Home » Newcomers » Newcomers » install plugin if only zip is available
install plugin if only zip is available [message #57372] Mon, 25 April 2005 23:55 Go to next message
Originally posted by: nospam.noplace.net
I'd like to install VE 1.1M1 which just became available however the
announcement in the VE NG points only to ZIP files. FAQs and NG articles
I've seen all warn against manual installation into the plugins directory.
So how do I install this plugin if the only pointers I have are to ZIP
files, not update sites?
RL
Re: install plugin if only zip is available [message #57423 is a reply to message #57372] Tue, 26 April 2005 01:15 Go to previous message
Originally posted by: newsgroups.pellaton.li
Hello Roger
Just unzip the content to the plugins-directory while Eclipse is not
running and then run Eclipse with the runtime option "-clean". I always
installed VE - and other plug-ins - manually and I never ran into
troubles.
BTW: VE can be installed using an update site. Look for instructions in:
dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E/vep-ho me/WebContent/faq.html
Hope this helps
Michael Pellaton
> RL
Previous Topic:problem launching runtime workbench
Next Topic:generating dll
Current Time: Thu Nov 06 11:34:00 EST 2025
Powered by FUDForum. Page generated in 0.08304 seconds
