Home » Eclipse Projects » Equinox » Starting framework from Java code with EclipseStarter
Starting framework from Java code with EclipseStarter [message #57412] Mon, 23 January 2006 12:42 Go to next message
Originally posted by: agno.AI.SRI.COM
I'm trying to start the framework from existing Java code. I'm
using EclipseStarter to do this. This starts out fine--bundles get
auto-started, but the problem is that EclipseStarter seems to need
an application to start. When I try to add an extension to the
org.eclipse.core.runtime.applications extension point, the logs say:
Command-line arguments: -application com.sri.aic.plugin.core.OSGIAppStarter -noSplash -console 8090 -clean
!ENTRY org.eclipse.osgi 2006-01-23 09:00:10.429
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "com.sri.aic.plugin.core.OSGIAppStarter" could not be found in the
registry. The applications available are: <NONE>.
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:99)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
com.sri.aic.cmatrix.bootstrap.CMatrixCoordinator$1.run(CMatr ixCoordinator.java:120)
at java.lang.Thread.run(Thread.java:595)
I feel I must be missing something fairly obvious, but I can't find
it. I'm guessing that just loading my bundle won't register the
application, but how else must I register the application?
Oh, and I'm using 3.2M4.
Any help would be appreciated.
Andrew.
Re: Starting framework from Java code with EclipseStarter [message #57437 is a reply to message #57412] Mon, 23 January 2006 13:25 Go to previous messageGo to next message
Incidentally, the application does work when I start it from Eclipse,
running it as an Eclipse Application.
Re: Starting framework from Java code with EclipseStarter [message #57462 is a reply to message #57412] Mon, 23 January 2006 22:30 Go to previous messageGo to next message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
Just to clarify, the -application argument is the id of the application
extension that you have to supply. Here it appears (from the name) to be a
class. There is a way of running the platform and telling it not to even
try to run the application but for the life of me I can't see the arg in the
code. The app model is in flux so I suppose it has moved or changed some
how. I'll try to get the info and post back here.
Jeff
"Andrew Agno" <agno@AI.SRI.COM> wrote in message
news:pan.2006.01.23.17.42.20.386734@AI.SRI.COM...
> !STACK 1
> at
java:99)
> at
> at
pLauncher.java:68)
> at
> at
> at
va:120)
> Andrew.
Re: Starting framework from Java code with EclipseStarter [message #57889 is a reply to message #57462] Mon, 23 January 2006 23:57 Go to previous message
Tom reminded me...
There are two properties to set in their config.ini
eclipse.ignoreApp=true
osgi.noShutdown=true
If you do not use the console then you need to make sure that a non-daemon
thread is started from one of their bundles, otherwise the VM will exit once
the work of main is done starting the framework.
Jeff
"Jeff McAffer" <jeff_nospam_mcaffer@ca.ibm.com> wrote in message
news:dr470k$oa4$1@utils.eclipse.org...
a
the
> Jeff
> > !STACK 1
> > at
> java:99)
> > at
> > at
> pLauncher.java:68)
> > at
> > at
> > at
> va:120)
> > Thanks,
> > Andrew.
Previous Topic:problem with EclipseStarter
Next Topic:Bundles View?! Is there such a thing?
Current Time: Thu Nov 20 16:47:34 EST 2025
Powered by FUDForum. Page generated in 0.04415 seconds
