Home » Modeling » M2T (model-to-text transformation) » Re: JET Null Pointer Exception & XPath Axes
Re: JET Null Pointer Exception & XPath Axes [message #5103] Tue, 20 March 2007 08:34
Toby,
Please use the M2T newsgroup for JET2 questions. I've added it to the
to list, so you can keep using this thread.
Toby Myers wrote:
> Hello All,
> I have just started using JET and I am having a problem with the
> default files from the EMFT JET Transformation Project. When I run
> the files I receive the error:
> templates/dump.jet(2,1): <c:dump entities="true" format="true"
> select="/*">
> Error: Error executing tag handler: java.lang.NullPointerException
> Does anyone know why this is happening?
> Also I read an old post about JET and XPath expressions that said not
> all the XPath axes are supported. Have any more XPath expressions been
> added since then, especially //. If not, can anyone suggest a good
> workaround?
> Cheers,
> Toby
Previous Topic:MOFScript and the M2T project
Next Topic:JET2 - declaring custom tags
Current Time: Tue Jun 03 17:08:25 EDT 2025
Powered by FUDForum. Page generated in 0.02918 seconds
