Home » Modeling » GMF (Graphical Modeling Framework) » How to set the lenght and width of different elemets in gmf
How to set the lenght and width of different elemets in gmf [message #57427] Fri, 29 September 2006 07:19 Go to next message
Originally posted by: Lakshya.agarwal.gmail.com
Hi ,
When I am trying to drag and drop different elements in gmf. Different
elements are of different width and lenghth . Can some please suggest me
how to set width and legth of different elements
Thanks & regards,
Lakshya
Re: How to set the lenght and width of different elemets in gmf [message #57556 is a reply to message #57427] Fri, 29 September 2006 08:54 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
When you select a node on a diagram it becomes decorated with small
black boxes at the corners; drag them to resize the node.
Lakshya wrote:
> Hi ,
> Thanks & regards,
> Lakshya
Re: How to set the lenght and width of different elemets in gmf [message #57605 is a reply to message #57556] Fri, 29 September 2006 09:24 Go to previous messageGo to next message
Hi Dmitry ,
I dont want to drag it . I want When I drag and just drop. That size of
element is different for my different elements. I want to make them same.
Lakshya
Re: How to set the lenght and width of different elemets in gmf [message #57629 is a reply to message #57605] Fri, 29 September 2006 11:31 Go to previous message
If you want to have nodes with fixed width and height you should specify
in gmfgraph model 'Resize Constraint' = 'NONE' for the node and set
min/max/pref sizes for the node figure; see Port in TaiPan as a reference.
Lakshya wrote:
> Hi Dmitry ,
> Lakshya
Previous Topic:java as language for constraints validation
Next Topic:MultiPageEditorPart and properties view
Current Time: Tue Oct 28 20:44:15 EDT 2025
Powered by FUDForum. Page generated in 0.09314 seconds
