5A/JPWtTuYdR1dfREXCaNpFb6m qsRweLlGjTSA
VdT8Ma/D0dUkbfaPs3Hp/VL1TfI/af281XawOHEPCwGrj/HPv45fzT/N/oh9 P6bp9tpVhb6d
aLxt7ZBGmwBNOrNxABZj8TGm7ZsybfNUVirGJ/y+8rT6Ro+iJb3NnZ6DbJY6 RLp9/e6fdwWi
RpH6AurWeKdo2EUfNGkZZGjjeQM8aMptUDaflN+X9jAtvaaR6UaWws4iLm6L xxJDp8CNG5lL
JJGulWRimQrNFJbrNG6ys7s2Vp0X5UeRofrUkdjcrqF79WNzq/6R1A6q72Xr iGT6+bj60JFS
5mg9UTeo1s/1VmNuqxK2tI6y/L7ytp1tpdrZW9zD+h7m4vLK5W/vTd+re3Ju 7lZrkzmaeOeY
+pPDPJJDMyp6iN6acW1QK/lR5GjgtrOGxuYNOtra3sm02DUdQhsLm3tIUto0 vLWO4WG7/cxp
DIbpJmlhRIZS8aquNrSd/wCE/L/6M/Q/1P8A3HfpH9N+j6kv/HQ/SP6W9Xlz 5f71fveFeH7H
H0/gwWrtf8qaN5l+rtqa3Mdzacxb3mn3t3pl2iS8fUjFxYywS+m5RGeLn6bt HG7KWjjKtqgk
/LzyfHp+qaWum/6HrWnDRdWUzzl7my5XUjCSQyFzI73tzJLPy9eWSVpJZXf4 sNrStrvkrQfM
V2moX3122v0jEDXWl6lf6RNLCjMyJM+nz27SrGzuY1lLiIyS+nx9WTkLVyeS PLVvpuoaRp9r
JpdhqckE11HpV1c6awa0t7e1iEMlpLE8CrDawx8IWjTgnEr8b8m1V9O8p+X9 Jn0+5sLP0rnS
7a7s7SYySyP6WozQ3F00jO7GWSaWCOWWaXnM8nJ2flJIWbVOsVdirsVdirsV dirsVdirsVdi
rsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdi rsVdiqV+Zf8A
lHNY/wCYK5/5NNhHNS/PLMhqf//Q9Wal/vQn/MPbf9Q8eY5bQhMCuxV2KuxV 2KuxV2KuxV2K
uxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2K uxV2KuxV2Kux
V2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KpX5l/5RzWP+YK5/wCTTYRz UvzyzIan/9H1
ZqX+9Cf8w9t/1Dx5jltCEwK7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7F XYq7FXYq7FXY
q7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7FXY q7FXYq7FXYq7
FXYq7FXYqlfmX/lHNY/5grn/AJNNhHNS/PLMhqf/0vVmpf70J/zD23/UPHmO W0ITArsVdirs
VdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirs VdirsVdirsVd
irsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdiqV+Zf+Uc1 j/mCuf8Ak02E
c1L88syGp//T9Wal/vQn/MPbf9Q8eY5bQhMCuxV2KuxV2KuxV2KuxV2KuxV2 KuxV2KuxV2Ku
xV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2Ku xV2KuxV2KsJ0
rzB+YOv29xqWj6H5fTSlv9T0+0bUNd1C3upF0nUbnTWkeKDRLlE5vbMyqJno pG+Sod6LRvr/
AJpf9Wbyp/4UOrf+M7jQ71su9f8ANL/qzeVP/Ch1b/xncaHetl3r/ml/1ZvK n/hQ6t/4zuND
vWy71/zS/wCrN5U/8KHVv/Gdxod62Xev+aX/AFZvKn/hQ6t/4zuNDvWy71/z S/6s3lT/AMKH
Vv8AxncaHetl3r/ml/1ZvKn/AIUOrf8AjO40O9bLvX/NL/qzeVP/AAodW/8A Gdxod62Ul0X8
wdcn/MuX8tdf0jTre8j0eTWzf6TqV1qEQ9O4gg9BlutNsGDETh+S81pt9qvF MdrUFl/mX/lH
NY/5grn/AJNNgHNJfnlmQ1P/1PVmpf70J/zD23/UPHmOW0ITArsVdirsVdir sVdirsVdirsV
dirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsV dirsVdirsVdi
rsVdirsVdirzby/DaXPl/wAr2t6scsMnnHzU6wTMvF5rbXfMFzEQjXMAdo5I lmQeldlHjWZY
EaL63azP6EBl8Pk/ylbej9X0DTofq/peh6dnAvp/V/q3pcaIKcPqVrwp9n6t b0/uY+MLS6Hy
f5StvR+r6Bp0P1f0vQ9OzgX0/q/1b0uNEFOH1K14U+z9Wt6f3MfFtUr17TPI 3k7y7qPma48u
2QsPL1lJqLx2llbessOmRQTKIQQihlWwtvT+JQptrfdfRj4FWMNo935RbTtY 8xaP5Yl0Sa90
3Tl0zSNJa3utOmvrqxs7Mx3cszJcrBNBYxt/o1kTHbxXEYja1htHKFD8srrS PPOheVdc0vy1
osGn/o6xu9a1GGxjW3/SH1W0YWWmgGo+qy2lr6szM6W7WdvZp6txDK1gnZQ9 Ch8n+Urb0fq+
gadD9X9L0PTs4F9P6v8AVvS40QU4fUrXhT7P1a3p/cx8Y2l0Pk/ylbej9X0D Tofq/peh6dnA
vp/V/q3pcaIKcPqVrwp9n6tb0/uY+Lauh8n+Urb0fq+gadD9X9L0PTs4F9P6 v9W9LjRBTh9S
teFPs/Vren9zHxbV4l5Ah+rfn3YW/o/V/R8gRx+h6X1f0+MmlDj6X1ay4UpT h9VtuPT6vD/d
rYeTEc3ufmX/AJRzWP8AmCuf+TTZAc2RfnlmQ1P/1fVmpf70J/zD23/UPHmO W0ITArsVdirs
irsVdirsVdirsVdirsVdirsVdirzbQdStNJ8saDeahex2FhH5o85PdTz3C20 Ihh1fzHM5ctd
W6sqKhkYFLoKE9X0E9P63bTP6EBl83nDylbet9Y1/Tofq/q+v6l5Avp/V/rP q8quKcPqV1zr
9n6tcV/uZOMKS6bzh5StvW+sa/p0P1f1fX9S8gX0/q/1n1eVXFOH1K651+z9 WuK/3MnFpUFr
2teQtW0jVdC17WdOfSry2u7LVbeS+ih/0cx3cVyjMsisnFbS7DkFWT6tcbr6 EnE7qxeR4Lme
O086ef8ARdR8uaTcpei1SGHT7+S40iaeeF7+5F68bejJp080wt7azVprKXaO 2hubZlDvKth5
S8hWWjWln5v06H9EadBpfmRZJYI4L/8ARFnPai6aMz/6Pcxfo2dXl5P/AKPa 3FvcLJ9Uhks0
7qzWbzh5StvW+sa/p0P1f1fX9S8gX0/q/wBZ9XlVxTh9Suudfs/Vriv9zJxF JdN5w8pW3rfW
Nf06H6v6vr+peQL6f1f6z6vKrinD6ldc6/Z+rXFf7mTi0rpvOHlK29b6xr+n Q/V/V9f1LyBf
T+r/AFn1eVXFOH1K651+z9WuK/3MnFpXiXkCH6t+fdhb+j9X9HyBHH6HpfV/ T4yaUOPpfVrL
hSlOH1W249Pq8P8AdrYeTEc3ufmX/lHNY/5grn/k02QHNkX55ZkNT//W9Wal /vQn/MPbf9Q8
eY5bQhMCuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2Kux V2KuxV2KuxV2
KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KuxV2KvGbv8pvzSW7vBoX5o/o rRJb7Ub6x01N
HL/V01S/uNReMyJfR+oRJcv8bLUjwUKonxeTGlD/AJVP+c3/AJeB/wDuDSf9 5LHiHctO/wCV
T/nN/wCXgf8A7g0n/eSx4h3LTv8AlU/5zf8Al4H/AO4NJ/3kseIdy07/AJVP +c3/AJeB/wDu
DSf95LHiHctO/wCVT/nN/wCXgf8A7g0n/eSx4h3LTv8AlU/5zf8Al4H/AO4N J/3kseIdy07/
AJVP+c3/AJeB/wDuDSf95LHiHctO/wCVT/nN/wCXgf8A7g0n/eSx4h3LSZ+Q vyj8y+WfPcvn
vzR5xXzNfyaXNpCoNONk4Wae3m5tIbu45cfq/EDj+19r4aYDKwkB6N5l/wCU c1j/AJgrn/k0
2Ac0l+eWZDU//9f1ZqX+9Cf8w9t/1Dx5jltCEwK7FXYq7FXYq7FXYq7FXYq7 FXYq7FXYq7FX
Yq7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7FXYq7FX Yq7FXYq7FXYq
7FXYq7FXYq7FXYq7FXYq7FXYqlfmX/lHNY/5grn/AJNNhHNS/PLMhqf/0PTO q+Y/LyXnpPq1
kskUUEciG5iDK8cKKykctipBBHY5QQWy0H/iXy5/1eLL/pJi/wCasFFNu/xL 5c/6vFl/0kxf
81Y0Vt3+JfLn/V4sv+kmL/mrGitu/wAS+XP+rxZf9JMX/NWNFbd/iXy5/wBX iy/6SYv+asaK
27/Evlz/AKvFl/0kxf8ANWNFbd/iXy5/1eLL/pJi/wCasaK27/Evlz/q8WX/ AEkxf81Y0Vt3
+JfLn/V4sv8ApJi/5qxorbv8S+XP+rxZf9JMX/NWNFbd/iXy5/1eLL/pJi/5 qxorbv8AEvlz
/q8WX/STF/zVjRW3f4l8uf8AV4sv+kmL/mrGitu/xL5c/wCrxZf9JMX/ADVj RW3f4l8uf9Xi
y/6SYv8AmrGitu/xL5c/6vFl/wBJMX/NWNFbd/iXy5/1eLL/AKSYv+asaK27 /Evlz/q8WX/S
TF/zVjRW3f4l8uf9Xiy/6SYv+asaK27/ABL5c/6vFl/0kxf81Y0Vt3+JfLn/ AFeLL/pJi/5q
xorbv8S+XP8Aq8WX/STF/wA1Y0Vt3+JfLn/V4sv+kmL/AJqxorbv8S+XP+rx Zf8ASTF/zVjR
W3f4l8uf9Xiy/wCkmL/mrGitu/xL5c/6vFl/0kxf81Y0Vt3+JfLn/V4sv+km L/mrGitu/wAS
+XP+rxZf9JMX/NWNFbd/iXy5/wBXiy/6SYv+asaK27/Evlz/AKvFl/0kxf8A NWNFbd/iXy5/
1eLL/pJi/wCasaK27/Evlz/q8WX/AEkxf81Y0Vt3+JfLn/V4sv8ApJi/5qxo rbv8S+XP+rxZ
f9JMX/NWNFbd/iXy5/1eLL/pJi/5qxorbv8AEvlz/q8WX/STF/zVjRW3f4l8 uf8AV4sv+kmL
/mrGitu/xL5c/wCrxZf9JMX/ADVjRW3f4l8uf9Xiy/6SYv8AmrGitu/xL5c/ 6vFl/wBJMX/N
WNFbd/iXy5/1eLL/AKSYv+asaK27/Evlz/q8WX/STF/zVjRW3f4l8uf9Xiy/ 6SYv+asaK27/
ABL5c/6vFl/0kxf81Y0Vt3+JfLn/AFeLL/pJi/5qxorbv8S+XP8Aq8WX/STF /wA1Y0Vt3+Jf
Ln/V4sv+kmL/AJqxorbv8S+XP+rxZf8ASTF/zVjRW3f4l8uf9Xiy/wCkmL/m rGitu/xL5c/6
vFl/0kxf81Y0Vt3+JfLn/V4sv+kmL/mrGitu/wAS+XP+rxZf9JMX/NWNFbd/ iXy5/wBXiy/6
SYv+asaK2lvmDzBoE2garDDqtnJNJZ3CRxpcRMzM0TAAANUknCAbQS+BMva3 /9Hz/irsVdir
sVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdir sVdirsVdirsV
dirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsVdirsV f//Z
--------------050202030408090109040504--
Re: Where is the XML editor? [message #57911 is a reply to message #57881] Thu, 23 December 2004 22:39 Go to previous messageGo to next message
Dim Dimych wrote:
> Hi Andreas,
> Cheers,
> Dimos
Hi, the problem you've described might not be a bug. Error markers are
contributed (to the problems view etc.) only after validating. By default
a simple project only validates files when the user explictly invokes the
validate menu item. You can configure the project to automatically
validate on save ... which might be behaviour you're expecting. I've
included a link below to validation tutorial [1] that might explain. Post
back and let me know if this helps and if you have any suggestions on how
we might make the behaviour more intuitive.
[1]
http://www.eclipse.org/webtools/testtutorials/M2/xml/XMLVali dationTutorial.xml
Re: Where is the XML editor? [message #57935 is a reply to message #57429] Thu, 23 December 2004 22:43 Go to previous messageGo to next message
> Hello everyone,
> very helpful.
> Andreas
Andreas, it could be that in your workspaces the 'default' editor has been
configured to be the web browser. I'd suggest right clicking on an XML
file in the navigator view and seeing if the 'Open With...' option lists
the XML editor as an available editor. If not I'd suspect that the plugins
didn't get unzipped correctly (perhaps you ran out of disk space... I know
I've done that before :-)
Re: Where is the XML editor? [message #58031 is a reply to message #57935] Fri, 24 December 2004 04:56 Go to previous messageGo to next message
>> I uninstalled WTP M1 for a similar problem, but this time the XML
>> editor is part of the High Priority items on the milestone plan
> been configured to be the web browser. I'd suggest right clicking on an
> XML file in the navigator view and seeing if the 'Open With...' option
> lists the XML editor as an available editor.
"Open with..." does not list the XML editor.
> plugins didn't get unzipped correctly (perhaps you ran out of disk
> space... I know I've done that before :-)
I just cross-checked and installed Eclipse from scratch. I made sure
that I have at least 1 GB free on my drive, then I unpacked
eclipse-SDK-3.1M4-win32.zip 90,0 MB (94.433.804 bytes) and
wtp-1.0M2.zip 15,3 MB (16.054.198 bytes)
and installed in the WTP as usual.
Again, Eclipse claims that the WTP is installed (Manage
Configuration...) but no XML/JSP anything is available. There is no
other Eclipse plugin installed.
My Eclipse .log:
!SESSION 2004-12-24 10:47:34.739
eclipse.buildId=I20041216-2000
java.version=1.5.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2004-12-24 10:47:34.739
!MESSAGE Invalid preference page path: XML Catalog
Andreas
Re: Where is the XML editor? [message #58056 is a reply to message #57881] Fri, 24 December 2004 05:01 Go to previous messageGo to next message
I have no other XML related plugins installed. Only Subclipse and
RegexTester. I cross-checked with a fresh installation without any extra
plugins - the problem prevails.
I did this already. Even without the Xerces jars the XML editor should
appear in "Open with...", does it?
Andreas
Re: Where is the XML editor? [message #58104 is a reply to message #57911] Fri, 24 December 2004 06:55 Go to previous messageGo to next message
> default a simple project only validates files when the user explictly
> invokes the validate menu item. You can configure the project to
> automatically validate on save ... which might be behaviour you're
> expecting. I've included a link below to validation tutorial [1] that
> might explain. Post back and let me know if this helps and if you have
> any suggestions on how we might make the behaviour more intuitive.
Hi Craig,
I had just SUSPECTED a bug :) But after your explanation everything is
clear. Obviously, this is a cool feature!!! Now the validator is working
exactly as expected. I only wonder why there is no direct link to
complete set of tutorials you sent me the link to one of? (sorry for bad
English, can't manage such a long sentences :) ) They would preclude
from many questions that you have to answer now.
Anyway, lot of thanx for the help! Da thing you are producing is very
valuable and requested by developers. Nice work!!!
Dim Dimych
Where is the XML editor? (solved) [message #58129 is a reply to message #58031] Fri, 24 December 2004 07:14 Go to previous messageGo to next message
Hello again,
I finally managed to solve my problem: I forgot to install some of the
prerequisites listed on
http://download.eclipse.org/webtools/downloads/drops/S-1.0M2 -200412230036/index.html
Eclipse/WTP should check that all required plugins are installed instead
of silently "failing". If nobody as any objections, I will file a bug
report/feature request about this.
Thanks for helping!
Andreas
Re: Where is the XML editor? [message #58157 is a reply to message #58056] Fri, 24 December 2004 07:20 Go to previous messageGo to next message
--------------030300050408030202020203
Hmm... Even can't tell you what's wrong. I'd just told you my experience
with similar problem. Removing extra XML editors had cured this. Then I
can only join to Craig's advice to check if you extracted wtp-1.0M2.zip
correctly. Traverse the 'features' and 'plugins' directories for
'eclipse' folder. If you're able to see it then file unzipped in wrong
place. This is very common error because Eclipse guys like to cook their
distros putting the 'eclipse' folder into archive.
Yes, you're perfectly right. There must be actually even three items:
Web Browser, XML Editor, and XML Source Page Editor.
Sorry pal, that's all I could made for you. Perhaps, Craig would be of
assistance.
Dim Dimych
Content-Type: text/x-vcard; charset=utf-8;
name="matamba.vcf"
Content-Disposition: attachment;
filename="matamba.vcf"
begin:vcard
fn:Dmitry Polishchuk
n:Polishchuk;Dmitry
org:Elashking Research;Perspective Technologies
adr:;;State Univercity Techno-park;Moscow;;;Russian Federation
email;internet:dimos@elashkin.com
title:Head of department
tel;work:+7(095)930-8563
tel;cell:+7(095)243-0759
url:http://www.elashkin.com
version:2.1
end:vcard
--------------030300050408030202020203--
Re: Where is the XML editor? [message #58231 is a reply to message #57429] Fri, 24 December 2004 11:32 Go to previous messageGo to next message
Originally posted by: massimo.nospam.net
I had the same problems, then I paid a little more attention to the
prerequisites in the download page.
did you forget to install, the three components?
http://download.eclipse.org/tools/emf/downloads/drops/2.1.0/ I200412160800/emf-sdo-xsd-SDK-I200412160800.zip
http://download.eclipse.org/tools/gef/downloads/drops/I-I200 41216-200412160200/GEF-SDK-I20041216.zip
http://download.eclipse.org/tools/ve/downloads/drops/R-1.0.2 -200412091401/JEM-runtime-1.0.2.zip
I did. But after installing these three plugins, I finally could start
working.
hope it helps
max
> Hello everyone,
> very helpful.
> Andreas
Re: Where is the XML editor? (solved) [message #58331 is a reply to message #58129] Fri, 24 December 2004 13:23 Go to previous messageGo to next message
On Fri, 24 Dec 2004 13:14:00 +0100, Andreas Schildbach <andreas@schildbach.de> wrote:
> I finally managed to solve my problem: I forgot to install some of the prerequisites listed on http://download.eclipse.org/webtools/downloads/drops/
> S-1.0M2-200412230036/index.html
>Eclipse/WTP should check that all required plugins are installed instead of silently "failing". If nobody as any objections, I will file a bug
Be sure to check your .log file (in the <workspace>/.metadata directory. There should have been errors listed there saying which plugins were disable due to missing pre-reqs.
We probably could, in theory, improve some of the error messages, but in general, not sure how much we can do (other than log the warnings).
Once we get "update manager" function supported, this will be easier, and it will report errors or "need" for other plugins/features.
Thanks for persisting with these early versions.
Re: Where is the XML editor? [message #58354 is a reply to message #58104] Fri, 24 December 2004 13:31 Go to previous messageGo to next message
> Hi Craig,
> Dim Dimych
Yes, we're still working on organizing our tutorials. We should have a
"direct link to complete set of tutorials" soon.
Re: Where is the XML editor? [message #58377 is a reply to message #58157] Fri, 24 December 2004 13:36 Go to previous message
> assistance.
> Cheers,
> Dim Dimych
Andreas,
Just to make sure... did you unzip the dependencies required for wtp (EMF,
GEF, JEM) as listed on the download page [1]?
[1]
Previous Topic:CDT & WTP = conflict
Next Topic:CDT & WTP = conflict
Current Time: Tue Nov 04 22:31:10 EST 2025
Powered by FUDForum. Page generated in 0.05767 seconds
