Home » Eclipse Projects » Equinox » Minor problem with serverSide web.xml
Minor problem with serverSide web.xml [message #57175] Thu, 19 January 2006 20:34 Go to next message
For fun I tried publishing the bridge.war to WAS (Websphere). The publish
failed because it detected an issue with the servlet defined in the
web.xml. Moving the <load-on-startup> attribute after the <init-parm>
attributes fixed it and it worked on WAS. I am no expert but I think the
XML schema defines this attributed to be last. The corrected servelet
definition looks like this:
<servlet id="bridge">
<servlet-name>equinoxbridgeservlet</servlet-name>
<display-name>Equinox Bridge Servlet</display-name>
<description>Equinox Bridge Servlet</description>
<servlet-class>org.eclipse.equinox.servlet.bridge.BridgeServlet </servlet-class>
<init-param>
<param-name>enableConsole</param-name>
<param-value>true</param-value>
</init-param>
<init-param>
<param-name>enableFrameworkControls</param-name>
</init-param>
<load-on-startup>1</load-on-startup>
Jim D'Anjou
Re: Minor problem with serverSide web.xml [message #57201 is a reply to message #57175] Thu, 19 January 2006 20:52 Go to previous message
Originally posted by: skaegi.sympatico.ca
Updated.
Thanks Jim.
"Jim D'Anjou" <danjou@us.ibm.com> wrote in message
news:45f802edffeeadb27cf645346c2d8640$1@www.eclipse.org...
ss>
> <init-param>
> </init-param>
> <init-param>
> </init-param>
> Jim D'Anjou
Previous Topic:eclipse server-side startup questions
Next Topic:Failed to start Infocenter(Help System)
Current Time: Mon Jul 21 21:17:20 EDT 2025
Powered by FUDForum. Page generated in 0.25192 seconds
