Home » Eclipse Projects » Plugin Development Environment (PDE) » Error in exported product log
Error in exported product log [message #57329] Tue, 21 April 2009 09:47 Go to next message
Hi!
This is x-posted from .equinox, in the hope that you guys might know more
I'm seeing this error in the log of my exported product:
java.io.IOException: Unable to initialize osgi.frameworkClassPath
at org.eclipse.core.launcher.Main.addBaseJars(Main.java:567)
at org.eclipse.core.launcher.Main.getDevPath(Main.java:466)
I solved it using the solution given here:
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg12468.html
It says:
- Copy the org.eclipse.osgi_vernum.jar from the
plugins/org.eclipse.osgi_vernum directory to the plugins directory
- Delete the org.eclipse.osgi_vernum directory
- Launch the application
So this has solved my problem, but I haven't figured out _why_ I need to
do this. Is there something I can do to prevent it on the Eclipse GUI
side, so it doesn't happen if I'm exporting to a new product?
Thanks!
Maurice
Re: Error in exported product log [message #57356 is a reply to message #57329] Tue, 21 April 2009 11:58 Go to previous messageGo to next message
It is probably caused by having org.eclipse.osgi imported into your
workspace as a binary project.
Try doing the export after closing all such imported binary projects.
You don't need to have them in your workspace, it is enough that they
are in your target.
This would be a bug in the export, but the problem is that from the
shape of the project, build can't tell that this is a spoofed up bundle
created by the import and not the real binary bundle.
Maurice O'Connor wrote:
> Hi!
> more :)
> It says:
> Thanks!
> Maurice
Re: Error in exported product log [message #57658 is a reply to message #57356] Wed, 22 April 2009 07:19 Go to previous message
This was indeed the issue. It's working perfectly now - thanks for your
help!
Maurice
> are in your target.
>> Hi!
>> more :)
>> It says:
>> Thanks!
>> Maurice
Re: Error in exported product log [message #595977 is a reply to message #57329] Tue, 21 April 2009 11:58 Go to previous message
are in your target.
> Hi!
> more :)
> It says:
> Thanks!
> Maurice
Re: Error in exported product log [message #596083 is a reply to message #57356] Wed, 22 April 2009 07:19 Go to previous message
help!
Maurice
> are in your target.
>> Hi!
>> more :)
>> It says:
>> Thanks!
>> Maurice
Previous Topic:Build updatesite doesn't create web/* and index.html
Next Topic:Creating an update site
Current Time: Sat Jul 26 09:08:36 EDT 2025
Powered by FUDForum. Page generated in 0.04238 seconds
