| OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #57255] |
Wed, 06 August 2008 09:47  |
I'm trying to custom draw some things within the cells of the
Grid/Gridviewer using the OwnerDrawLabelProvider but it seems that paint
events doesn't get triggered for the label provider. The same applies to
SWT.paintItem on the Grid. Are these intended to be included or is there
another way of doing it?
With regards
Tommy
| Re: OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #494940 is a reply to message #494939] |
Tue, 03 November 2009 05:34  |
done ...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=294035
Enrico
"Tom Schindl" <tom.schindl@bestsolution.at> schrieb im Newsbeitrag
news:hcp05l$qb$1@build.eclipse.org...
> Well Grid simply works different and you can't apply the concept without
> investing time into it.
> Naturally we could add callbacks into our draw CellRenders callback to
> PaintItem, MeasureItem, ... but frankly at the moment this is not on our
> list of things so the only possibility is to experiment with writing
> your own renderer.
> Please log a feature request so that we don't miss this feature.
> Tom
> Enrico Schnepel schrieb:
>> why don't you use the same concept for the grid as well as for the
>> native controls. I ran into the same problem. It should be possible to
>> use the same labelprovider for the grid as well as for a SWT-backended
>> JFace table.
>> Regards,
>> Enrico
| Re: OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #591549 is a reply to message #57255] |
Wed, 06 August 2008 09:49  |
Now owner draw is a concept only part of native swt controls because
nebula grid is completely custom drawn you can simply replace the
cell-renderer if you need some custom drawing.
The concept of owner draw can't work in nebula grid.
Tom
Tommy schrieb:
> Hi
> With regards
> Tommy
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
| Re: OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #598572 is a reply to message #494924] |
Tue, 03 November 2009 05:20  |
your own renderer.
Tom
> JFace table.
> Enrico
| Re: OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #598578 is a reply to message #494939] |
done ...
Enrico
> your own renderer.
> Tom
>> JFace table.
>> Regards,
>> Enrico
FUDForum. Page generated in 0.06292 seconds
